[GeoNode-users] Geoserver data directory lost
Paolo Corti pcorti at gmail.com
Mon Apr 18 07:43:56 PDT 2016
I would add that also SLD files are synced with the GeoNode database,
so in case you need to restore styles you should be able to do it.
p
On Thu, Apr 14, 2016 at 1:46 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> hi Israel,
> you probably cannot recover geoserver but somehow rebuild it, as all the
> vector layers are in the db you can connect back a fresh geoserver manually
> creating the store. For raster data check if you have a copy in var www
> geonode uploaded layer, and you can re upload them.
> hope it helps
> 2016-04-14 4:37 GMT+02:00 Israel López <asralf at gmail.com>:
>> Hi devs, well I'm in trouble... Accidentally delete the directory
>> geoserver
>> at tomcat7 webapps,.. In fact, It was deleted the geoserver.war and then
>> the geoserver directory.
>> Do you know some way to recover my geoserver???
>> The databases are ok
>> I would appreciate any ideas, thanks.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
