[GeoNode-users] geonode importlayers error when metadata XML is present
Daniel Victoria daniel.victoria at gmail.com
Wed Apr 13 11:43:34 PDT 2016
Hi Tom et al.,
I saw that you closed the issue. Great. Two questions though
1) Was the problem related to how the metadata was produced (incomplete)?
Or related to geonode not accepting incomplete data?
2) I'm a newbie when it comes to updating GeoNode. I have it installed from
the ppa repositories. How can I apply the patch you just comited? Should I
just convert the GeoNode install folder from my machine into a git
repository and pull from Github? Are there any tutorials on how to do that?
Thanks
Daniel
On Tue, Apr 12, 2016 at 10:40 PM, Daniel Victoria <daniel.victoria at gmail.com
> wrote:
> Thanks Tom, I just opened an issue[1].
> Now, getting back to my problem of getting the metadata from one GeoNode
> server to another. What would be the best option? I tried downloading the
> XML and putting it along with the shapefile since I'd rather not have to
> fill 100+ metadata records by hand.
> What about the migration scripts from afabiani. Will that move both the
> data (vector data in postgis or imagens in GeoServer) along with the
> metadata?
> Cheers
> Daniel
> [1] https://github.com/GeoNode/geonode/issues/2469
> On Tue, Apr 12, 2016 at 5:27 PM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
>> On Tue, Apr 12, 2016 at 12:39 PM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>> > Hi all,
>> > I'm trying to populate a new geonode instance (v2.4) with some
>> shapefiles
>> > from another geonode (v2.4).
>> > I have all the shapefiles in a directory so I'm inclined to use the
>> > importlayers command. And to make things easier, I've downloaded the
>> > metadata (ISO format, XML file) from the former geonode and placed it
>> with
>> > the shapefiles that will be imported.
>> > The importlayers command fails with the following message
>> > ./par_a01_2013_inventoryplotsubplot.shp
>> > Traceback (most recent call last):
>> >   File "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py",
>> > line 588, in upload
>> >     title=title
>> > line 429, in file_upload
>> >     vals, regions, keywords = set_metadata(xml_file.read())
>> >   File
>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/metadata.py",
>> > line 62, in set_metadata
>> >     vals, regions, keywords = dc2dict(exml)
>> >   File
>> > line 198, in dc2dict
>> >     vals['date'] = sniff_date(mdata.modified)
>> >   File
>> > line 222, in sniff_date
>> >     return datetime.datetime.strptime(datestr.strip(), dfmt)
>> > AttributeError: 'NoneType' object has no attribute 'strip'
>> > If I remove the XML file from the shapefile directory, the importlayers
>> > command works OK.
>> > Any idea what is wrong? Attached is the offending metadata file, just in
>> > case.
>> > Cheers
>> > Daniel
>> Daniel: looks like missing metadata.  Having said this, we should have a
>> more
>> graceful error.  If you can open a GitHub issue [1], I will fix.
>> Thanks
>> ..Tom
>> [1] https://github.com/GeoNode/geonode/issues/new
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160413/00d56f23/attachment.html>
More information about the geonode-users mailing list
