[GeoNode-users] failed migration from 2.0 to 2.4
Paolo Corti pcorti at gmail.com
Tue Apr 19 06:03:34 PDT 2016
Hi
this won't help, you will loose all the style, metadata, tags,
permissions doing so.
Checking your logs, first script ran successfully.
You have a problem at the beginning of the second script: before
running it make sure that GeoServer is communicating correctly with
GeoNode: you should be able to see the layers in the GeoServer
preview, for example.
The fact that links are broken, this is expected, as updating layers
failed at the beginning of the second script.
You are exactly in the same problem as a couple of users here (they
managed to fix it): https://github.com/GeoNode/geonode/issues/2067
Hope it helps
p
On Tue, Apr 19, 2016 at 7:31 AM, Levi Westerveld
<levi.westerveld at gmail.com> wrote:
> As a follow up to this email.
> It appears that for the second error none of the GIS data was actually
> migrated but just a description of the layers was. We will now try to import
> the layers that did not migrate using the sudo geonode importalyers
> <dat_dir> to the new geonode and I just hope that the imported layers will
> link back with the descriptive data that was imported for each layer.
> The first issue remains unresolved..
> Thank you,
> levi
> On Tue, Apr 19, 2016 at 12:48 PM, Levi Westerveld
>> Dear Simone and Paolo,
>> We have reinstalled ubuntu and ran the migration files successfully again
>> from our geonode 2.0 server to our geonode 2.4 instance.
>> We have two issues
>> 1. we are able to access the geonode 2.4 if we are signed in as a user at
>> http://opengeo.grida.no/ but if not signed in then an internal server issues
>> shows up
>> 2. when we are in the layers section and click on a layer it seems that
>> the link is broken, and we are not redirected to that layer, but stay on the
>> same page
>> I attached the two log files for the migration.
>> Thank you!
>> Levi
>> On Fri, Apr 15, 2016 at 9:14 AM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>>> Levi,
>>> that is definitely not a good error but can be solved. Linux puts the
>>> file system in read only mode when there are inconsistencies on the disk.I
>>> suggest you to google for that error, you will find tons of suggestions on
>>> how to check and fix the disk errors.
>>> 2016-04-14 22:36 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>>>> Hello Paolo and Simone,
>>>> We just ran the script again and we got a new error message in the
>>>> terminal. Have you seen this before? Is it maybe because we had already ran
>>>> the scripts at an earlier stage? Thank you for your help!
>>>> Levi
>>>> Traceback (most recent call last):
>>>>   File
>>>> "/home/administrator/geonode-migration_from20_to_24/migrate_contactroles.py",
>>>> line 4, in <module>
>>>>     src = utils.get_src()
>>>>   File "/home/administrator/geonode-migration_from20_to_24/utils.py",
>>>> line 21, in get_src
>>>>     "dbname='%s' user='%s' port='5432' host='%s' password='%s'" %
>>>> (gn20_dbname, gn20_user, gn20_host, gn20_password)
>>>>   File "/usr/lib/python2.7/dist-packages/psycopg2/__init__.py", line
>>>> 179, in connect
>>>>     connection_factory=connection_factory, async=async)
>>>> psycopg2.OperationalError: FATAL:  could not open file
>>>> "base/16384/11757": Read-only file system
>>>> On Mon, Apr 11, 2016 at 4:52 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>> Looks like the migrations scripts didn't run successfully.
>>>>> Levi, could you re-run the process and provide the full log of the
>>>>> migration scripts?
>>>>> Also, make sure to read comments here:
>>>>> thanks
>>>>> p
>>>>> On Mon, Apr 11, 2016 at 8:03 AM, Simone Dalmasso
>>>>> > The issue seems to be originating here
>>>>> > https://github.com/GeoNode/geonode/blob/master/geonode/base/templatetags/base_tags.py#L54.
>>>>> > And the final error is: ValueError: invalid literal for int() with
>>>>> > base 10:
>>>>> > 'None'
>>>>> >  @capooti any hints?
>>>>> > 2016-04-11 13:59 GMT+02:00 Levi Westerveld
>>>>> >> Hello,
>>>>> >> We recently moved our data from a 2.0 geonode server
>>>>> >> (http://geonode.grida.no/) to a new server with geonode 2.4
>>>>> >> (http://opengeo.grida.no/). geonode 2.4 was successfully installed
>>>>> >> before we
>>>>> >> ran the migration using the scripts provided here:
>>>>> >> https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24.
>>>>> >> After running the two migration scripts, users, layers, and maps
>>>>> >> data were
>>>>> >> transferred successfully, but each time I clicked on a layer nothing
>>>>> >> would
>>>>> >> happen. When we tried to access the geoserver after logging in we
>>>>> >> also
>>>>> >> received an error message.
>>>>> >> Now we have an Internal Server Error after we tried to open up to
>>>>> >> the
>>>>> >> client side so that the server could be accessed externally from a
>>>>> >> browser.
>>>>> >> The error log file from /var/logs/apache2/error.log is attached to
>>>>> >> this
>>>>> >> email.
>>>>> >> perhaps someone here has an idea on what is the best way forward?
>>>>> >> Many thanks for the help,
>>>>> >> Levi
>>>>> >> _______________________________________________
>>>>> >> geonode-users mailing list
>>>>> >> geonode-users at lists.osgeo.org
>>>>> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> > Simone
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>> Levi Westerveld
>>> Simone
>> Levi Westerveld
> Levi Westerveld
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
