[GeoNode-users] Customize GeoNode from the ubuntu package downloaded with sudo apt-get
Francesco Bartoli xbartolone at gmail.com
Tue Aug 23 14:23:24 PDT 2016
Hi Kevin,
absolutely, following the approach of geonode-project [1] you can customize even the systemwide geonode. Make sure to take the right branch corresponding to your version (I’m assuming you are on 2.4)
Francesco
[1] https://github.com/GeoNode/geonode-project/tree/master
Il giorno 23/ago/2016, alle ore 21:43, Kevin Côté <Kevin.Cote2 at USherbrooke.ca> ha scritto:
> Hi,
> Just wanted to know if it is possible to customize the GeoNode plateform when it has been automatically installed using the "sudo apt-get" method. If so, is the procedure similar to the one explained in the docs ?
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160823/24c00c87/attachment.html>
More information about the geonode-users mailing list
