[GeoNode-users] Which Repo to use
Simone Dalmasso simone.dalmasso at gmail.com
Wed Aug 3 06:41:01 PDT 2016
We still have to decide where to put it. I'm not sure if it will be able to
do automatic migrations from 2.4 to 2.6. There are data model changes even
if not so many.
Il martedì 2 agosto 2016, Daniel Victoria <daniel.victoria at gmail.com> ha
scritto:
> Hi Simone,
> So as curiosity, the 2.6 release won't be compatible with the 2.4? Because
> if the repository name will change, that would be to avoid automatic
> update, correct?
> Thanks
> On Tue, Aug 2, 2016 at 5:16 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> wrote:
>> Hi, the latest is stable which holds the 2.4, while release is 2.0 this
>> was due to avoid automatic updates between incompatible versions of
>> Geonode.
>> A new ppa will be available on in autumn when we release the 2.6 but is
>> yet to be decided which name to use.
>> Regards
>> Il martedì 2 agosto 2016, Paul Grambauer <
>> Paul.Grambauer at sunshinecoast.qld.gov.au
>> <javascript:_e(%7B%7D,'cvml','Paul.Grambauer at sunshinecoast.qld.gov.au');>>
>> ha scritto:
>>> Hi,
>>> Just a quick question.  I know the docs say to use $ sudo
>>> add-apt-repository ppa:geonode/stable, but what is ppa:geonode/release.
>>> I was wondering which one is is the latest working version?  How often
>>> would it be re-packaged?
>>> Thanks,
>>> Paul Grambauer
>>> P 0448 117 316
>>> E paul.grambauer at sunshinecoast.qld.gov.au
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160803/542fd802/attachment.html>
More information about the geonode-users mailing list
