[GeoNode-users] Permissions on GeoNode deployment
Simone Dalmasso simone.dalmasso at gmail.com
Tue Sep 29 23:10:08 PDT 2015
Hi Melvin, there may be more than one errors here:
- first seems that you did not set the SITE_URL properly in the settings as
the client is requesting the static content over localhost:8000 so maybe
you have also to turn odd DEBUG and do a collectstatic (check also the
settings for static_root and apache ownership there).
- second geoserver may be unable to access GeoNode for authentication
purposes because is looking for it on port 8000, for this you should refer
to the docs here
http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install
hope this helps
2015-09-29 23:51 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
> Hello community,
> I made a deployment of GeoNode (using the GitHub way, meaning the version
> is 2.4bSomething) in a VPS server, and at first I had trouble because I
> couldn't upload files. I changed the ownership of the uploaded folder from
> root to www-data to fix this.
> Although everything works fine regarding the uploading, once uploaded the
> file, the system can't show the layers in the map viewer (both the layer
> detail and the viewer alone), and also if you set up the thumbnail, it
> creates the thumb file, but it doesn't show it. It gives this error:
> Failed to load resource: net::ERR_NETWORK_ACCESS_DENIED
> http://localhost:8000/uploaded/thumbs/layer-1886cbce-4162-11e5-92a1-f23c91e4f95f-thumb.png
> Any ideas what I am missing?
> Thanks in advance
> Melvin David Ramos Macías
> 07-41408
> Ingeniería de Computación
> Universidad Simón Bolívar
> Enviado con MailTrack
> <https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150930/0ab93a86/attachment.html>
More information about the geonode-users mailing list
