[GeoNode-users] post-installation issues
Eugenio Trumpy frippe12573 at hotmail.com
Tue Sep 29 07:37:08 PDT 2015
Dear all,
I completed the installation of geonode vs 2.4.dev20150908094256,
I even solved the problem on geoserver and it seems to run well.
I set a geoserver from my organization as external service and
I'm able to see the layers available. I can see the map of the layer
and I can use them to prepare maps.
I tried also to upload a document, and even this function runs well.
My main problem is on map saving, this operation gives me the 500 internal server error.
By the way the map appears on the list of maps.
Checking the db (postgres) I see in the maps table the new record,
however from the map's list I cannot visualize such map, and a new error page
with yellow narrow appears. This page contains many statements, these three lines
give an hint on the possible problem:
Exception Type:
      IndexError
      Exception Value:
      list index out of range
      Exception Location:
      /dati/geonode/geonode/utils.py in viewer_json, line 266
This is my first issue, I got a suggestion (here in the mailing list) to debug by python
console geonode, but unfortunately I don't know how to start.
Suggestions?
Another question, might be related to the previous problem, is on geoserver authentication:
I didn't give any password during the installation, and in local_setting.py and setting.py
I see that geoserver has the classical administrator credentials (admin,geoserver).
However if I use the link to geoserver from the user context menu (in the geonode website)
I see the geoserver home page already logged in, but the user logged is not admin,
but the superuser of django. Is that right? Have I set th geoserver credential somewhere?
Thanks for now,
best regards
Eugenio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/5c413a45/attachment.html>
More information about the geonode-users mailing list
