[GeoNode-users] opening up client side of geonode server on ubuntu error
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 8 06:25:05 PDT 2016
Not very clear from the log. But something went wrong with the migration I
guess. Do you layer tables in the db have a column named 'id'?
2016-04-08 15:14 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
> Hi,
> The file in questions is attached to this email.
> Thank you,
> Levi
> On Fri, Apr 8, 2016 at 3:07 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Hi, what error do you get on /var/logs/apache2/error.log?
>> 2016-04-08 14:47 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>> Hello,
>>> We just recently managed to transfer our data from 2.0 to 2.4, but after
>>> trying to open up our server so that it can be accessed through a normal
>>> web browser online, we are getting an Internal Server Error. (
>>> http://opengeo.grida.no/) Is there a tutorial out there on the steps to
>>> take to set the server so that it can be accessed in a web browser?
>>> When the geonode was running internally, we could also not access the
>>> geoserver (each time I would get a tomcat7 error message). Is the geoserver
>>> something that should be installed independently from the geonode in the
>>> terminal? Perhaps that is the source of the initial issue?
>>> Many thanks,
>>> Levi
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Levi Westerveld
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160408/78d8d742/attachment.html>
More information about the geonode-users mailing list
