[GeoNode-users] Geonode Windows 2.4
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Aug 23 01:09:29 PDT 2016
Hello Chris,
did you use the latest version of the installer available from the geonode
main site?
The behavior is quite strange, form the error logs it looks like there's a
syntax error into the settings.py file, but I really don't have an idea on
the reasons.
You can try to edit manually that file removing the wrong lines and restart
apache in order to see if that was the issue.
About the Apache Service, now all the environment variables needed are
located into the Windows Registry.
The latest version of the installer puts the required variables into the
registry and those are the only ones the Apache service will take into
account.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Aug 22, 2016 at 4:26 AM, Franklin, Chris <
CFranklin at anglogoldashanti.com> wrote:
> Hi,
> I have installed Geonode 2.4 on windows server 2012, I have Geoserver
> working, but I don’t have the GeoNode interface coming up. – I have set
> localhost to aupegis03 (local domain name)  also Tomcat also runs on
> localhost:8080 perfectly.
> I get this error:
> *Internal Server Error*
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator at webmaster at example.org to
> inform them of the time this error occurred, and the actions you performed
> just before this error.
> More information about this error may be available in the server error log
> [Mon Aug 22 10:15:38.161664 2016] [wsgi:error] [pid 1488:tid 2592] [client
> 172.16.0.110:58358] mod_wsgi (pid=1488): Exception occurred processing
> WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'.
> 172.16.0.110:58358] Traceback (most recent call last):
> 172.16.0.110:58358]   File "C:\\GeoNode-2.4.x\\geonode-2.
> 4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in
> __call__
> 172.16.0.110:58358]     self.load_middleware()
> 4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in
> load_middleware
> 172.16.0.110:58358]     for middleware_path in
> settings.MIDDLEWARE_CLASSES:
> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in
> __getattr__
> 172.16.0.110:58358]     self._setup(name)
> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup
> 172.16.0.110:58358]     self._wrapped = Settings(settings_module)
> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__
> 172.16.0.110:58358]     mod = importlib.import_module(self.
> SETTINGS_MODULE)
> 4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in
> import_module
> 172.16.0.110:58358]     __import__(name)
> 172.16.0.110:58358]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py",
> line 892
> 172.16.0.110:58358]     "apiKey": s1kpAAqIEjz86yRjlnlk~
> tPUN2J2Fvxzv14u6U8jpwQ~AsquDvAuq0pVg1VaXex4VFpz0V29SNsl_hpkv-P3_
> CPXMm0kE4zbMcpn5p7f8V45
> 172.16.0.110:58358]                                   ^
> 172.16.0.110:58358] SyntaxError: invalid syntax
> [Mon Aug 22 10:15:40.880423 2016] [mpm_winnt:notice] [pid 1056:tid 592]
> AH00422: Parent: Received shutdown signal -- Shutting down the server.
> [Mon Aug 22 10:15:42.911716 2016] [mpm_winnt:notice] [pid 1488:tid 492]
> AH00364: Child: All worker threads have exited.
> [Mon Aug 22 10:15:43.161678 2016] [mpm_winnt:notice] [pid 1056:tid 592]
> AH00430: Parent: Child process 1488 exited successfully.
> [Mon Aug 22 10:15:44.396046 2016] [core:warn] [pid 4224:tid 592] AH00117:
> Ignoring deprecated use of DefaultType in line 424 of
> C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
> [Mon Aug 22 10:15:44.411674 2016] [wsgi:warn] [pid 4224:tid 592] mod_wsgi:
> Compiled for Python/2.7.10+.
> Runtime using Python/2.7.10.
> [Mon Aug 22 10:15:44.411674 2016] [mpm_winnt:notice] [pid 4224:tid 592]
> AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured --
> resuming normal operations
> AH00456: Server built: Dec  9 2015 12:21:09
> [Mon Aug 22 10:15:44.411674 2016] [core:notice] [pid 4224:tid 592]
> AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d
> C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
> AH00418: Parent: Created child process 5092
> [Mon Aug 22 10:15:44.802298 2016] [core:warn] [pid 5092:tid 492] AH00117:
> [Mon Aug 22 10:15:44.833549 2016] [core:warn] [pid 5092:tid 492] AH00117:
> [Mon Aug 22 10:15:44.849174 2016] [wsgi:warn] [pid 5092:tid 492] mod_wsgi:
> [Mon Aug 22 10:15:45.161675 2016] [mpm_winnt:notice] [pid 5092:tid 492]
> AH00354: Child: Starting 250 worker threads.
> [Mon Aug 22 10:18:37.117590 2016] [wsgi:error] [pid 5092:tid 2592] [client
> 172.16.0.110:58441] mod_wsgi (pid=5092): Exception occurred processing
> 172.16.0.110:58441] Traceback (most recent call last):
> 172.16.0.110:58441]   File "C:\\GeoNode-2.4.x\\geonode-2.
> __call__
> [Mon Aug 22 10:18:37.118592 2016] [wsgi:error] [pid 5092:tid 2592] [client
> 172.16.0.110:58441]     self.load_middleware()
> load_middleware
> 172.16.0.110:58441]     for middleware_path in
> __getattr__
> 172.16.0.110:58441]     self._setup(name)
> 172.16.0.110:58441]     self._wrapped = Settings(settings_module)
> 172.16.0.110:58441]     mod = importlib.import_module(self.
> SETTINGS_MODULE)
> import_module
> [Mon Aug 22 10:18:37.119591 2016] [wsgi:error] [pid 5092:tid 2592] [client
> 172.16.0.110:58441]     __import__(name)
> 172.16.0.110:58441]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py",
> line 892
> 172.16.0.110:58441]     "apiKey": s1kpAAqIEjz86yRjlnlk~
> 172.16.0.110:58441]                                   ^
> 172.16.0.110:58441] SyntaxError: invalid syntax
> [Mon Aug 22 10:18:37.197595 2016] [wsgi:error] [pid 5092:tid 2592] [client
> 172.16.0.110:58442] mod_wsgi (pid=5092): Exception occurred processing
> WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'., referer:
> http://aupegis03/
> 172.16.0.110:58442] Traceback (most recent call last):, referer:
> http://aupegis03/
> [Mon Aug 22 10:18:37.198596 2016] [wsgi:error] [pid 5092:tid 2592] [client
> 172.16.0.110:58442]   File "C:\\GeoNode-2.4.x\\geonode-2.
> __call__, referer: http://aupegis03/
> 172.16.0.110:58442]     self.load_middleware(), referer: http://aupegis03/
> load_middleware, referer: http://aupegis03/
> 172.16.0.110:58442]     for middleware_path in
> settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/
> __getattr__, referer: http://aupegis03/
> 172.16.0.110:58442]     self._setup(name), referer: http://aupegis03/
> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup,
> 172.16.0.110:58442]     self._wrapped = Settings(settings_module),
> __init__, referer: http://aupegis03/
> 172.16.0.110:58442]     mod = importlib.import_module(self.SETTINGS_MODULE),
> import_module, referer: http://aupegis03/
> 172.16.0.110:58442]     __import__(name), referer: http://aupegis03/
> 172.16.0.110:58442]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py",
> line 892, referer: http://aupegis03/
> 172.16.0.110:58442]     "apiKey": s1kpAAqIEjz86yRjlnlk~
> tPUN2J2Fvxzv14u6U8jpwQ~AsquDvAuq0pVg1VaXex4VFpz0V29SNsl_hpkv-P3_CPXMm0kE4zbMcpn5p7f8V45,
> 172.16.0.110:58442]                                   ^, referer:
> http://aupegis03/
> 172.16.0.110:58442] SyntaxError: invalid syntax, referer:
> http://aupegis03/
> Also I have set the env var as per the instructions but still no luck, but
> setting the GEONODE_PATHEXT is not clear, here is what I have:
> GDAL_HOME                                     C:\GeoNode-2.4.x\GDAL
> GDAL_LIBRARY_PATH                    C:\GeoNode-2.4.x\GDAL\gdal111.dll
> GEOS_LIBRARY_PATH                    C:\GeoNode-2.4.x\GDAL\geos.dll (or
> should it be geos_c.dll)
> JRE_HOME                                          C:\GeoNode-2.4.x\jre
> GEONODE_PATHEXT                      This is what is confusing me (what
> do I  need to enter here? C:\GeoNode-2.4.x; C:\GeoNode-2.4.x\geonode-2.4.x\scripts;
> C:\GeoNode-2.4.x\Python27; (anything else?) the add %GEONODE_PATHEXT% to
> Path
> %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\
> System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.
> 0\;%GEONODE_PATHEXT%;
> In the windows env if I follow the README.txt  and do this red text:
> *GeoNode Startup*
> *    To run GeoNode on Windows:*
> *    1. Start GeoServer Service*
> *                   GeoServer is running under Apache Tomcat7 which is
> installed as a "service" on your system.*
> *                   The service should start automatically, however before
> starting GeoNode, make sure the Apache Tomcat7 is up and running.*
> *    2. Start GeoNode*
> *       This shortcut redirects you to the http://localhost
> <http://localhost>, the GeoNode home page, on your default browser.*
> *    The default GeoNode administrator is:*
> *      username: admin*
> *      password: admin*
> *GeoNode Support*
> *    To get support, give feedbacks and suggestions please use the GeoNode
> official channels, the users mailing list: *
> *    http://lists.osgeo.org/pipermail/geonode-users/
> <http://lists.osgeo.org/pipermail/geonode-users/> and the developers
> mailing list: http://lists.osgeo.org/pipermail/geonode-devel/
> <http://lists.osgeo.org/pipermail/geonode-devel/>.*
> *    This repository is used to track code changes and GeoNode issues,
> please DON'T open new issues to ask for support.*
> *Notes on the installation*
> *                a. **Notice that sometimes the Apache HTTPD web service
> does not start automatically right after*
> *                   the installation due to the system environment.*
> *                   In that case, after the installation, run the "Apache2
> Start" from the WinLAMP shortcut.*
> *                   Also please check through the Windows Services that
> the two services "Apache Tomcat7" and "Apache2"*
> *                  are up and running.*
> *    b. If you have issues starting GeoNode, try to run the "GeoNode
> VirtualEnv Setup" shortcut.*
> *       Make sure all the GeoNode Python dependencies have been correctly
> installed on the*
> *       Virtual Environment.*
> *       In case of problems, please ask for support on the mailing lists.*
> I get this error:
> But the file exists and is in the right place,
> Any ideas anyone?
> I know of the gurus will be in Bonn this week….so may be busy J
> Cheers
> *Chris Franklin*
> GIS and Database Co-ordinator
> Exploration Australia
> Tel:         +61 08 9425 4719
> Fax:        +61 08 9425 4650
> Email:      cfranklin at anglogoldashanti.com
> Consider the environment. Think before you print.
> This email, and its attachments, is subject to important warnings and
> disclaimers which are legally incorporated into this email in terms of
> Section 11(3) of the South African Electronic Communications and
> Transactions Act, 25 of 2002. The full text of the warnings and
> disclaimers, together with the company details and directors is available
> by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/2ced4a26/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/2ced4a26/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/2ced4a26/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/2ced4a26/attachment-0005.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/2ced4a26/attachment-0001.jpg>
More information about the geonode-users mailing list
