[GeoNode-users] Geonode internal Error
Suchakrey Kongpila suchakreyk at adpc.net
Thu Aug 25 03:59:17 PDT 2016
Hi All
Our Geonode Server version 2.4 suddenly crash. Here is error detail in
apache log.
[Thu Aug 25 05:35:02.884236 2016] [:error] [pid 1176:tid 139696053827328]
Internal Server Error: /
[Thu Aug 25 05:35:02.884259 2016] [:error] [pid 1176:tid 139696053827328]
[Thu Aug 25 05:35:02.884261 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line
137, in get_response
[Thu Aug 25 05:35:02.884264 2016] [:error] [pid 1176:tid
139696053827328]     response = response.render()
[Thu Aug 25 05:35:02.884266 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/response.py", line
105, in render
[Thu Aug 25 05:35:02.884268 2016] [:error] [pid 1176:tid
139696053827328]     self.content = self.rendered_content
[Thu Aug 25 05:35:02.884269 2016] [:error] [pid 1176:tid 139696053827328]
82, in rendered_content
[Thu Aug 25 05:35:02.884271 2016] [:error] [pid 1176:tid
139696053827328]     content = template.render(context)
[Thu Aug 25 05:35:02.884273 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140,
in render
[Thu Aug 25 05:35:02.884275 2016] [:error] [pid 1176:tid
139696053827328]     return self._render(context)
[Thu Aug 25 05:35:02.884277 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134,
in _render
[Thu Aug 25 05:35:02.884279 2016] [:error] [pid 1176:tid
139696053827328]     return self.nodelist.render(context)
[Thu Aug 25 05:35:02.884281 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840,
in render
[Thu Aug 25 05:35:02.884283 2016] [:error] [pid 1176:tid
139696053827328]     bit = self.render_node(node, context)
[Thu Aug 25 05:35:02.884285 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854,
in render_node
[Thu Aug 25 05:35:02.884287 2016] [:error] [pid 1176:tid
139696053827328]     return node.render(context)
[Thu Aug 25 05:35:02.884289 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py",
line 123, in render
[Thu Aug 25 05:35:02.884291 2016] [:error] [pid 1176:tid
139696053827328]     return compiled_parent._render(context)
[Thu Aug 25 05:35:02.884293 2016] [:error] [pid 1176:tid 139696053827328]
in _render
[Thu Aug 25 05:35:02.884295 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884297 2016] [:error] [pid 1176:tid 139696053827328]
in render
[Thu Aug 25 05:35:02.884299 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884300 2016] [:error] [pid 1176:tid 139696053827328]
in render_node
[Thu Aug 25 05:35:02.884302 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884304 2016] [:error] [pid 1176:tid 139696053827328]
line 123, in render
[Thu Aug 25 05:35:02.884306 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884308 2016] [:error] [pid 1176:tid 139696053827328]
in _render
[Thu Aug 25 05:35:02.884311 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884313 2016] [:error] [pid 1176:tid 139696053827328]
in render
[Thu Aug 25 05:35:02.884315 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884323 2016] [:error] [pid 1176:tid 139696053827328]
in render_node
[Thu Aug 25 05:35:02.884325 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884327 2016] [:error] [pid 1176:tid 139696053827328]
line 62, in render
[Thu Aug 25 05:35:02.884329 2016] [:error] [pid 1176:tid
139696053827328]     result = block.nodelist.render(context)
[Thu Aug 25 05:35:02.884331 2016] [:error] [pid 1176:tid 139696053827328]
in render
[Thu Aug 25 05:35:02.884332 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884334 2016] [:error] [pid 1176:tid 139696053827328]
in render_node
[Thu Aug 25 05:35:02.884336 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884338 2016] [:error] [pid 1176:tid 139696053827328]
line 62, in render
[Thu Aug 25 05:35:02.884340 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884342 2016] [:error] [pid 1176:tid 139696053827328]
in render
[Thu Aug 25 05:35:02.884344 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884346 2016] [:error] [pid 1176:tid 139696053827328]
in render_node
[Thu Aug 25 05:35:02.884348 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884349 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py",
line 506, in render
[Thu Aug 25 05:35:02.884351 2016] [:error] [pid 1176:tid
139696053827328]     output = self.nodelist.render(context)
[Thu Aug 25 05:35:02.884353 2016] [:error] [pid 1176:tid 139696053827328]
in render
[Thu Aug 25 05:35:02.884355 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884357 2016] [:error] [pid 1176:tid 139696053827328]
in render_node
[Thu Aug 25 05:35:02.884359 2016] [:error] [pid 1176:tid
[Thu Aug 25 05:35:02.884361 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 1157,
in render
[Thu Aug 25 05:35:02.884363 2016] [:error] [pid 1176:tid
139696053827328]     context[self.target_var] = func(*resolved_args,
**resolved_kwargs)
[Thu Aug 25 05:35:02.884365 2016] [:error] [pid 1176:tid 139696053827328]
File
"/usr/local/lib/python2.7/dist-packages/geonode/base/templatetags/base_tags.py",
line 34, in facets
[Thu Aug 25 05:35:02.884367 2016] [:error] [pid 1176:tid
139696053827328]     request.user, 'base.view_resourcebase').values('id')
[Thu Aug 25 05:35:02.884368 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/guardian/shortcuts.py", line 387, in
get_objects_for_user
[Thu Aug 25 05:35:02.884370 2016] [:error] [pid 1176:tid
139696053827328]     user = get_anonymous_user()
[Thu Aug 25 05:35:02.884372 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/guardian/utils.py", line 37, in
get_anonymous_user
[Thu Aug 25 05:35:02.884374 2016] [:error] [pid 1176:tid
get_user_model().objects.get(id=guardian_settings.ANONYMOUS_USER_ID)
[Thu Aug 25 05:35:02.884376 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/db/models/manager.py", line
151, in get
[Thu Aug 25 05:35:02.884380 2016] [:error] [pid 1176:tid
139696053827328]     return self.get_queryset().get(*args, **kwargs)
[Thu Aug 25 05:35:02.884382 2016] [:error] [pid 1176:tid 139696053827328]
File "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line
310, in get
[Thu Aug 25 05:35:02.884384 2016] [:error] [pid 1176:tid
139696053827328]     self.model._meta.object_name)
[Thu Aug 25 05:35:02.884386 2016] [:error] [pid 1176:tid 139696053827328]
DoesNotExist: Profile matching query does not exist.
Could you please suggest me how to solve this problem?
Best regards,
Suchakrey
*adpc*
*Asian Disaster Preparedness Center*
Mr. Suchakrey Kongpila
Computer and Network Coordinator
Tel: +66 2 298 0682-92 *|* Fax: +66 2 298 0012
Mobile: +66 8 9451 4468 *| *Skype: chakreyk
www.adpc.net *| **twitter <https://twitter.com/ADPCnet>* *| *facebook
<https://www.facebook.com/adpc.thailand>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160825/6c7e90c8/attachment-0001.html>
More information about the geonode-users mailing list
