[GeoNode-users] problem to install geonode on a remote vm
Charles Cossé ccosse at gmail.com
Wed Sep 23 10:47:56 PDT 2015
Ahh yes that's a good idea ... we don't have a domain yet so we've just
been using numbers, but thank you for that suggestion.  We will have to
pause and consider that.
-C
On Wed, Sep 23, 2015 at 1:07 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> You best bet is to set a domain name that resolves both locally and
> externally to the right IP address.
> GeoNode stores the full URL internally in a few places, the main reason is
> historical because geonetwork and geoserver need fully qualified urls
> instead of relative ones. It would be interested to have someone
> investigate how to remove that restriction from GeoNode.
> -a
> On Wed, Sep 23, 2015 at 10:12 AM, Charles Cossé <ccosse at gmail.com> wrote:
>> Hi, we have an issue running the latest GeoNode on a virtual server.
>> From our LAN we access via a 192.168 ip address.  Externally we access via
>> another, real ip address.   But when we access externally the image
>> thumbnails and layers fail to show because they are referencing the 192.168
>> address.   Looking through the database ("maps_mapsnapshot" table) I found
>> that GeoNode had ingested the 192.168 address and was generating links from
>> there.   I concluded that having 2 ips (one internal, one external) must
>> not be possible given what was happening.  I don't see any way around it
>> and we're re-configuring our systems to use a single IP as a result.
>> Thanks,
>> Charles Cossé
>> Guyana Forestry Commission
>> Georgetown, Guyana
>> On Wed, Sep 23, 2015 at 10:02 AM, Giuseppe Ricci <peppepegasus at gmail.com>
>> wrote:
>>> Hi guys,
>>> I'm trying to install geonode on a virtual machine installed on Micrsoft
>>> Azure server.
>>> I followed this tutorial:
>>> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
>>> but when i give this command:
>>> sudo geonode-updateip localhost:4567
>>> I receive this errors:
>>> $  sudo geonode-updateip localhost:4567
>>> Replacing SITEURL value with 'localhost:4567' in
>>> /etc/geonode/local_settings.py ... done.
>>> Adding entry for 'localhost:4567' in
>>> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
>>> found to the printing whitelist.
>>> Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>> ... 'localhost:4567' already found in ALLOWED_HOSTS list.
>>>  * Restarting web server
>>> apache2
>>> AH00558: apache2: Could not reliably determine the server's fully qualified
>>> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
>>> suppress this message
>>> [ OK ]
>>> Finished processing 0 layers in 0.0 seconds.
>>> 0 Created layers
>>> 0 Updated layers
>>> 0 Failed layers
>>> 0.000000 seconds per layer
>>> At the adress localhost:4567 I receive the message:
>>> web page doesn't exist. ERR_CONNECTION_REFUSED.
>>> Can some one to help me?
>>> Thanks.
>>> Dott. Giuseppe Ricci
>>> Via B. Spaventa 6, Terlizzi
>>> Cel. 340 3059772
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/8330dd49/attachment.html>
More information about the geonode-users mailing list
