[GeoNode-users] Severe layer permissions problem
Daniel Berry dberry at boundlessgeo.com
Fri Aug 26 02:52:22 PDT 2016
Ben,
It appears that your GeoServer is not seeing the  GeoNode (Django)
sessionid. Did you configure the GeoNode Auth provider
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration.
Geoserver uses the sessionid to initiate a request to GeoNode to verify
that the user is authorized to view the layer. If the layer is not granted
anonymous access GeoServer will not expose the layer to the user, which is
why you are seeing pink tiles.
Dan
On Aug 26, 2016 08:39, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
> Benjamin, Can you file an issue for this in the issue tracker. One of
> us will try to replicate on a fresh instance.
> On Fri, Aug 26, 2016 at 12:17 AM, Benjamin Ducke <benducke at fastmail.fm>
> wrote:
> > Dear All --
> > I have a layer permissions problem that
> > I cannot solve. The problem is that any
> > vector layer which is not set to visible to
> > "Anyone" cannot be viewed, not even by
> > the layer's owner. It will be shown
> > in the list of Layers if the user has
> > viewing permissions, but clicking on it
> > will produce just a pink box. The Geoserver
> > log contains error messages complaining
> > about a missing layer:
> > Caused by: org.geoserver.platform.ServiceException: geonode:gisws_orte
> > layer does not exist
> > However, the layer does definitely exist
> > and will be displayed if switched visible
> > for "Anyone".
> > This problem occurs with PostGIS-stored
> > layers on a fresh installation of
> > GeoNode 2.4.1 (official Ubuntu packages),
> > with data migrated from a 2.0 install
> > following these instructions:
> > https://github.com/capooti/geonode/tree/migration_from20_
> to_24/scripts/migrations/migrate20to24
> > Any hints would be very much appreciated.
> > Cheers,
> > Ben
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160826/d5df80c7/attachment.html>
More information about the geonode-users mailing list
