[GeoNode-users] error on saving maps
Eugenio Trumpy frippe12573 at hotmail.com
Tue Sep 29 01:35:52 PDT 2015
settings.py has 0755 premisses, the user and group belonging to is www-data
Is that correct?
E.
Date: Tue, 29 Sep 2015 10:20:26 +0200
Subject: Re: error on saving maps
To: frippe12573 at hotmail.com
CC: geonode-users at lists.osgeo.org
The error is that GeoNode can't read this list https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L605, properly.It may depend of an incorrect settings import.
2015-09-29 10:17 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi Simone,
actually I didn't modify such file and/or MAP_BASELAYER.
What do you mean, saying settings are not imported correctly?
E.
Date: Tue, 29 Sep 2015 10:10:15 +0200
Eugenio, perhaps you modified the MAP_BASELAYERS from the settings?https://github.com/GeoNode/geonode/blob/master/geonode/utils.py#L266 or the settings are not imported correctly
2015-09-29 10:00 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Dear all,
I just solved my problems on geoserver version provided by geonode.
Now a new problem appears on saving maps.
I have no errors on creating a map, when I save a new map I got an error,
The server returned an error: 500 Internal Server Error
so my apache2 error log havs:
[Tue Sep 29 09:47:45 2015] [error] [client x.x.x.x] Premature end of script headers: wsgi.py, referer: http://my_server_name/maps/new
[Tue Sep 29 09:47:45 2015] [notice] child pid 15764 exit signal Segmentation fault (11)
Actually on maps page of geonode I see the new map, without title and thumbnail.
If I click to view such map a page error appears:
IndexError at /maps/89
  list index out of range
      Request Method:
      GET
      Request URL:
      http://my_server_name/maps/89
      Django Version:
      1.6.10
      Exception Type:
      IndexError
      Exception Value:
      Exception Location:
      /dati/geonode/geonode/utils.py in viewer_json, line 266
      Python Executable:
      /usr/bin/python
      Python Version:
      2.7.3
      Python Path:
      ['/dati/.venvs/geonode/lib/python2.7/site-packages',
 '/usr/local/lib/python2.7/dist-packages/virtualenv-1.8.4-py2.7.egg',
 '/usr/local/lib/python2.7/dist-packages/pip-1.2.1-py2.7.egg',
 '/dati/geonode',
 '/usr/lib/python2.7',
 '/usr/lib/python2.7/plat-linux2',
 '/usr/lib/python2.7/lib-tk',
 '/usr/lib/python2.7/lib-old',
 '/usr/lib/python2.7/lib-dynload',
 '/usr/local/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages/PIL',
 '/usr/lib/pymodules/python2.7',
 '/var/www']
      Server time:
      Tue, 29 Sep 2015 09:59:48 +0200
Any hints on this issue?
Regards
Eugenio
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/32ace13a/attachment.html>
More information about the geonode-users mailing list
