[GeoNode-users] Layer upload and enabling django-notification
Seno Adiwicaksono senoadiw at gmail.com
Mon Sep 7 03:52:45 PDT 2015
Hi Simone,
Looks like that did the trick, all that was required was to:
sudo chown root:www-data /var/www
sudo chmod g+w /var/www
It's okay to leave the /var/www/geonode owner and permission alone (I
switched mine back to root:root with 755 perm). Also the notification
folder in /var/www/geonode is not required.
Thanks a lot!
Regards,
SN
On Mon, Sep 7, 2015 at 5:11 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Ok, tested on a Virtual machine. I had to make sure that www-data has the
> rights to write in the /var/www folder. Tested changing the ownership and
> works.
> 2015-09-07 11:59 GMT+02:00 Seno Adiwicaksono <senoadiw at gmail.com>:
>> Hi Simone,
>> I did the complete install from
>> https://geonode.readthedocs.org/en/2.0/tutorials/admin/install/complete_install.html.
>> I have the main geonode installation in /var/www/geonode/ and a geonode
>> project in /var/www/my_geonode/. GeoNode is running under Apache www-data
>> user. I can see the layer files written in the uploaded dir but then the
>> lockfile error happens.
>> Regards,
>> SN
>> On Mon, Sep 7, 2015 at 4:39 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> what installation did you do?
>>> 2015-09-07 11:05 GMT+02:00 Seno Adiwicaksono <senoadiw at gmail.com>:
>>>> Dear GeoNode users,
>>>> I'm trying to enable notifications on my GeoNode install however met
>>>> with the same lockfile error as pointed out by Hugo in this thread
>>>> http://osgeo-org.1560.x6.nabble.com/uploading-layer-and-enable-notifications-td5214225.html.
>>>> I also tried setting the NOTIFICATION_LOCK_LOCATION variable as well as
>>>> chown the /var/www/geonode folder to www-data and create a notification
>>>> folder in it with 777 permissions which did not work in my case. I also
>>>> tried setting NOTIFICATION_QUEUE_ALL = True so the notifications are sent
>>>> later but the error just came up faster.
>>>> As for now I commented out notification in INSTALLED_APPS to allow
>>>> layer uploads to complete. Is anyone else having the same issue and are
>>>> there any other workarounds? I would greatly appreciate any input provided.
>>>> Regards,
>>>> SN
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150907/247ea000/attachment.html>
More information about the geonode-users mailing list
