[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso simone.dalmasso at gmail.com
Mon Dec 19 05:21:44 PST 2016
I suggest you to go manually and create a site folder copying the
site_template, rename and add the Site object into the database.
geosites has not been revised for a while and geonode improved. It works
but the shortcut command addsite may be broken.
2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> I did what you suggested, actually now I have the addsite command, but as
> you announced I have also this error:
> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
> then I added SITE_ROOT in local_setting.py inserting the path
> "geonode/contrib/geosites"
> afterwords I had this error:
> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
> so that I added SERVE_PATH in local_setting.py inserting the path "
> geonode/contrib/geosites/static"
> but I'm not sure I did the right thing, since now I have this error:
> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib/site2'
> Where I'm wrong?
> Thanks
> Eugenio
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 19 dicembre 2016 11.04
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> you have to add it in INSTALLED_APPS, currently it is only listed in the
> contrib apps.
> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone,
>> and thank you for your answer.
>> Sorry for my trivial question:
>> in my setting.py I have already geonode.contrib.geosites
>> in GEONODE_CONTRIB_APPS, see below:
>> GEONODE_CONTRIB_APPS = (
>>     # GeoNode Contrib Apps
>>     'geonode.contrib.dynamic',
>>     'geonode.contrib.exif',
>>     'geonode.contrib.favorite',
>>     'geonode.contrib.geogig',
>>     'geonode.contrib.geosites',
>>     'geonode.contrib.nlp',
>>     'geonode.contrib.slack'
>> in INSTALLED_APPS I have:
>> INSTALLED_APPS = (
>>     # Boostrap admin theme
>>     # 'django_admin_bootstrapped.bootstrap3',
>>     # 'django_admin_bootstrapped',
>>     # Apps bundled with Django
>>     'django.contrib.auth',
>>     'django.contrib.contenttypes',
>>     'django.contrib.sessions',
>>     'django.contrib.sites',
>>     'django.contrib.admin',
>>     'django.contrib.sitemaps',
>>     'django.contrib.staticfiles',
>>     'django.contrib.messages',
>>     'django.contrib.humanize',
>>     'django.contrib.gis',
>>     # Third party apps
>>     # Utility
>>     'pagination',
>>     'taggit',
>>     'friendlytagloader',
>>     'geoexplorer',
>>     'leaflet',
>>     'django_extensions',
>>     # 'haystack',
>> ....and others...
>> Should I insert geonode.contrib.geosites somewhere in local_setting? or
>> it's already ok as it? or copy geonode.contrib.geosites in settings.py
>> under INSTALLED_APPS?
>> Sorry again for this banal question...
>> E.
>> *Inviato:* lunedì 19 dicembre 2016 09.04
>> *A:* Eugenio Trumpy
>> Ciao Eugenio,
>> sorry for being so late in the response.
>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS in
>> order to get the command.
>> In case you get errors in running that command, you can always 'make' a
>> geosite by yourself by copying the folder 'site_template' and changing it's
>> name and internal parameters and then register the new Site in the admin
>> panel. You can follow the utils.py add_site function and replicate the
>> needed steps (some of them are only for production).
>> Take also some time to see how the pre and post settings work.
>> Hope this helps
>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi everyone,
>>> regarding the multi-tenancy setting up and in particular the
>>> installation of new site since the command:
>>> python manage.py addsite sitename sitedomain
>>> return me:
>>> Unknown command: 'addsite'
>>> Type 'manage.py help' for usage.
>>> Do you know way? Have I 'activate' in some way the multi-tenancy before?
>>> or it is ready to use?
>>> If it is ready to use, why 'addsite' is an unknown command?
>>> I launched the command from the main geonode directory, am I right?
>>> As I wrote in the previous email in my installation I have only
>>> manage.py file in
>>> /geonode directory.
>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>> 2.4.dev20151029170512.
>>> I installed geonode as custom installation (not by apt-get).
>>> Thanks
>>> Eugenio
>>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>> *A:* geonode-users at lists.osgeo.org
>>> *Oggetto:* Multi-Tenancy: how to start
>>> Hi all,
>>> as pointed in the email object I want to try the geonode multi-tenancy
>>> capabilities.
>>> I started of course from the documentation [1] and [2], but a need some
>>> hints to start.
>>> I have already a running geonode instance. Do you think I should start
>>> from
>>> a clean geonode installation or I can arrange the running one?
>>> Is there somewhere a set of commands to setup the geosite 1, geosite 2,
>>> I was looking into geosites folder, as suggested in [2], but I don't see
>>> neither manage.py nor manage_all.py files.
>>> I tried python manage.py addsite geosite1 geosite1domain
>>> but I got Unknown command: 'addsite'
>>> Am I missing something?
>>> After that: How can I sort out the already stored layers?
>>> Thank you very much for hints and for the patience of this
>>> stupid questions,
>>> Eugenio
>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>> lti-tenancy.html
>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>> ontrib/geosites
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161219/68a8e77d/attachment-0001.html>
More information about the geonode-users mailing list
