[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso simone.dalmasso at gmail.com
Mon Dec 19 09:33:47 PST 2016
I mean the whole gemex folder can be outside. For the static roots they can
be anywhere and is not recommended to have them inside but rather in
/var/www as they need to be served by the web server at some point.
2016-12-19 16:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Ok, once I run syncdb I 'm able to register new site! first step!!!!
> Coming back to the first issue, I'm not sure to have understood well, do
> you mean the dir thumb, layers, static_root can stay ouside my newsite
> directory?
> That means I cannot run collectstatic if those dirs are inside my site dir?
> Actually in the docs I read I saw that the static folder is inside the
> new sites.
> This part is not so clear to me....
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 19 dicembre 2016 16.22
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> It is a good practice to not install the new sites folders into the root
> of the code. They can live outside without problems.
> The second issue is that you did not run python manage.py syncdb or
> migrate to install the tables that come with geosites.
> 2016-12-19 15:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Sorry for these multiple emails,
>> I following your suggestion to create the site by hand I proceeded to
>> register the new site by using the admin console as you suggested.
>> On save action I had this error message:
>> http://pastebin.com/SskX1QNB
>> It seems geonode.contrib.geosites is not installed yet, right?
>> E.
>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>> *Inviato:* lunedì 19 dicembre 2016 15.37
>> *A:* Simone Dalmasso
>> Ok,
>> this is my new virtualhost prepared for the new site named 'gemex':
>> <VirtualHost *:80>
>>     ServerName http://gemex.igg.cnr.it
>>     ServerAdmin webmaster at localhost
>>     DocumentRoot /var/www/html
>>     Options -Indexes +FollowSymLinks
>>     Alias /gemex "/dati/geonode/geonode/contrib/geosites"
>>     WSGIDaemonProcess gemex python-path=/dati/geonode/geon
>> ode/contrib/geosites:/dati/.venvs/geonode/lib/python2.7/site-packages
>> user=eugenio threads=15 processes=2
>>     ErrorLog /var/log/apache2/error.log
>>     LogLevel warn
>>     CustomLog /var/log/apache2/access.log combined
>>     WSGIProcessGroup gemex
>>     WSGIPassAuthorization On
>>     WSGIScriptAlias / /dati/geonode/geonode/contrib/
>> geosites/gemex/wsgi.py
>>     <Directory "/dati/geonode/geonode/contrib/geosites/gemex">
>>            Options Indexes FollowSymLinks
>>         Require all granted
>>         IndexOptions FancyIndexing
>>     </Directory>
>>     Alias /uploaded/ /dati/geonode/geonode/contrib/
>> geosites/gemex/uploaded/
>>     Alias /static/ /dati/geonode/geonode/contrib/
>> geosites/gemex/static_root/
>>      ProxyPreserveHost On
>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>     ProxyPass /geoserver2 http://localhost:8080/geoserver2
>>     ProxyPassReverse /geoserver2 http://localhost:8080/geoserver2
>> </VirtualHost>
>> My concerns are:
>>    - WSGIDeamon line, is that correct?
>>    - the first Alias, is that correct too?
>>    - Eventually the Directory is right?
>> Moreover, I followed again this page for the http setup:
>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>> n/geonode_install/setup_configure_httpd.html
>> I think now should be rready for the collecstatic command, but I don't
>> know how to run it in in the new static_root inside my site gemex.
>> Any hints?
>> E.
>> Setup & Configure HTTPD — GeoNode 2.4 documentation
>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html>
>> docs.geonode.org
>> Setup & Configure HTTPD¶ In this section we are going to setup Apache
>> HTTP to serve GeoNode.
>> *Inviato:* lunedì 19 dicembre 2016 15.03
>> *A:* Eugenio Trumpy
>> Exactly, one virtualhost for each site.
>> 2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Ok,
>>> I will proceed this way.
>>> Then I have to create a new virtualhost pointing to the wsgi.py within
>>> the new site dir, right?
>>> In the same virtual host have I to set new aliases for uploaded dir and
>>> static_root as I did for the normal installation?
>>> E.
>>> *Inviato:* lunedì 19 dicembre 2016 14.21
>>> *A:* Eugenio Trumpy
>>> I suggest you to go manually and create a site folder copying the
>>> site_template, rename and add the Site object into the database.
>>> geosites has not been revised for a while and geonode improved. It works
>>> but the shortcut command addsite may be broken.
>>> 2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi Simone,
>>>> I did what you suggested, actually now I have the addsite command, but
>>>> as you announced I have also this error:
>>>> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
>>>> then I added SITE_ROOT in local_setting.py inserting the path
>>>> "geonode/contrib/geosites"
>>>> afterwords I had this error:
>>>> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
>>>> so that I added SERVE_PATH in local_setting.py inserting the path "
>>>> geonode/contrib/geosites/static"
>>>> but I'm not sure I did the right thing, since now I have this error:
>>>> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib/site2'
>>>> Where I'm wrong?
>>>> Thanks
>>>> Eugenio
>>>> *Inviato:* lunedì 19 dicembre 2016 11.04
>>>> *A:* Eugenio Trumpy
>>>> you have to add it in INSTALLED_APPS, currently it is only listed in
>>>> the contrib apps.
>>>> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Hi Simone,
>>>>> and thank you for your answer.
>>>>> Sorry for my trivial question:
>>>>> in my setting.py I have already geonode.contrib.geosites
>>>>> in GEONODE_CONTRIB_APPS, see below:
>>>>> GEONODE_CONTRIB_APPS = (
>>>>>     # GeoNode Contrib Apps
>>>>>     'geonode.contrib.dynamic',
>>>>>     'geonode.contrib.exif',
>>>>>     'geonode.contrib.favorite',
>>>>>     'geonode.contrib.geogig',
>>>>>     'geonode.contrib.geosites',
>>>>>     'geonode.contrib.nlp',
>>>>>     'geonode.contrib.slack'
>>>>> in INSTALLED_APPS I have:
>>>>> INSTALLED_APPS = (
>>>>>     # Boostrap admin theme
>>>>>     # 'django_admin_bootstrapped.bootstrap3',
>>>>>     # 'django_admin_bootstrapped',
>>>>>     # Apps bundled with Django
>>>>>     'django.contrib.auth',
>>>>>     'django.contrib.contenttypes',
>>>>>     'django.contrib.sessions',
>>>>>     'django.contrib.sites',
>>>>>     'django.contrib.admin',
>>>>>     'django.contrib.sitemaps',
>>>>>     'django.contrib.staticfiles',
>>>>>     'django.contrib.messages',
>>>>>     'django.contrib.humanize',
>>>>>     'django.contrib.gis',
>>>>>     # Third party apps
>>>>>     # Utility
>>>>>     'pagination',
>>>>>     'taggit',
>>>>>     'friendlytagloader',
>>>>>     'geoexplorer',
>>>>>     'leaflet',
>>>>>     'django_extensions',
>>>>>     # 'haystack',
>>>>> ....and others...
>>>>> Should I insert geonode.contrib.geosites somewhere in local_setting?
>>>>> or it's already ok as it? or copy geonode.contrib.geosites in
>>>>> settings.py under INSTALLED_APPS?
>>>>> Sorry again for this banal question...
>>>>> E.
>>>>> *Inviato:* lunedì 19 dicembre 2016 09.04
>>>>> *A:* Eugenio Trumpy
>>>>> Ciao Eugenio,
>>>>> sorry for being so late in the response.
>>>>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS in
>>>>> order to get the command.
>>>>> In case you get errors in running that command, you can always 'make'
>>>>> a geosite by yourself by copying the folder 'site_template' and changing
>>>>> it's name and internal parameters and then register the new Site in the
>>>>> admin panel. You can follow the utils.py add_site function and replicate
>>>>> the needed steps (some of them are only for production).
>>>>> Take also some time to see how the pre and post settings work.
>>>>> Hope this helps
>>>>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>> Hi everyone,
>>>>>> regarding the multi-tenancy setting up and in particular the
>>>>>> installation of new site since the command:
>>>>>> python manage.py addsite sitename sitedomain
>>>>>> return me:
>>>>>> Unknown command: 'addsite'
>>>>>> Type 'manage.py help' for usage.
>>>>>> Do you know way? Have I 'activate' in some way the multi-tenancy
>>>>>> before? or it is ready to use?
>>>>>> If it is ready to use, why 'addsite' is an unknown command?
>>>>>> I launched the command from the main geonode directory, am I right?
>>>>>> As I wrote in the previous email in my installation I have only
>>>>>> manage.py file in
>>>>>> /geonode directory.
>>>>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>>>>> 2.4.dev20151029170512.
>>>>>> I installed geonode as custom installation (not by apt-get).
>>>>>> Thanks
>>>>>> Eugenio
>>>>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>>>>> *A:* geonode-users at lists.osgeo.org
>>>>>> *Oggetto:* Multi-Tenancy: how to start
>>>>>> Hi all,
>>>>>> as pointed in the email object I want to try the
>>>>>> geonode multi-tenancy capabilities.
>>>>>> I started of course from the documentation [1] and [2], but a need
>>>>>> some hints to start.
>>>>>> I have already a running geonode instance. Do you think I should
>>>>>> start from
>>>>>> a clean geonode installation or I can arrange the running one?
>>>>>> Is there somewhere a set of commands to setup the geosite 1, geosite
>>>>>> 2, ...
>>>>>> I was looking into geosites folder, as suggested in [2], but I don't
>>>>>> see neither manage.py nor manage_all.py files.
>>>>>> I tried python manage.py addsite geosite1 geosite1domain
>>>>>> but I got Unknown command: 'addsite'
>>>>>> Am I missing something?
>>>>>> After that: How can I sort out the already stored layers?
>>>>>> Thank you very much for hints and for the patience of this
>>>>>> stupid questions,
>>>>>> Eugenio
>>>>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>>>>> lti-tenancy.html
>>>>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>>>>> ontrib/geosites
>>>>> Simone
>>>> Simone
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161219/7dda473f/attachment-0001.html>
More information about the geonode-users mailing list
