[GeoNode-users] problem to install geonode on a remote vm
Charles Cossé ccosse at gmail.com
Wed Sep 23 11:50:11 PDT 2015
I totally concur.
On Wed, Sep 23, 2015 at 2:44 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> In your intranet, you can set the domain name for testing in the router
> configuration.
> On your developer machine and for trusted users you can edit the
> /etc/hostnames (or the windows equivalent) and test it too.
> I usually do that and it works fine, let's you get early feedback on the
> name from trusted people and generally results in a faster agreement on
> what the DNS should be.
> -a
> On Wed, Sep 23, 2015 at 12:47 PM, Charles Cossé <ccosse at gmail.com> wrote:
>> Ahh yes that's a good idea ... we don't have a domain yet so we've just
>> been using numbers, but thank you for that suggestion.  We will have to
>> pause and consider that.
>> -C
>> On Wed, Sep 23, 2015 at 1:07 PM, Ariel Nunez <ingenieroariel at gmail.com>
>> wrote:
>>> You best bet is to set a domain name that resolves both locally and
>>> externally to the right IP address.
>>> GeoNode stores the full URL internally in a few places, the main reason
>>> is historical because geonetwork and geoserver need fully qualified urls
>>> instead of relative ones. It would be interested to have someone
>>> investigate how to remove that restriction from GeoNode.
>>> -a
>>> On Wed, Sep 23, 2015 at 10:12 AM, Charles Cossé <ccosse at gmail.com>
>>> wrote:
>>>> Hi, we have an issue running the latest GeoNode on a virtual server.
>>>> From our LAN we access via a 192.168 ip address.  Externally we access via
>>>> another, real ip address.   But when we access externally the image
>>>> thumbnails and layers fail to show because they are referencing the 192.168
>>>> address.   Looking through the database ("maps_mapsnapshot" table) I found
>>>> that GeoNode had ingested the 192.168 address and was generating links from
>>>> there.   I concluded that having 2 ips (one internal, one external) must
>>>> not be possible given what was happening.  I don't see any way around it
>>>> and we're re-configuring our systems to use a single IP as a result.
>>>> Thanks,
>>>> Charles Cossé
>>>> Guyana Forestry Commission
>>>> Georgetown, Guyana
>>>> On Wed, Sep 23, 2015 at 10:02 AM, Giuseppe Ricci <
>>>> peppepegasus at gmail.com> wrote:
>>>>> Hi guys,
>>>>> I'm trying to install geonode on a virtual machine installed on
>>>>> Micrsoft Azure server.
>>>>> I followed this tutorial:
>>>>> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
>>>>> but when i give this command:
>>>>> sudo geonode-updateip localhost:4567
>>>>> I receive this errors:
>>>>> $  sudo geonode-updateip localhost:4567
>>>>> Replacing SITEURL value with 'localhost:4567' in
>>>>> /etc/geonode/local_settings.py ... done.
>>>>> Adding entry for 'localhost:4567' in
>>>>> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
>>>>> found to the printing whitelist.
>>>>> Adding localhost:4567 to ALLOWED_HOSTS in
>>>>> /etc/geonode/local_settings.py ... 'localhost:4567' already found in
>>>>> ALLOWED_HOSTS list.
>>>>>  * Restarting web server
>>>>> apache2
>>>>> AH00558: apache2: Could not reliably determine the server's fully qualified
>>>>> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
>>>>> suppress this message
>>>>> [ OK ]
>>>>> Finished processing 0 layers in 0.0 seconds.
>>>>> 0 Created layers
>>>>> 0 Updated layers
>>>>> 0 Failed layers
>>>>> 0.000000 seconds per layer
>>>>> At the adress localhost:4567 I receive the message:
>>>>> web page doesn't exist. ERR_CONNECTION_REFUSED.
>>>>> Can some one to help me?
>>>>> Thanks.
>>>>> Dott. Giuseppe Ricci
>>>>> Via B. Spaventa 6, Terlizzi
>>>>> Cel. 340 3059772
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/f477d940/attachment.html>
More information about the geonode-users mailing list
