[GeoNode-users] Understanding group permissions in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Thu Sep 24 06:20:35 PDT 2015
There's no docs on that but you can look at
https://github.com/GeoNode/geonode/blob/master/geonode/templates/_permissions.html
https://github.com/GeoNode/geonode/blob/master/geonode/social/signals.py#L154
2015-09-24 14:04 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> Hi Simone, Seno,
> Thanks for the info. We will try to implement the changes here. Is there
> some documentation showing which parts of the code needs to be changed?
> Cheers
> Daniel
> On Thu, Sep 24, 2015 at 6:58 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Thanks Seno,
>> just to add that the default anonymous permissions (and the checkbox
>> behavior) can be controlled by these settings
>> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L401
>> 2015-09-24 9:04 GMT+02:00 Seno Adiwicaksono <senoadiw at gmail.com>:
>>> Hi Daniel,
>>> I sort of got this flow working. What was done is to make sure that the
>>> approving group (call it GroupApproval) is given all the group permissions
>>> in the layer upload page, I set it through javascript to fill the
>>> permissions textbox with GroupApproval. Also it is key to make sure the
>>> Anyone (view and download) checkboxes are unchecked. Once the user has
>>> successfully uploaded the layer, an email notification is sent to members
>>> of GroupApproval. Since the Anyone view permission is unchecked, the layer
>>> will not show up in the layers list even though it's published. Then the
>>> GroupApproval member can visit the new layer from the link in the email,
>>> review it, and finally check the Anyone view and download permissions so it
>>> is accessible by the public.
>>> Hope this helps!
>>> Regards,
>>> SN
>>> On Thu, Sep 24, 2015 at 1:19 PM, Simone Dalmasso <
>>>> Hi Daniel,
>>>> what you want to achieve cannot be done with standard GeoNode as, by
>>>> default, a user that uploads data is also the owner and can publish and
>>>> modify it. You would have to modify the standard permissions (easy
>>>> setting), the UI to remove the public flags and not grant the
>>>> "change_resourcebase_permissions" permission to the users that should not
>>>> be able to publish.
>>>> Then you have to add the notifications system to the group you need for
>>>> "layer_uploaded".
>>>> About the permissions, don't consider the ones in the "admin panel" as
>>>> they contain also some django internals that we don't use. the GeoNode
>>>> permissions are the ones listed in the permissions widget:
>>>> 2015-09-23 21:15 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> Hi list,
>>>>> We'd like to create some groups in GeoNode similar to what Seno
>>>>> describes bellow. One group that can upload data and fill the metadata but
>>>>> not make it public. And a second group that will review, correct the
>>>>> metadata and make it public. Is this done using only the group permissions?
>>>>> Or are there some other things that need to be changed?
>>>>> Also, looking at the group permissions in the administration panel, I
>>>>> got lost. Is there some place that describes what each of the permissions
>>>>> is for? Some are quite self-describing but, what is the difference between:
>>>>> a) can add layer vs. can add layer file
>>>>> b) can add upload vs. can add upload file
>>>>> Cheers
>>>>> Daniel
>>>>> On Mon, Sep 7, 2015 at 9:25 AM, Seno Adiwicaksono <senoadiw at gmail.com>
>>>>> wrote:
>>>>>> Dear all,
>>>>>> I have a specific use case with regards the django-notification used
>>>>>> in GeoNode. The requirements are to only send a layer_created notice to
>>>>>> specific group managers. The group managers will then review and publish
>>>>>> the uploaded layer. I put a call to notification.send(managers,
>>>>>> 'layer_created', notif_ctx) after a new layer object is saved, which then
>>>>>> sends the layer_created email to the managers. However they receive 2
>>>>>> layer_created emails. I suppose the first one is from my manual call and
>>>>>> the second one is because the managers are subscribed to layer_created in
>>>>>> the notification settings. I then uncheck the setting and tried uploading
>>>>>> another layer expecting to receive only 1 email this time, however none was
>>>>>> received. I enabled the settings again and 2 emails were delivered. I find
>>>>>> it strange that the saved settings would also affect my manual call.
>>>>>> So my question is where in GeoNode's code can I look to disable
>>>>>> sending the 2nd email?
>>>>>> Thanks,
>>>>>> SN
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150924/c1ff398a/attachment.html>
More information about the geonode-users mailing list
