[GeoNode-users] Geoserver version and requirements
Simone Giannecchini simone.giannecchini at geo-solutions.it
Thu Sep 24 05:09:41 PDT 2015
Ciao Eugenio,
I would suggest to explicitly set the JDK in the env var for tomcat so
you are sure which one you calling.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Sep 24, 2015 at 12:46 PM, Eugenio Trumpy
<frippe12573 at hotmail.com> wrote:
> Hi Simone,
> thank you for your hints.
> On regard the first issue, you are right webapp-replica is a clone container
> of tomcat6, actually monitor does not exist,
> it exists in the first tomcat6 container.
> On regard the second problem I update the system installing openJDK-7, then
> I updated the java alternatives
> and I restarted both tomcat6 and tomcat6-replica, however the same error
> still exist.
> E.
>> From: simone.giannecchini at geo-solutions.it
>> Date: Thu, 24 Sep 2015 11:48:07 +0200
>> Subject: Re: [GeoNode-users] Geoserver version and requirements
>> To: frippe12573 at hotmail.com
>> CC: geonode-users at lists.osgeo.org
>> Ciao Eugenio,
>> I see two errors:
>> -1- you probably using an existing tomcat installation or a clone of it.
>> Which references this path that does not exists:
>> /dati/webapps-replica/monitor
>> This should not be a blocker.
>> -2- you are probably deploying a 2.7.x (can you confirm) instance of
>> GeoServer using java6:
>> java.lang.UnsupportedClassVersionError:
>> org/geoserver/GeoserverInitStartupListener : Unsupported major.minor
>> version 51.0 (unable to load class
>> org.geoserver.GeoserverInitStartupListener)
>> You can have multiple java version on the same machine. You need to
>> have this tomcat using java 7.
>> Regards,
>> Simone Giannecchini
>> @simogeo
>> Founder/Director
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> On Thu, Sep 24, 2015 at 11:20 AM, Eugenio Trumpy
>> > Dear all,
>> > for many reasons I had to configure two tomcat6 containers since I have
>> > to manage two different geoserver:
>> > first geoserver (G1) is an original version 2.3.2, which is running
>> > correctly in the first container of tomcat6. This geoserver the one I
>> > use to
>> > spread spatial dataset on behalf of my organization
>> > second geoserver (G2) istance is the version I took from geonode
>> > installation (from downloaded directory), and I put it on the second
>> > tomcat6
>> > container.
>> > Unfortunately G2 is not running, although the second tomcat6 container
>> > runs
>> > fine (I tested a sample application downloaded from the web and I tried
>> > there a normal geoserver application (vs.2.3.2), the G2 took from the
>> > geonode istallation give me the error here below:
>> > 4-set-2015 11.15.40 org.apache.catalina.core.StandardService stop
>> > INFO: Stopping service Catalina
>> > 24-set-2015 11.15.40 org.apache.coyote.http11.Http11Protocol destroy
>> > INFO: Stopping Coyote HTTP/1.1 on http-8081
>> > CompilerOracle: unrecognized line
>> > "exclude net/sf/saxon/event/ReceivingContentHandler startElement'"
>> > Unrecognized text after command: '
>> > 24-set-2015 11.15.48 org.apache.catalina.startup.ClassLoaderFactory
>> > validateFile
>> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/server/classes],
>> > exists: [false], isDirectory: [false], canRead: [false]
>> > validateFile
>> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/server], exists:
>> > validateFile
>> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/shared/classes],
>> > validateFile
>> > AVVERTENZA: Problem with directory [/usr/share/tomcat6/shared], exists:
>> > 24-set-2015 11.15.49 org.apache.coyote.http11.Http11Protocol init
>> > INFO: Initializing Coyote HTTP/1.1 on http-8081
>> > 24-set-2015 11.15.49 org.apache.catalina.startup.Catalina load
>> > INFO: Initialization processed in 785 ms
>> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardService start
>> > INFO: Starting service Catalina
>> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardEngine start
>> > INFO: Starting Servlet Engine: Apache Tomcat/6.0.35
>> > 24-set-2015 11.15.49 org.apache.catalina.startup.HostConfig
>> > deployDescriptor
>> > INFO: Deploying configuration descriptor monitor.xml
>> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext
>> > resourcesStart
>> > GRAVE: Error starting static Resources
>> > java.lang.IllegalArgumentException: Document base
>> > /dati/webapps-replica/monitor does not exist or is not a readable
>> > directory
>> > at
>> > org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:142)
>> > at
>> > org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4320)
>> > at
>> > org.apache.catalina.core.StandardContext.start(StandardContext.java:4489)
>> > at
>> > org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
>> > at
>> > org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
>> > at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
>> > at
>> > org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:675)
>> > at
>> > org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:601)
>> > at
>> > org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:502)
>> > at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
>> > at
>> > org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
>> > at
>> > org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
>> > at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
>> > at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
>> > at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
>> > at
>> > org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
>> > at
>> > org.apache.catalina.core.StandardService.start(StandardService.java:525)
>> > at
>> > org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
>> > at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
>> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> > at
>> > sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
>> > at
>> > sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
>> > at java.lang.reflect.Method.invoke(Method.java:622)
>> > at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
>> > at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
>> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext start
>> > GRAVE: Error in resourceStart()
>> > GRAVE: Error getConfigured
>> > GRAVE: Context [/monitor] startup failed due to previous errors
>> > 24-set-2015 11.15.49 org.apache.catalina.core.StandardContext stop
>> > INFO: Container
>> > org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/monitor]
>> > has
>> > not been started
>> > 24-set-2015 11.15.49 org.apache.catalina.startup.HostConfig deployWAR
>> > INFO: Deploying web application archive sample.war
>> > INFO: Deploying web application archive geoserver.war
>> > 24-set-2015 11.15.50 org.apache.catalina.loader.WebappClassLoader
>> > validateJarFile
>> > INFO:
>> > validateJarFile(/dati/webapps-replica/geoserver/WEB-INF/lib/servlet-api-2.5.jar)
>> > - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
>> > javax/servlet/Servlet.class
>> > 24-set-2015 11.15.50 org.apache.tomcat.util.modeler.Registry
>> > registerComponent
>> > GRAVE: Null component
>> > Catalina:type=JspMonitor,name=jsp,WebModule=//localhost/geoserver,J2EEApplication=none,J2EEServer=none
>> > 24-set-2015 11.15.50 org.apache.catalina.startup.HostConfig deployWAR
>> > GRAVE: Error deploying web application archive geoserver.war
>> > version
>> > 51.0 (unable to load class org.geoserver.GeoserverInitStartupListener)
>> > at
>> > org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2822)
>> > at
>> > org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1159)
>> > at
>> > org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1647)
>> > at
>> > org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
>> > at
>> > org.apache.catalina.startup.WebAnnotationSet.loadClassAnnotation(WebAnnotationSet.java:145)
>> > at
>> > org.apache.catalina.startup.WebAnnotationSet.loadApplicationListenerAnnotations(WebAnnotationSet.java:73)
>> > at
>> > org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:56)
>> > at
>> > org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:297)
>> > at
>> > org.apache.catalina.startup.ContextConfig.start(ContextConfig.java:1078)
>> > at
>> > org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:261)
>> > at
>> > at
>> > org.apache.catalina.core.StandardContext.start(StandardContext.java:4612)
>> > at
>> > at
>> > at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
>> > at
>> > org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
>> > at
>> > org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > 24-set-2015 11.15.50 org.apache.coyote.http11.Http11Protocol start
>> > INFO: Starting Coyote HTTP/1.1 on http-8081
>> > 24-set-2015 11.15.50 org.apache.catalina.startup.Catalina start
>> > I searched something on the net and this problem should be related to
>> > different version of tomcat/java JDK/geoserver
>> > is that right?
>> > My server is an Ubuntu 12.04, tomcat is at version 6, and java is
>> > java-6-openjdk-amd64
>> > Is that a right config?
More information about the geonode-users mailing list
