[GeoNode-users] geonode importlayers error when metadata XML is present
Daniel Victoria daniel.victoria at gmail.com
Tue Apr 12 18:40:20 PDT 2016
Thanks Tom, I just opened an issue[1].
Now, getting back to my problem of getting the metadata from one GeoNode
server to another. What would be the best option? I tried downloading the
XML and putting it along with the shapefile since I'd rather not have to
fill 100+ metadata records by hand.
What about the migration scripts from afabiani. Will that move both the
data (vector data in postgis or imagens in GeoServer) along with the
metadata?
Cheers
Daniel
[1] https://github.com/GeoNode/geonode/issues/2469
On Tue, Apr 12, 2016 at 5:27 PM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> On Tue, Apr 12, 2016 at 12:39 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
> > Hi all,
> > I'm trying to populate a new geonode instance (v2.4) with some shapefiles
> > from another geonode (v2.4).
> > I have all the shapefiles in a directory so I'm inclined to use the
> > importlayers command. And to make things easier, I've downloaded the
> > metadata (ISO format, XML file) from the former geonode and placed it
> with
> > the shapefiles that will be imported.
> > The importlayers command fails with the following message
> > ./par_a01_2013_inventoryplotsubplot.shp
> > Traceback (most recent call last):
> >   File "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py",
> > line 588, in upload
> >     title=title
> > line 429, in file_upload
> >     vals, regions, keywords = set_metadata(xml_file.read())
> >   File
> "/usr/local/lib/python2.7/dist-packages/geonode/layers/metadata.py",
> > line 62, in set_metadata
> >     vals, regions, keywords = dc2dict(exml)
> >   File
> > line 198, in dc2dict
> >     vals['date'] = sniff_date(mdata.modified)
> >   File
> > line 222, in sniff_date
> >     return datetime.datetime.strptime(datestr.strip(), dfmt)
> > AttributeError: 'NoneType' object has no attribute 'strip'
> > If I remove the XML file from the shapefile directory, the importlayers
> > command works OK.
> > Any idea what is wrong? Attached is the offending metadata file, just in
> > case.
> > Cheers
> > Daniel
> Daniel: looks like missing metadata.  Having said this, we should have a
> more
> graceful error.  If you can open a GitHub issue [1], I will fix.
> Thanks
> ..Tom
> [1] https://github.com/GeoNode/geonode/issues/new
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160412/b598422b/attachment.html>
More information about the geonode-users mailing list
