[GeoNode-users] Windows Installer Error
Carlo Di Michele carlo.dimichele at gmail.com
Fri Apr 22 07:30:52 PDT 2016
Hello and thanks for your fast support.
The system is not a clean system.
I have yet installed other python's version.
Note: I've installed everything without the Antivirus Avira because detect
a troian (Dropper.gen) in the postgis-pg84-setup-1.5.4-2.exe
After the installation this is the situation:
JVM I don't see any service active. Postgre service there is postgresql-8.4
running.
I see Apache 2 service that doesn't starts (see the note below).
I don't see Tomcat 7 service.
About the GeoNode folder I see:
- Apache2  where the logs contains the install.log where there are no errors
- Apache Tomcat 7 where the logs is empty
- data
- Gdal
- Geonode-2.4x
- postgres
- python27
Note: in the environment variables system the JRE_HOME path was
C:\Geonode-2.4x\jre but there is no jre folder there created!!! I did a
test: I've change the JRE_HOME to the right path (under Java Folder) and it
starts. Seems that the installation fails to create jre subfolder in the
C:\Geonode-2.4x folder
No other environmental Variables has been created as indicated in the
Windows Installer user guide.
The only icon created are:
- Geonode that points to http://localhost ...... nothing opens
- GeoNode VirtualEnv Setup that points to
C:\Geonode-2.4x\Geonode-2.4x\virtualenv_setup.bat that doesn't exist.
- Uninstall
Hope these hints helps.
Regards
Carlo
2016-04-22 9:25 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Dear Carlo,
> can you describe a bit your Windows 10 conifguration?
> Do you have Python, JVM and/or PostgreSQL services already installed
> there? Or did you started with a fully clean system?
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
>> On Thu, Apr 21, 2016 at 9:56 AM, Carlo Di Michele
>> <carlo.dimichele at gmail.com> wrote:
>> > Hello to everybody,
>> > I'm trying to install Geonode in my laptop Windows 10 64bit.
>> > I've followed the default installation parameters except the port 8086
>> > instead of 8080.
>> > Apache Tomcat 7 folder exist but the Service of tomcat 7 is not present.
>> > Apache 2 is present in the Windows Service but I can't start.
>> > I've installed/uninstalled many times with the same result.
>> > Thanks for any help
>> > Carlo
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160422/2fcdfbae/attachment.html>
More information about the geonode-users mailing list
