[GeoNode-users] Adding layer from GeoExplorer porduces error
David Alda Fernandez de Lezea dalda at hazi.eus
Thu Feb 4 05:27:24 PST 2016
Yeah, I usually do that with the layers that I load in GeoServer from different sources, but in this case is a user uploaded layer.. It is supposed that automatically it will load them, right?
Regards,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: jueves, 04 de febrero de 2016 13:53
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Adding layer from GeoExplorer porduces error
Hi, you may need to run a geonode updatelayers in order to register them in geonode.
2016-02-04 11:33 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi List,
I don’t know why but when I’m trying to add a layer in the geoexplorer interface I get an error 404 a prompt shows: PAGE NOT FOUND  Using fiddler I’ve seen that it fails requesting the url
http://192.168.1.190/gs/puntos_rakel/edit-check
where puntos_rakel is a previously added shape layer. It also occurs with all geoserver added layers.
The full output from fiddler is
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <title>GeoNode</title>
      <link href="/static/lib/css/assets.min.css?v=2.4" rel="stylesheet"/>
      <link href="/static/geonode/css/ext-compatibility.css?v=2.4" rel="stylesheet" />
      <link href="/static/geonode/css/base.css?v=2.4" rel="stylesheet" />
      <style type="text/css">[ng\:cloak],[ng-cloak],[data-ng-cloak],[x-ng-cloak],.ng-cloak,.x-ng-cloak,.ng-hide:not(.ng-hide-animate){display:none !important;}</style>
    <!--[if IE]>
      <script src="https://html5shim.googlecode.com/svn/trunk/html5.js"></script>
      <style>
        #ieflag{
            display: block !important;
            height: 150px;
            text-align: center;
      </style>
    <![endif]-->
    <link rel="search" type="application/opensearchdescription+xml" href="/catalogue/opensearch" title="GeoNode Search"/>
  </head>
  <body class="">
    <nav class="navbar navbar-inverse navbar-fixed-top" role="navigation">
      <div class="container">
        <div class="navbar-header">
          <button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#navbar">
            <span class="sr-only">Toggle navigation</span>
            <span class="icon-bar"></span>
          </button>
          <a class="navbar-brand" href="/">GeoNode</a>
        </div>
        <div id="navbar" class="navbar-collapse collapse">
          <ul class="nav navbar-nav">
            <li id="nav_layers">
              <a href="/layers/">Capas</a>
            </li>
            <li id="nav_maps">
              <a href="/maps/">Mapas</a>
            </li>
            <li id="nav_documents">
              <a href="/documents/">Documentos</a>
            </li>
            <li id="nav_people">
              <a href="/people/">Personas</a>
            </li>
            <li id="nav_groups">
              <a href="/groups/">Grupos</a>
            </li>
          </ul>
          <form class="navbar-form" id="search" action="/search/" >
            <div class="col-md-3">
              <div class="input-group">
                <input id="search_input" type="text" placeholder="Search" class="form-control" name="title__icontains">
                <span class="input-group-btn">
                  <button class="btn btn-primary" type="submit"><i class="fa fa-search"></i></button>
                </span>
              </div>
            </div>
          </form>
          <ul class="nav navbar-nav navbar-right">
            <li>
              <a href="#" data-toggle="modal" data-target="#UserModal" role="button" aria-expanded="false">
                <img src="http://www.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e/?s=30" alt="u0899jbe" /> u0899jbe
              </a>
            </li>
          </ul>
        </div><!--/.nav-collapse -->
      </div>
    </nav>
    <div class="alert alert-danger alert-dismissible" role="alert" id="ieflag" style="display:none">
      <button type="button" class="close" data-dismiss="alert" aria-label="Close"><span aria-hidden="true">×</span></button>
      <h1>You are using an outdated browser that is not supported by GeoNode.</h1>
      <p>Please use a <strong>modern browser</strong> like Mozilla Firefox, Google Chrome or Safari.</p>
    </div>
  <div id="wrap">
      <div class="alert alert-warn" id="status-message" hidden="hidden">
    <a class="close" onclick="$('.alert').hide()">×</a>
    <strong><p id="status-message-text">Placeholder for status-message</p></strong>
    <p id="status-message-text-body">Placeholder for status-message-body</p>
</div>
      <div class="row">
        <div class="col-md-8">
  <div id="description"><h3>Página no encontrada</h3></div>
La página solicitada no existe. Tal vez usted está utilizando un marcador desactualizado.⏎
        </div>
        <div class="col-md-4">
        </div>
      </div>
    </div>
  </div>
    <footer class="footer">
        <div class="row">
            Proporcionado por: <a href="http://geonode.org">GeoNode</a> <em>Versión 2.4</em> |
            <a href="/developer/">Desarrolladores</a> |
            <a href="/about/">Acerca de</a>
          </div>
            <label class="hidden">Idioma</label>
            <form class="form-inline" action="/i18n/setlang/" method="post">
            <input type='hidden' name='csrfmiddlewaretoken' value='jwfEKZjzwie2cflbenmB0s4wNuXKAFTn' />
              <select class="col-md-6 pull-right" name="language" onchange="javascript:form.submit()">
                <option value="en" >
                  English
                </option>
                <option value="es"  selected="selected">
                  Español
                </option>
                <option value="it" >
                  Italiano
                </option>
                <option value="fr" >
                  Français
                </option>
                <option value="de" >
                  Deutsch
                </option>
                <option value="el" >
                  Ελληνικά
                </option>
                <option value="id" >
                  Bahasa Indonesia
                </option>
                <option value="zh-cn" >
                  中文
                </option>
                <option value="ja" >
                  日本語
                </option>
                <option value="fa" >
                  Persian
                </option>
                <option value="ar" >
                  Arabic
                </option>
                <option value="bn" >
                  Bengali
                </option>
                <option value="ne" >
                  Nepali
                </option>
                <option value="sq" >
                  Albanian
                </option>
                <option value="af" >
                  Afrikaans
                </option>
                <option value="sw" >
                  Swahili
                </option>
                <option value="pt" >
                  Portuguese
                </option>
                <option value="ru" >
                  Russian
                </option>
                <option value="vi" >
                  Vietnamese
                </option>
                <option value="ko" >
                  한국어
                </option>
                <option value="am" >
                  Amharic
                </option>
                <option value="km" >
                  Khmer
                </option>
                <option value="pl" >
                  Polish
                </option>
                <option value="sv" >
                  Swedish
                </option>
                <option value="th" >
                  ไทย
                </option>
                <option value="uk" >
                  Ukranian
                </option>
                <option value="si" >
                  Sinhala
                </option>
                <option value="ta" >
                  Tamil
                </option>
                <option value="tl" >
                  Tagalog
                </option>
              </select>
            </form>
          </div>
        </div>
      </div>
    </footer>
    <!-- Modal must stay outside the navbar -->
    <div class="modal fade" id="UserModal" tabindex="-1" role="dialog" aria-labelledby="myModalLabel" aria-hidden="true">
      <div class="modal-dialog modal-sm">
        <div class="modal-content">
          <div class="modal-header">
            <button type="button" class="close" data-dismiss="modal" aria-hidden="true">×</button>
            <h4 class="modal-title" id="myModalLabel">Menu</h4>
          </div>
          <div class="modal-body">
            <ul class="list-unstyled">
              <li><a href="/layers/upload"><i class="fa fa-cloud-upload"></i> Subir Capas</a></li>
              <li class="modal-divider"></li>
              <li><a href="/people/profile/u0899jbe/"><i class="fa fa-user"></i> Perfil</a></li>
              <li><a href="/social/recent-activity"><i class="fa fa-fire"></i> Reciente Actividad</a></li>
              <li><a href="/messages/inbox/"><i class="fa fa-inbox"></i> Bandeja de entrada</a></li>
              <li><a title="Help" rel="tooltip" href="/help/"><i class="fa fa-question-circle"></i> Ayuda</a></li>
            </ul>
          </div>
          <div class="modal-footer">
            <form action="/account/logout/" id="logout_form" method="post">
              <a class="btn btn-warning btn-block" href="javascript:{}" onclick="document.getElementById('logout_form').submit();">Salir</a>
            </form>
          </div>
        </div>
      </div>
    </div>
    <!-- End of Modal -->
    <script src="/static/lib/js/assets.min.js?v=2.4"></script>
    <script src="/static/geonode/js/utils/utils.js?v=2.4"></script>
    <script src="/static/geonode/js/base/base.js?v=2.4"></script>
<script type="text/javascript">
jQuery(function($) {
function getCookie(name) {
    var cookieValue = null;
    if (document.cookie && document.cookie != '') {
        var cookies = document.cookie.split(';');
        for (var i = 0; i < cookies.length; i++) {
            var cookie = jQuery.trim(cookies[i]);
            // Does this cookie string begin with the name we want?
            if (cookie.substring(0, name.length + 1) == (name + '=')) {
                cookieValue = decodeURIComponent(cookie.substring(name.length + 1));
                break;
    return cookieValue;
function csrfSafeMethod(method) {
    // these HTTP methods do not require CSRF protection
    return (/^(GET|HEAD|OPTIONS|TRACE)$/.test(method));
function sameOrigin(url) {
    // test that a given url is a same-origin URL
    // url could be relative or scheme relative or absolute
    var host = document.location.host; // host + port
    var protocol = document.location.protocol;
    var sr_origin = '//' + host;
    var origin = protocol + sr_origin;
    // Allow absolute or scheme relative URLs to same origin
    return (url == origin || url.slice(0, origin.length + 1) == origin + '/') ||
        (url == sr_origin || url.slice(0, sr_origin.length + 1) == sr_origin + '/') ||
        // or any other URL that isn't scheme relative or absolute i.e relative.
        !(/^(\/\/|http:|https:).*/.test(url));
$.ajaxSetup({
    beforeSend: function(xhr, settings) {
        if (!csrfSafeMethod(settings.type) && sameOrigin(settings.url)) {
            // Send the token to same-origin, relative URLs only.
            // Send the token only if the method warrants CSRF protection
            // Using the CSRFToken value acquired earlier
            xhr.setRequestHeader("X-CSRFToken", getCookie('csrftoken'));
</script>
<script type="text/javascript" src="/static/autocomplete_light/django_admin.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/autocomplete.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/widget.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/addanother.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/text_widget.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/remote.js"></script>
<link rel="stylesheet" type="text/css" href="/static/autocomplete_light/style.css" />
    <script type="text/javascript" src="/jsi18n/"></script>
        var autocomplete = $('#search_input').yourlabsAutocomplete({
            url: '/autocomplete/ResourceBaseAutocomplete/',
            choiceSelector: 'span',
            hideAfter: 200,
            minimumCharacters: 1,
            placeholder: 'Escriba aquí su busqueda  ...',
            appendAutocomplete: $('#search_input'),
            autoHilightFirst: false
        $('#search_input').bind('selectChoice', function(e, choice, autocomplete) {
            if(choice[0].children[0] == undefined) {
                $('#search_input').val($(choice[0]).text());
                $('#search').submit();
    </script>
    <script>
        // Workaround to fix the autocomplete box positions
        yourlabs.Autocomplete.prototype.fixPosition = function(html) {
            this.input.parents().filter(function() {
                return $(this).css('overflow') === 'hidden';
            }).first().css('overflow', 'visible');
            if(this.input.attr('name') !== 'resource-keywords'){
              this.box.insertAfter(this.input).css({top: 0, left: 0});
            }else{
              var pos = $.extend({}, this.input.position(), {
                height: this.input.outerHeight()
              this.box.insertAfter(this.input).css({top: pos.top + pos.height, left: pos.left});
    </script>
    <script type="text/javascript" src="/lang.js"></script>
  </body>
</html>
Any Ideas?
Thanks.
Agur bero bat,
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
More information about the geonode-users mailing list
