[GeoNode-users] GeoServer crashes at restart
David Alda Fernandez de Lezea dalda at hazi.eus
Mon Apr 18 06:26:05 PDT 2016
Hi list,
I had my geonode installation working like a charm until this morning  when I realized that the GeoServer part is not working anymore I needed to restart tomcat ad after that GeoServer didn't work. From the web page I get 404 error but digging into the logs I've seen the following:
2016-04-18 15:11:28,923 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in '/home/u0899dal/gwc'
2016-04-18 15:11:29,162 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2016-04-18 15:11:29,816 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
2016-04-18 15:11:29,816 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /usr/share/geoserver/data/gwc-layers
2016-04-18 15:11:29,831 INFO [gwc.layer] - Loading tile layers from /usr/share/geoserver/data/gwc-layers
2016-04-18 15:11:30,938 INFO [gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
2016-04-18 15:11:30,961 INFO [config.XMLConfiguration] - Found configuration file in /home/u0899dal/gwc
2016-04-18 15:11:31,060 INFO [config.XMLConfiguration] - Configuration file validated fine.
2016-04-18 15:11:31,070 INFO [config.XMLConfiguration] - Initializing GridSets from /home/u0899dal/gwc
2016-04-18 15:11:31,070 INFO [config.XMLConfiguration] - Read GridSet EPSG:3857
2016-04-18 15:11:31,071 INFO [config.XMLConfiguration] - Initializing layers from /home/u0899dal/gwc
2016-04-18 15:11:31,071 INFO [layer.TileLayerDispatcher] - Configuration /home/u0899dal/gwc contained no layers.
2016-04-18 15:11:31,118 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /home/u0899dal/gwc/geowebcache-diskquota.xml
2016-04-18 15:11:31,130 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /home/u0899dal/gwc/geowebcache-diskquota.xml
2016-04-18 15:11:31,131 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2016-04-18 15:11:31,131 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2016-04-18 15:11:31,133 INFO [diskquota.DiskQuotaMonitor] - 300 layers attached to global quota 500,0 MB
2016-04-18 15:11:31,357 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2016-04-18 15:11:33,636 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks...
2016-04-18 15:11:33,637 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2016-04-18 15:11:33,637 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2016-04-18 15:11:33,659 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'geoGigGeoServerLifeCycleListener': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2016-04-18 15:11:33,660 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcFacade' defined in URL [jar:file:/usr/share/geoserver/WEB-INF/lib/gs-gwc-2.7.4.jar!/applicationContext.xml]: Cannot resolve reference to bean 'DiskQuotaMonitor' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaMonitor' defined in URL [jar:file:/usr/share/geoserver/WEB-INF/lib/gs-gwc-2.7.4.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Could not locate a layer or layer group with id LayerInfoImpl--49aab484:153849293ea:7199 within GeoServer configuration, the GWC configuration seems to be out of synch
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
	at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
	at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
	at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
	at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
	at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:670)
	at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1839)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
	at java.util.concurrent.FutureTask.run(FutureTask.java:262)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'DiskQuotaMonitor' defined in URL [jar:file:/usr/share/geoserver/WEB-INF/lib/gs-gwc-2.7.4.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is java.lang.IllegalStateException: Could not locate a layer or layer group with id LayerInfoImpl--49aab484:153849293ea:7199 within GeoServer configuration, the GWC configuration seems to be out of synch
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
	... 31 more
Caused by: java.lang.IllegalStateException: Could not locate a layer or layer group with id LayerInfoImpl--49aab484:153849293ea:7199 within GeoServer configuration, the GWC configuration seems to be out of synch
	at org.geoserver.gwc.layer.GeoServerTileLayer.getPublishedInfo(GeoServerTileLayer.java:308)
	at org.geoserver.gwc.layer.GeoServerTileLayer.getLayerInfo(GeoServerTileLayer.java:287)
	at org.geoserver.gwc.layer.GeoServerTileLayer.getLatLonBbox(GeoServerTileLayer.java:251)
	at org.geoserver.gwc.layer.GeoServerTileLayer.checkGridSubsets(GeoServerTileLayer.java:777)
	at org.geoserver.gwc.layer.GeoServerTileLayer.getGridSubsets(GeoServerTileLayer.java:765)
	at org.geowebcache.diskquota.LayerCacheInfoBuilder.findOnDiskTileSets(LayerCacheInfoBuilder.java:148)
	at org.geowebcache.diskquota.LayerCacheInfoBuilder.buildCacheInfo(LayerCacheInfoBuilder.java:110)
	at org.geowebcache.diskquota.DiskQuotaMonitor.launchCacheInfoGatheringThreads(DiskQuotaMonitor.java:413)
	at org.geowebcache.diskquota.DiskQuotaMonitor.startUpInternal(DiskQuotaMonitor.java:272)
	at org.geowebcache.diskquota.DiskQuotaMonitor.startUp(DiskQuotaMonitor.java:231)
	at org.geowebcache.diskquota.DiskQuotaMonitor.afterPropertiesSet(DiskQuotaMonitor.java:188)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452)
	... 38 more
I tried restarting the server but without success...
I have GWC configured to a different directory than default, but it has been working for the last 3 weeks (at least) perfectly.
Any ideas??
Thanks in advance.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
More information about the geonode-users mailing list
