[GeoNode-users] problem to install geonode on a remote vm
Giuseppe Ricci peppepegasus at gmail.com
Thu Sep 24 04:58:20 PDT 2015
It seems, according to the tutorial, that command is to update the ip.
Dott. Giuseppe Ricci
Via B. Spaventa 6, Terlizzi
Cel. 340 3059772
2015-09-24 13:51 GMT+02:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
> Hi,
> shouldn´t you use
> $ sudo geonode update-ip http://domain.cloudapp.net:4567/
> To correctly update the site references?
> Message: 2
> Date: Thu, 24 Sep 2015 12:04:13 +0200
> From: Giuseppe Ricci <peppepegasus at gmail.com>
> To: Charles Coss? <ccosse at gmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] problem to install geonode on a remote vm
> Message-ID:
>         <CAB6LW8YjcwxkwTTmXNgu5EmzmixwwGU1__f=zL=
> Y_ksSvSKT1w at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> As suggested Ariel I set in the file /etc/geonode/local_settings.py in this
> manner:
> SITEURL = 'http://domain.cloudapp.net:4567/'
> but I have the same problem..is it not correct as ip adress configuration?
> g
> Cel. 340 3059772
> mit freundlichen Grüßen
> Florian Hoedt
> B.Sc. Florian Hoedt
> Hochschule Ostwestfalen-Lippe / Campus Höxter
> FB 9 Landschaftsarchitektur und Umweltplanung
> An der Wilhelmshöhe 44
> 37671 Höxter
> Tel.: 05271-687-7478
> E-Mail: florian.hoedt at hs-owl.de
> www.hs-owl.de/fb9
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150924/277fe01d/attachment.html>
More information about the geonode-users mailing list
