[GeoNode-users] failed migration from 2.0 to 2.4
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 15 00:14:53 PDT 2016
Levi,
that is definitely not a good error but can be solved. Linux puts the file
system in read only mode when there are inconsistencies on the disk.I
suggest you to google for that error, you will find tons of suggestions on
how to check and fix the disk errors.
2016-04-14 22:36 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
> Hello Paolo and Simone,
> We just ran the script again and we got a new error message in the
> terminal. Have you seen this before? Is it maybe because we had already ran
> the scripts at an earlier stage? Thank you for your help!
> Levi
> Traceback (most recent call last):
>   File
> "/home/administrator/geonode-migration_from20_to_24/migrate_contactroles.py",
> line 4, in <module>
>     src = utils.get_src()
>   File "/home/administrator/geonode-migration_from20_to_24/utils.py", line
> 21, in get_src
>     "dbname='%s' user='%s' port='5432' host='%s' password='%s'" %
> (gn20_dbname, gn20_user, gn20_host, gn20_password)
>   File "/usr/lib/python2.7/dist-packages/psycopg2/__init__.py", line 179,
> in connect
>     connection_factory=connection_factory, async=async)
> psycopg2.OperationalError: FATAL:  could not open file "base/16384/11757":
> Read-only file system
> On Mon, Apr 11, 2016 at 4:52 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Looks like the migrations scripts didn't run successfully.
>> Levi, could you re-run the process and provide the full log of the
>> migration scripts?
>> Also, make sure to read comments here:
>> https://github.com/GeoNode/geonode/issues/2067
>> thanks
>> p
>> On Mon, Apr 11, 2016 at 8:03 AM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>> > The issue seems to be originating here
>> https://github.com/GeoNode/geonode/blob/master/geonode/base/templatetags/base_tags.py#L54
>> > And the final error is: ValueError: invalid literal for int() with base
>> 10:
>> > 'None'
>> >  @capooti any hints?
>> > 2016-04-11 13:59 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>> >> Hello,
>> >> We recently moved our data from a 2.0 geonode server
>> >> (http://geonode.grida.no/) to a new server with geonode 2.4
>> >> (http://opengeo.grida.no/). geonode 2.4 was successfully installed
>> before we
>> >> ran the migration using the scripts provided here:
>> https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24
>> >> After running the two migration scripts, users, layers, and maps data
>> were
>> >> transferred successfully, but each time I clicked on a layer nothing
>> would
>> >> happen. When we tried to access the geoserver after logging in we also
>> >> received an error message.
>> >> Now we have an Internal Server Error after we tried to open up to the
>> >> client side so that the server could be accessed externally from a
>> browser.
>> >> The error log file from /var/logs/apache2/error.log is attached to this
>> >> email.
>> >> perhaps someone here has an idea on what is the best way forward?
>> >> Many thanks for the help,
>> >> Levi
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> > Simone
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Levi Westerveld
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160415/db5e7632/attachment.html>
More information about the geonode-users mailing list
