[GeoNode-users] Cant upload and register remote services after update
Christian Willmes
c.willmes at uni-koeln.de
Fri Oct 30 07:02:26 PDT 2015
thanks, but it did not help. I did:
~$ geonode collectstatic
You have requested to collect static files at the destination
location as specified in your settings.
This will overwrite existing files!
Are you sure you want to do this?
Type 'yes' to continue, or 'no' to cancel: yes
0 static files copied, 880 unmodified.
Errors in logs look exactly same, as posted in the mail before.
Regards,
Christian
Am 30.10.2015 um 14:57 schrieb Simone Dalmasso:
> Christian. A geonode collectstatic may fix. Let us know
> Il venerdì 30 ottobre 2015, Christian Willmes
> <christian.willmes at googlemail.com
> <mailto:christian.willmes at googlemail.com>> ha scritto:
> Hi,
> I run a GeoNode /version 2.4c2 /from the ubuntu packages./
> /After an "apt-get update / upgrade" yesterday, I can't upload new
> layers or register remote services on GeoNode anymore.
> /On registering remote services the logs say:
> [Fri Oct 30 13:24:41.857736 2015] [core:error] [pid 24951:tid
> 140094098888448] [client 134.95.126.26:38719
> <http://134.95.126.26:38719>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.857932 2015] [core:error] [pid 25013:tid
> 140094014961408] [client 134.95.126.26:38714
> <http://134.95.126.26:38714>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.858108 2015] [core:error] [pid 24951:tid
> 140094090495744] [client 127.0.0.1:36688 <http://127.0.0.1:36688>]
> End of script output before headers: geonode.wsgi
> [Fri Oct 30 13:24:41.858290 2015] [core:error] [pid 24951:tid
> 140094073710336] [client 134.95.126.26:38467
> <http://134.95.126.26:38467>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.858455 2015] [core:error] [pid 24951:tid
> 140094006568704] [client 134.95.126.26:38447
> <http://134.95.126.26:38447>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.858625 2015] [core:error] [pid 25013:tid
> 140094115673856] [client 134.95.126.26:38399
> <http://134.95.126.26:38399>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.858788 2015] [core:error] [pid 25013:tid
> 140093914248960] [client 134.95.126.26:38411
> <http://134.95.126.26:38411>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.858963 2015] [core:error] [pid 25013:tid
> 140093939427072] [client 134.95.126.26:38433
> <http://134.95.126.26:38433>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.859267 2015] [core:error] [pid 25013:tid
> 140093964605184] [client 134.95.126.26:38350
> <http://134.95.126.26:38350>] End of script output before headers:
> geonode.wsgi
> [Fri Oct 30 13:24:41.859403 2015] [core:error] [pid 24951:tid
> 140093922641664] [client 134.95.150.136:37065
> <http://134.95.150.136:37065>] End of script output before
> headers: geonode.wsgi, referer:
> http://geonode.crc806db.uni-koeln.de/services/register/
> On upload via the web gui, the logs say:
> [Fri Oct 30 07:50:58.506998 2015] [:error] [pid 1277:tid
> 139701666780928] "'category'"
> [Fri Oct 30 07:50:58.507085 2015] [:error] [pid 1277:tid
> 139701666780928] Traceback (most recent call last):
> [Fri Oct 30 07:50:58.507097 2015] [:error] [pid 1277:tid
> 139701666780928] File
> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py",
> line 154, in layer_upload
> [Fri Oct 30 07:50:58.507106 2015] [:error] [pid 1277:tid
> 139701666780928] topic_id = request.POST['category']
> [Fri Oct 30 07:50:58.507115 2015] [:error] [pid 1277:tid
> "/usr/lib/python2.7/dist-packages/django/utils/datastructures.py",
> line 301, in __getitem__
> [Fri Oct 30 07:50:58.507126 2015] [:error] [pid 1277:tid
> 139701666780928] raise MultiValueDictKeyError(repr(key))
> [Fri Oct 30 07:50:58.507139 2015] [:error] [pid 1277:tid
> 139701666780928] MultiValueDictKeyError: "'category'"
> Is there any step I need to do manually after an package upgrade?
> I remember similar problems after the last update, then it was a
> problem with "uploadsession" not "category" during upload layers.
> Thanks and regards,
> Christian
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Christian Willmes
AG GIS & Fernerkundung | GIS & RS Group
Geographisches Institut | Institute of Geography
Universität zu Köln | University of Cologne
Tel.: +49 (0)221 470 6234
http://www.geographie.uni-koeln.de/willmes-christian.695.en.html
http://www.sfb806.de
http://crc806db.uni-koeln.de
More information about the geonode-users
