[GeoNode-users] unable to save maps
Eugenio Trumpy frippe12573 at hotmail.com
Mon Sep 21 09:11:26 PDT 2015
Dear all,
I'm testing GeoNode version 2.4.dev20150908094256.
I installed this version by following the steps described here:
http://docs.geonode.org/en/latest/tutorials/admin/install/custom_install.html#custom-install
The application seems to work fine. I added 4 different wed map services (both geoservers and mapserver),
and I have several layers.
I tried to compose a map, and I was able to, but I got an error on saving the prepared maps as well as when
I click on create maps I had:
The server returned an error: 503 SERVICE UNAVAILABLE
I think this error is due to a geoserver that I'm using for geonode.
Is that right?
Actually the geoserver that I got from the geonode installation runs (or should run) in a second container of tomcat6
since I already have another geoserver instance on the first tomcat6 container. And I have to use them separate.
Am I right?
I would even use a running Geonetwork for metadata, if I understand well there are two ways:
one is to use my geonetwork as metadata repository. for this I should set it up in the local_setting.py file
or second insert it as external CSW service.
Am I correct?
Thanks for any kind hints you would give me.
Best
Eugenio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150921/169efc8c/attachment.html>
More information about the geonode-users mailing list
