[GeoNode-users] Just installed Geonode, one question
Charles Cossé ccosse at gmail.com
Tue Oct 20 12:15:06 PDT 2015
In /etc/apache2/sites-enabled you need 1) geonode.conf and 2) omeka.conf.
-Charles
On Tue, Oct 20, 2015 at 3:09 PM, Gisli Palsson <gisli.palsson at umu.se> wrote:
> Thanks for the response Simone. I have been trying to change the server
> name to get around this.
> Tried going from ‘servername localhost’ to ‘servername geonode.localhost’
> but that doesn’t do the trick. Anyone know?
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Sent:* 20 October 2015 20:59
> *To:* Gisli Palsson <gisli.palsson at umu.se>
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Just installed Geonode, one question
> Hi as stated in the docs geonode installed via apt-get should be installed
> in a clean environment. Probably it just changed the Apache default site
> but might not be the only thing. /etc/apache/sites-enabled
> Hope this helps
> Il martedì 20 ottobre 2015, Gisli Palsson <gisli.palsson at umu.se> ha
> scritto:
> Hey,
> I just installed Geonode onto a system that I’m planning on using for two
> applications. The Geonode works fine, but the other (Omeka) installed at
> var/www/omeka isn’t being served to the internet. Instead, Geonode takes
> over the entire site. There isn’t anything obvious in the documentation to
> solve this.
> I’m not sure how to fix this, any help appreciated!
> Simone
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151020/3ce27cdd/attachment.html>
More information about the geonode-users mailing list
