[GeoNode-users] Install Geoserver from WAR (running on Tomcat)
Simone Dalmasso simone.dalmasso at gmail.com
Tue Apr 5 01:39:26 PDT 2016
Hi Jorge,
you can take the downloaded war and drop into the desired server. The you
have to correct the OGC_SERVER location, in your settings, to point to the
external geoserver address and tell geoserver where geonode is in
date/security/auth/geonodeAuthProvider/config.xml (by default is localhost)
A standard geoserver is also supported at the price of loosing the
permissions system.
Hope this helps
2016-04-05 9:30 GMT+02:00 Jorge de Jesus <jorge.jesus at gmail.com>:
> Hi to all
> I was wondering how to make a geoserver install (mainly WAR file drop) in
> another server instead of the one running geonode.
>  I see that paver downloads geoserver and makes the complete install with
> all the libs/requirements necessary for genode integration. Is there
> documentation on how this can be done manually and/or the requirements for
> a geoserver compatible with geonode
> Thank you
> Jorge de Jesus
> OpenPGP Key: 0x7212572C
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160405/cf80af4a/attachment.html>
More information about the geonode-users mailing list
