[GeoNode-users] opening up client side of geonode server on ubuntu error
Levi Westerveld levi.westerveld at gmail.com
Fri Apr 8 06:14:31 PDT 2016
The file in questions is attached to this email.
Thank you,
Levi
On Fri, Apr 8, 2016 at 3:07 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, what error do you get on /var/logs/apache2/error.log?
> 2016-04-08 14:47 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>> Hello,
>> We just recently managed to transfer our data from 2.0 to 2.4, but after
>> trying to open up our server so that it can be accessed through a normal
>> web browser online, we are getting an Internal Server Error. (
>> http://opengeo.grida.no/) Is there a tutorial out there on the steps to
>> take to set the server so that it can be accessed in a web browser?
>> When the geonode was running internally, we could also not access the
>> geoserver (each time I would get a tomcat7 error message). Is the geoserver
>> something that should be installed independently from the geonode in the
>> terminal? Perhaps that is the source of the initial issue?
>> Many thanks,
>> Levi
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Levi Westerveld
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160408/237911ff/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160408/237911ff/attachment-0001.obj>
More information about the geonode-users mailing list
