[GeoNode-users] google api policy
Paolo Corti pcorti at gmail.com
Fri Aug 5 14:15:58 PDT 2016
Wait, it is already there:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html#google
sorry for the noise
p
On Fri, Aug 5, 2016 at 11:12 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Thanks Giovani
> could you send a PR, including some documentation (must be added here:
> https://github.com/GeoNode/geonode/blob/master/docs/reference/developers/settings.txt)?
> thanks a lot
> p
> On Fri, Aug 5, 2016 at 9:41 PM, Giovani Fronza <giovanifronza at gmail.com> wrote:
>> I did it today, motivated by these toppics in the list.
>> I've put these code on my settings.py:
>> # A Google Maps API key is needed for the 3D Google Earth view of maps
>> # See http://code.google.com/apis/maps/signup.html
>> GOOGLE_API_KEY = '<your key rehe>'
>> try:
>>     GOOGLE_LAYER_SAT = {
>>         "source": {
>>             "ptype": "gxp_googlesource",
>>             "apiKey": GOOGLE_API_KEY
>>         "name": "SATELLITE",
>>         "fixed": True,
>>         "visibility": False,
>>         "group": "background"
>>     MAP_BASELAYERS.append(GOOGLE_LAYER_SAT)
>> except GoogleAPIError:
>>     print "Not enabling Google  Maps base layer as a GOOGLE_API_KEY is not
>> defined in settings.py file."
>> You could even change name "SATELLITE" by ROADMAP, HYBRID, or TERRAIN.
>> After changes, restart your apache to make efect.
>> 2016-08-05 15:14 GMT-03:00 Charles Cossé <ccosse at gmail.com>:
>>> Shouldn't it go in site_base.html?  as a Javascript include?
>>> -Charles
>>> On Aug 5, 2016 5:47 AM, "István Szőcs" <borohoro at gmail.com> wrote:
>>>> Hello !
>>>> Thank you for clearing that out. I have put the key in the file.
>>>> Do you know if there's a time frame until a new key becomes active ?
>>>> Because it's still not loading the google layers.
>>>> And I know that this is a geonode forum, please forgive me, but perhaps
>>>> somebody knows the same thing for an Opengeo Suite install (on Windows) ?
>>>> I couldn't find the file where to insert the key, of course
>>>> local_settings.py is not present over there.
>>>> So what would be the equivalent file in which to insert the key on an
>>>> Opengeo Suite installation ?
>>>> kind regards,
>>>>           István
>>>> On Thu, Aug 4, 2016 at 12:48 PM, Amedeo Fadini <amefad at gmail.com> wrote:
>>>>> Hello,
>>>>> Il 04/ago/2016 10:08 AM, "István Szőcs" <borohoro at gmail.com> ha scritto:
>>>>> > Hello !
>>>>> >  Can somebody please tell me where to insert this key, in which file
>>>>> > on the server ?
>>>>> Quite simple: in /etc/geonode/local_settings.py
>>>>> see also
>>>>> amedeo
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
