[GeoNode-users] Change SITE_URL of GeoNode 2.4 installation
Simone Dalmasso simone.dalmasso at gmail.com
Sat Apr 30 10:24:21 PDT 2016
have you used the command "$ sudo geonode-updateip yourdomain" ti change
it? It should take care of everything for you, if is not doing that then we
might have a bug :)
Ciao
2016-04-30 18:55 GMT+02:00 Israel López <asralf at gmail.com>:
> Yes, in fact, maybe you cannot see  thumbs and download the resources too,
> in the case of the legend, you should modify the global setting in
> geoserver, and for the database I'm not sure if there is a tool but I've
> modified by hand the tables resourcebase and links.
> The experts could give you more info.
> Hello everyone :-) I'm having a issue with GeoNode, tried to google around
> for a solition but not able to find one.
> Basically I need to change the SITE_URL of my installation (GeoNode2.4),
> the problem is that after changing his setting the legend of the layers
> disappers, the legend image still points to the old URL despite having
> restarted apache and tomcat and having cleared the geoserver cache.
> Have you got any suggestion to fix the proble? Maybe GeoNode stores the
> links or the address of the server somewhere in the DB?
> Thanks in advance
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160430/519d6ec4/attachment.html>
More information about the geonode-users mailing list
