[GeoNode-users] opening up client side of geonode server on ubuntu error
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 8 06:32:34 PDT 2016
In your database, with pgAdmin or psql.
2016-04-08 15:31 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
> hmmm, where should I look for those?
> On Fri, Apr 8, 2016 at 3:25 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Not very clear from the log. But something went wrong with the migration
>> I guess. Do you layer tables in the db have a column named 'id'?
>> 2016-04-08 15:14 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>> Hi,
>>> The file in questions is attached to this email.
>>> Thank you,
>>> Levi
>>> On Fri, Apr 8, 2016 at 3:07 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi, what error do you get on /var/logs/apache2/error.log?
>>>> 2016-04-08 14:47 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>>>> Hello,
>>>>> We just recently managed to transfer our data from 2.0 to 2.4, but
>>>>> after trying to open up our server so that it can be accessed through a
>>>>> normal web browser online, we are getting an Internal Server Error. (
>>>>> http://opengeo.grida.no/) Is there a tutorial out there on the steps
>>>>> to take to set the server so that it can be accessed in a web browser?
>>>>> When the geonode was running internally, we could also not access the
>>>>> geoserver (each time I would get a tomcat7 error message). Is the geoserver
>>>>> something that should be installed independently from the geonode in the
>>>>> terminal? Perhaps that is the source of the initial issue?
>>>>> Many thanks,
>>>>> Levi
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Levi Westerveld
>> Simone
> Levi Westerveld
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160408/04ad4cfc/attachment-0001.html>
More information about the geonode-users mailing list
