[GeoNode-users] syncdb problem
Simone Dalmasso simone.dalmasso at gmail.com
Wed Oct 28 08:27:15 PDT 2015
yeah it is correct, the --all was only to apply the 2.0 migrations.
2015-10-28 16:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I solved this issue I think was due to different version of django and
> geonode schema,
> by the way I remove all the packages installed via pip including django
> and I reinstalled
> each package by using:
> sudo pip install -e .
> then I sincronized the db
> and everything was ok.
> To syncdb I gave:
> python manage.py syncdb --noinput
> without --all as suggeste in the guide, was that a problem?
> best
> Eugenio
> From: simone.dalmasso at gmail.com
> Date: Wed, 28 Oct 2015 14:47:49 +0100
> Subject: Re: syncdb problem
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Which version of python-six you have. I has to be the 1.5.2, check it with:
> $ pip freeze | grep six
> 2015-10-28 14:40 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> I added this package, which was missing, however after the installation
> I run again
> and I got the same error lines.
> E.
> Date: Wed, 28 Oct 2015 14:32:12 +0100
> Eugenio,
> $ sudo apt-get install python-django-autocomplete-light
> should fix it.
> 2015-10-28 14:22 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I'm trying (again) to complete the installation and the test of the
> current geonode version 2.4.dev20151023111102.
> After a test on vagrant box, which run fine, I upgraded the software
> versions on my server machine.
> Now I have Ubuntu sserver at 14.04 version, apache2 is at 2.4.7 version,
> postgresql-postgis 9.3 (2.1) all of them installed from packages and
> tomcat7 installed manually.
> As usual I followed the guide:
> http://docs.geonode.org/en/latest/tutorials/admin/install/custom_install.html#custom-install
> Currently I have a problem on:
> which gave me this output:
> http://paste.ubuntu.com/12988689/
> The only difference is that I have postgresql listening on 5433 port
> instead the default. Of course I set the different post in the
> local_setting.py file.
> Any suggestions?
> thanks
> Eugenio
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/11fac2b2/attachment.html>
More information about the geonode-users mailing list
