[GeoNode-users] google api policy
István Szőcs borohoro at gmail.com
Tue Aug 9 04:04:34 PDT 2016
I've filled the key over there too and then I tried uncommenting the line,
still no help.
I've signed up for a mapquest key also but I don't have luck with that
neither, still not recognizing the keys.
here's the updated local_settings.py:
https://drive.google.com/folderview?id=0B6xaw_lJzhEAMldNNjFaNVJDajQ&usp=sharing
And no, I'm not able to load the google layers using the "Add layer" in map
composer, no baselayer shows up.
István
On Tue, Aug 9, 2016 at 1:47 PM, Amedeo Fadini <amefad at gmail.com> wrote:
> 2016-08-09 12:04 GMT+02:00 István Szőcs <borohoro at gmail.com>:
> > Hello !
> > Thank you for the links. I believe I've done everything that says in the
> > documentation, also as Giovani pointed out but I still can't get it
> working.
> > I've tried with more API keys too.
> > Please have a look at my settings.py and local_settings.py over here:
> I see in lines 86-88
> # A Google Maps API key is needed for the 3D Google Earth view of maps
> # See http://code.google.com/apis/maps/signup.html
> GOOGLE_API_KEY = ''
> Altough the assignment in line 103 should overwrite it, please fill
> the variable on that line.
> Are you able to load the google layers using "Add layer.. " button on
> map composer?
> Amedeo
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160809/863767c3/attachment.html>
More information about the geonode-users mailing list
