[GeoNode-users] Multi-Tenancy: how to start
Eugenio Trumpy frippe12573 at hotmail.com
Thu Dec 29 03:21:36 PST 2016
Hi Simone and all,
unfortunately I hadn't solved my problem multi-tenancy configuration.
My new questions are:
  *   can I set-up multi-geosites from my running normal installation? (I installed geonode following this guide [1]) or should I install a geonode from scratch?
  *   to run multi-geosites do you suggest me to setup multi-geosite from special version of geonode as for instance [2], if yes How to start?
  *   in my geonode normal installation manage.py and manage_all.py are missing in the /geonode/geonode/contrib/geosites/
  *   the master site has to be within contrib/geosites/master-site, which relationship is there between the normal geonode site and the master-site? in case master-site has to inherit from normal one-site config, how?
  *   just to be sure is this the right order of the setting files read by geonode:
     *   /geonode/geonode/local_setting.py and /geonode/geonode/setting.py (overridden by the first)
     *   /geonode/geonode/contrib/geosites/pre_setting.py
     *   /geonode/geonode/contrib/geosites/local_setting.py
and /geonode/geonode/contrib/geositessetting.py (overridden by the first)
     *   /geonode/geonode/contrib/geosites/post_setting.py
  *   in my test performed in the last days I set the: SERVE_PATH= "/dati/geonode/geonode/contrib/geosites/ in /geonode/geonode/local_setting.py is that right? in apache error log I have:
[Thu Dec 29 11:46:21.129691 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]     self.load_middleware()
[Thu Dec 29 11:46:21.129706 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 44, in load_middleware
[Thu Dec 29 11:46:21.129728 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]     for middleware_path in settings.MIDDLEWARE_CLASSES:
[Thu Dec 29 11:46:21.129742 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]   File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line 54, in __getattr__
[Thu Dec 29 11:46:21.129763 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]     self._setup(name)
[Thu Dec 29 11:46:21.129776 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]   File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line 49, in _setup
[Thu Dec 29 11:46:21.129797 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]     self._wrapped = Settings(settings_module)
[Thu Dec 29 11:46:21.129810 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]   File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line 132, in __init__
[Thu Dec 29 11:46:21.129831 2016] [:error] [pid 14216] [remote 93.32.72.156:62917]     % (self.SETTINGS_MODULE, e)
[Thu Dec 29 11:46:21.129851 2016] [:error] [pid 14216] [remote 93.32.72.156:62917] ImportError: Could not import settings '$PROJECT_NAME.gemex.settings' (Is it on sys.path? Is there an import error in the settings file?): No module named $PROJECT_NAME.gemex.settings
the error at last line it is seems to be related to something missing....
  *   last but not least I still have doubt on the positioning of static_root folder for each geosites, I would maintain them within each geosite folder but I don't know how to run collectstatic to populate that folder.
Thanks for any hint...
Eugenio
[1] http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html
[2] <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html> https://github.com/terranodo/geosites-project
terranodo/geosites-project<https://github.com/terranodo/geosites-project>
github.com
geosites-project - A skeleton project for creating a multi-tenancy GeoNode using the GeoSites contrib app.
Da: Simone Dalmasso <simone.dalmasso at gmail.com>
Inviato: mercoledì 21 dicembre 2016 10.37
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org
Oggetto: Re: Multi-Tenancy: how to start
ok:
- I this that that Alias is a mistake, the way is configured is that any url /gemex will internally point to /dati but I don't think they are actually urls. You can remove it
- you can assign a new name to WSGIProcessGroup
- it ok to keep the dir in the root base of geonode since your site is inside
- the geonode apt package creates the uploaded and static root under var/www as far as I know. It is ok to reuse the same settings. If not I suggest you to put them there as they are meant to be served by apache.
- you can use the same config for the Daemon, just use the name you gave to the WSGIProcessGroup instead of geonode
This is a brief explanation but you can find more on the static url and roots on the django docs and more on the wsgi config on the apache docs
hope this helps.
2016-12-20 9:36 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Hi Simone and all,
thanks again for your inputs.
However, I think I'm at a crucial position to finalize the configuration of the first new geosite (named gemex).
Just to clarify all the step performed and to focus the stage where I'm now, I list here below what I did and what I miss:
  1.  in setting.py I added under INSTALLED_APPS the line 'geonode.contrib.geosites'
  2.  I run python manage.py syncdb
  3.  I copy site-template (i.e. the folder inside contrib/geosites/) in the same position (i.e. contrib/geosites/) with a new name (e.g. gemex in my case)
  4.  I created a 4 level doman to be linked to the new site (i.e. gemex.igg.cnr.it<http://gemex.igg.cnr.it> in my case)
  5.  I added a new site from the admin panel available from a normal running installation
  6.  I create a new virtual host (for apache2) by copy the virtual host I had for the normal running installation. Here what is clear to me are the items:
     *   ServerName = where I put the created 4 level domain
     *   WSGIScriptAlias where I put the link to the wsgi.py available within the created newsite (i.e. path to contrib/geosites/gemex/wsgi.py)
     *   ProxyPass and ProxyPassReverse linked to the local geoserver
What is not yet clear:
from your last email I understand that the new site can be where I prefer. I would say that for now I can leave it inside contrib/geosites, if I can of course.
Then I have doubts to setup these lines:
  *   In the normal config I have Alias /geonode /dati/geonode/geonode but I think I should change to link it to my new site, is it right?
  *   In WSGIProcessGroup the normal config has geonode, for my new site do I need to change it?
  *   Regarding the directive Directory I had <Directory "/dati/geonode/geonode/"> for the normal config, here should I insert the path to my new site?
  *   Regarding /uploaded/ and /static/ Aliases, I understood from your email I can put those directory where I prefer. Now another trivial question: /uploaded/ and /static/ folder have to be different from those created for the normal installation? if no, then it is easy both configure the virtual host and run collectstatic. If yes, it is not clear how to run collectstatic for the new site. That's why the command python manage.py collectstatic works only within geonode folder and fill in the normal static_root folder. Could you clarify this point?
  *   Last but not least the line WSGIDaemonProcess is not clear, because running: service apache reload I had an error: Name duplicates previous WSGI daemon definition (that's why apache find the virtualhost I have for the normal installation. The normal installation has: WSGIDaemonProcess geonode python-path=/dati/geonode/:/dati/.venvs/geonode/lib/python2.7/site-packages user=eugenio threads=15 processes=2 How should sort out this line for the new site?
I offer myself to prepare an how to for dummies to be included as documentation in git, if I will be able to configure geosites.
Thanks for any clarification
Eugenio
Da: Simone Dalmasso <simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>>
Inviato: lunedì 19 dicembre 2016 18.33
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
I mean the whole gemex folder can be outside. For the static roots they can be anywhere and is not recommended to have them inside but rather in /var/www as they need to be served by the web server at some point.
2016-12-19 16:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Ok, once I run syncdb I 'm able to register new site! first step!!!!
Coming back to the first issue, I'm not sure to have understood well, do you mean the dir thumb, layers, static_root can stay ouside my newsite directory?
That means I cannot run collectstatic if those dirs are inside my site dir?
Actually in the docs I read I saw that the static folder is inside the new sites.
This part is not so clear to me....
E.
Inviato: lunedì 19 dicembre 2016 16.22
A: Eugenio Trumpy
It is a good practice to not install the new sites folders into the root of the code. They can live outside without problems.
The second issue is that you did not run python manage.py syncdb or migrate to install the tables that come with geosites.
2016-12-19 15:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Sorry for these multiple emails,
I following your suggestion to create the site by hand I proceeded to register the new site by using the admin console as you suggested.
On save action I had this error message:
http://pastebin.com/SskX1QNB
It seems geonode.contrib.geosites is not installed yet, right?
E.
Da: Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>
Inviato: lunedì 19 dicembre 2016 15.37
A: Simone Dalmasso
Ok,
this is my new virtualhost prepared for the new site named 'gemex':
<VirtualHost *:80>
    ServerName http://gemex.igg.cnr.it
    ServerAdmin webmaster at localhost
    DocumentRoot /var/www/html
    Options -Indexes +FollowSymLinks
    Alias /gemex "/dati/geonode/geonode/contrib/geosites"
    WSGIDaemonProcess gemex python-path=/dati/geonode/geonode/contrib/geosites:/dati/.venvs/geonode/lib/python2.7/site-packages user=eugenio threads=15 processes=2
    ErrorLog /var/log/apache2/error.log
    LogLevel warn
    CustomLog /var/log/apache2/access.log combined
    WSGIProcessGroup gemex
    WSGIPassAuthorization On
    WSGIScriptAlias / /dati/geonode/geonode/contrib/geosites/gemex/wsgi.py
    <Directory "/dati/geonode/geonode/contrib/geosites/gemex">
           Options Indexes FollowSymLinks
        Require all granted
        IndexOptions FancyIndexing
    </Directory>
    Alias /uploaded/ /dati/geonode/geonode/contrib/geosites/gemex/uploaded/
    Alias /static/ /dati/geonode/geonode/contrib/geosites/gemex/static_root/
     ProxyPreserveHost On
    ProxyPass /geoserver http://localhost:8080/geoserver
    ProxyPassReverse /geoserver http://localhost:8080/geoserver
    ProxyPass /geoserver2 http://localhost:8080/geoserver2
    ProxyPassReverse /geoserver2 http://localhost:8080/geoserver2
</VirtualHost>
My concerns are:
  *   WSGIDeamon line, is that correct?
  *   the first Alias, is that correct too?
  *   Eventually the Directory is right?
Moreover, I followed again this page for the http setup:
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
I think now should be rready for the collecstatic command, but I don't know how to run it in in the new static_root inside my site gemex.
Any hints?
E.
Setup & Configure HTTPD — GeoNode 2.4 documentation<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html>
docs.geonode.org<http://docs.geonode.org>
Setup & Configure HTTPD¶ In this section we are going to setup Apache HTTP to serve GeoNode.
Inviato: lunedì 19 dicembre 2016 15.03
A: Eugenio Trumpy
Exactly, one virtualhost for each site.
2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Ok,
I will proceed this way.
Then I have to create a new virtualhost pointing to the wsgi.py within the new site dir, right?
In the same virtual host have I to set new aliases for uploaded dir and static_root as I did for the normal installation?
E.
Inviato: lunedì 19 dicembre 2016 14.21
A: Eugenio Trumpy
I suggest you to go manually and create a site folder copying the site_template, rename and add the Site object into the database.
geosites has not been revised for a while and geonode improved. It works but the shortcut command addsite may be broken.
2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Hi Simone,
I did what you suggested, actually now I have the addsite command, but as you announced I have also this error:
AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
then I added SITE_ROOT in local_setting.py inserting the path "geonode/contrib/geosites"
afterwords I had this error:
AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
so that I added SERVE_PATH in local_setting.py inserting the path "geonode/contrib/geosites/static"
but I'm not sure I did the right thing, since now I have this error:
OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib/site2'
Where I'm wrong?
Thanks
Eugenio
Inviato: lunedì 19 dicembre 2016 11.04
A: Eugenio Trumpy
you have to add it in INSTALLED_APPS, currently it is only listed in the contrib apps.
2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Hi Simone,
and thank you for your answer.
Sorry for my trivial question:
in my setting.py I have already geonode.contrib.geosites
in GEONODE_CONTRIB_APPS, see below:
GEONODE_CONTRIB_APPS = (
    # GeoNode Contrib Apps
    'geonode.contrib.dynamic',
    'geonode.contrib.exif',
    'geonode.contrib.favorite',
    'geonode.contrib.geogig',
    'geonode.contrib.geosites',
    'geonode.contrib.nlp',
    'geonode.contrib.slack'
in INSTALLED_APPS I have:
INSTALLED_APPS = (
    # Boostrap admin theme
    # 'django_admin_bootstrapped.bootstrap3',
    # 'django_admin_bootstrapped',
    # Apps bundled with Django
    'django.contrib.auth',
    'django.contrib.contenttypes',
    'django.contrib.sessions',
    'django.contrib.sites',
    'django.contrib.admin',
    'django.contrib.sitemaps',
    'django.contrib.staticfiles',
    'django.contrib.messages',
    'django.contrib.humanize',
    'django.contrib.gis',
    # Third party apps
    # Utility
    'pagination',
    'taggit',
    'friendlytagloader',
    'geoexplorer',
    'leaflet',
    'django_extensions',
    # 'haystack',
....and others...
Should I insert geonode.contrib.geosites somewhere in local_setting? or it's already ok as it? or copy geonode.contrib.geosites in settings.py under INSTALLED_APPS?
Sorry again for this banal question...
E.
Inviato: lunedì 19 dicembre 2016 09.04
A: Eugenio Trumpy
Ciao Eugenio,
sorry for being so late in the response.
You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS in order to get the command.
In case you get errors in running that command, you can always 'make' a geosite by yourself by copying the folder 'site_template' and changing it's name and internal parameters and then register the new Site in the admin panel. You can follow the utils.py add_site function and replicate the needed steps (some of them are only for production).
Take also some time to see how the pre and post settings work.
Hope this helps
2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
Hi everyone,
regarding the multi-tenancy setting up and in particular the installation of new site since the command:
python manage.py addsite sitename sitedomain
return me:
Unknown command: 'addsite'
Type 'manage.py help' for usage.
Do you know way? Have I 'activate' in some way the multi-tenancy before? or it is ready to use?
If it is ready to use, why 'addsite' is an unknown command?
I launched the command from the main geonode directory, am I right?
As I wrote in the previous email in my installation I have only manage.py file in
/geonode directory.
I'm testing on on ubuntu 14.04 and geonode is at version 2.4.dev20151029170512.
I installed geonode as custom installation (not by apt-get).
Thanks
Eugenio
Inviato: venerdì 16 dicembre 2016 15.04
A: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Oggetto: Multi-Tenancy: how to start
Hi all,
as pointed in the email object I want to try the geonode multi-tenancy capabilities.
I started of course from the documentation [1] and [2], but a need some hints to start.
I have already a running geonode instance. Do you think I should start from
a clean geonode installation or I can arrange the running one?
Is there somewhere a set of commands to setup the geosite 1, geosite 2, ...
I was looking into geosites folder, as suggested in [2], but I don't see neither manage.py nor manage_all.py files.
I tried python manage.py addsite geosite1 geosite1domain
but I got Unknown command: 'addsite'
Am I missing something?
After that: How can I sort out the already stored layers?
Thank you very much for hints and for the patience of this stupid questions,
Eugenio
[1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/multi-tenancy.html
[2] https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
Simone
Simone
Simone
Simone
Simone
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161229/e38a17a0/attachment-0001.html>
More information about the geonode-users mailing list
