[GeoNode-users] Use raster
Jeffrey Johnson ortelius at gmail.com
Thu Sep 3 16:38:42 PDT 2015
If you can get GeoServer to render from PostGIS Rasters, then it can
be used in GeoNode. Check here for instructions on installing PostGIS
raster into your GeoServer using ImageMosaic.
http://docs.geoserver.org/stable/en/user/data/raster/postgisraster.html
On Thu, Sep 3, 2015 at 4:11 PM, GGC Garcia <gacoge at gmail.com> wrote:
> Jeffrey thank you so much.
> For your answer I have other question.
> Geonode can display a raster if I first import a raster in postgres using
> gdal?
> Is possible this option?
> Gerardo
> El sep 3, 2015 5:54 p.m., "Jeffrey Johnson" <ortelius at gmail.com> escribió:
>> Geonode does not support PostGIS Rasters currently. The rasters are
>> stored on the filesystem in the GeoServer data directory.
>> On Thu, Sep 3, 2015 at 3:52 PM, GGC Garcia <gacoge at gmail.com> wrote:
>> > Hello
>> > I have a question of the raster importing.
>> > I imported a raster and  the  procces is right. Because I can see the
>> > map in
>> > geonode and edit the metadata and define de simbology etc.
>> > But when I want look the raster in postgres, I can't find the table.
>> > Do you know what happend or where is the table.
>> > Regards
>> > Gerardo
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
