[GeoNode-users] Severe layer permissions problem
Benjamin Ducke benducke at fastmail.fm
Fri Aug 26 02:51:23 PDT 2016
Hi Dan --
On 26/08/16 11:52, Daniel Berry wrote:
> Ben,
> It appears that your GeoServer is not seeing the  GeoNode (Django)
> sessionid. Did you configure the GeoNode Auth provider
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration.
> Geoserver uses the sessionid to initiate a request to GeoNode to verify
> that the user is authorized to view the layer. If the layer is not
> granted anonymous access GeoServer will not expose the layer to the
> user, which is why you are seeing pink tiles.
Thanks for the pointer!
I will check this. Most likely it is not
configured (correctly).
If there is still a problem then I will
file a proper bug report.
Cheers!
Ben
> Dan
> On Aug 26, 2016 08:39, "Jeffrey Johnson" <ortelius at gmail.com
> <mailto:ortelius at gmail.com>> wrote:
>     Benjamin, Can you file an issue for this in the issue tracker. One of
>     us will try to replicate on a fresh instance.
>     On Fri, Aug 26, 2016 at 12:17 AM, Benjamin Ducke
>     <benducke at fastmail.fm <mailto:benducke at fastmail.fm>> wrote:
>     > Dear All --
>     > I have a layer permissions problem that
>     > I cannot solve. The problem is that any
>     > vector layer which is not set to visible to
>     > "Anyone" cannot be viewed, not even by
>     > the layer's owner. It will be shown
>     > in the list of Layers if the user has
>     > viewing permissions, but clicking on it
>     > will produce just a pink box. The Geoserver
>     > log contains error messages complaining
>     > about a missing layer:
>     > Caused by: org.geoserver.platform.ServiceException: geonode:gisws_orte
>     > layer does not exist
>     > However, the layer does definitely exist
>     > and will be displayed if switched visible
>     > for "Anyone".
>     > This problem occurs with PostGIS-stored
>     > layers on a fresh installation of
>     > GeoNode 2.4.1 (official Ubuntu packages),
>     > with data migrated from a 2.0 install
>     > following these instructions:
>     https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24
>     <https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24>
>     > Any hints would be very much appreciated.
>     > Cheers,
>     > Ben
>     > _______________________________________________
>     > geonode-users mailing list
>     > geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     > http://lists.osgeo.org/mailman/listinfo/geonode-users
>     <http://lists.osgeo.org/mailman/listinfo/geonode-users>
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
More information about the geonode-users mailing list
