[GeoNode-users] problem to install geonode on a remote vm
Giuseppe Ricci peppepegasus at gmail.com
Wed Sep 23 08:00:25 PDT 2015
I have a question: the mentioned tutorial is to install in local
geonode..if I want to install on a remote server there is a tutorial?
Thanks
Dott. Giuseppe Ricci
Via B. Spaventa 6, Terlizzi
Cel. 340 3059772
2015-09-23 16:06 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Giuseppe,
> I don't know about Azure but the connection refused error should be more
> relate to the web server configuration rather than Geonode that would throw
> a 5XX error series in case of errors or misconfigurations.
> 2015-09-23 16:02 GMT+02:00 Giuseppe Ricci <peppepegasus at gmail.com>:
>> Hi guys,
>> I'm trying to install geonode on a virtual machine installed on Micrsoft
>> Azure server.
>> I followed this tutorial:
>> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
>> but when i give this command:
>> sudo geonode-updateip localhost:4567
>> I receive this errors:
>> $  sudo geonode-updateip localhost:4567
>> Replacing SITEURL value with 'localhost:4567' in
>> /etc/geonode/local_settings.py ... done.
>> Adding entry for 'localhost:4567' in
>> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
>> found to the printing whitelist.
>> Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py
>> ... 'localhost:4567' already found in ALLOWED_HOSTS list.
>>  * Restarting web server
>> apache2
>> AH00558: apache2: Could not reliably determine the server's fully qualified
>> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
>> suppress this message
>> [ OK ]
>> Finished processing 0 layers in 0.0 seconds.
>> 0 Created layers
>> 0 Updated layers
>> 0 Failed layers
>> 0.000000 seconds per layer
>> At the adress localhost:4567 I receive the message:
>> web page doesn't exist. ERR_CONNECTION_REFUSED.
>> Can some one to help me?
>> Thanks.
>> Cel. 340 3059772
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/ccdb61a2/attachment.html>
More information about the geonode-users mailing list
