[GeoNode-users] Geoserver data directory lost
Israel López asralf at gmail.com
Tue Apr 19 13:20:12 PDT 2016
Thanks a lot Paolo, I had not noticed that.
El abr. 19, 2016 14:51, "Paolo Corti" <pcorti at gmail.com> escribió:
> You can recover all of the lost SLD from the layers_styles table in
> the database.
> For each layer in the layers_layer table you can find all of the associated
> SLD styles, in the layers_styles table (sld_text
> field). For each layer you can detect the default style from the
> default_style field in the layers_layer table.
> Basically you will need to create an sld for each of that styles in
> GeoServer and associate the default one to the GeoServer layer.
> You could use the gsconfig library to accomplish this task, or the
> GeoServer REST API directly.
> Or by hand (sigh)
> p
> On Tue, Apr 19, 2016 at 2:14 PM, Israel López <asralf at gmail.com> wrote:
> > Could you tell me how to do it Paolo?? Because I had to remade it one by
> one
> > again...
> > El abr. 18, 2016 9:44, "Paolo Corti" <pcorti at gmail.com> escribió:
> >> I would add that also SLD files are synced with the GeoNode database,
> >> so in case you need to restore styles you should be able to do it.
> >> p
> >> On Thu, Apr 14, 2016 at 1:46 AM, Simone Dalmasso
> >> <simone.dalmasso at gmail.com> wrote:
> >> > hi Israel,
> >> > you probably cannot recover geoserver but somehow rebuild it, as all
> the
> >> > vector layers are in the db you can connect back a fresh geoserver
> >> > manually
> >> > creating the store. For raster data check if you have a copy in var
> www
> >> > geonode uploaded layer, and you can re upload them.
> >> > hope it helps
> >> > 2016-04-14 4:37 GMT+02:00 Israel López <asralf at gmail.com>:
> >> >> Hi devs, well I'm in trouble... Accidentally delete the directory
> >> >> geoserver
> >> >> at tomcat7 webapps,.. In fact, It was deleted the geoserver.war and
> >> >> then
> >> >> the geoserver directory.
> >> >> Do you know some way to recover my geoserver???
> >> >> The databases are ok
> >> >> I would appreciate any ideas, thanks.
> >> >> _______________________________________________
> >> >> geonode-users mailing list
> >> >> geonode-users at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
> >> > Simone
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160419/b8ac56a8/attachment.html>
More information about the geonode-users mailing list
