[GeoNode-users] Migration of data from 2.0 to 2.4
Mana Etches manadotcom at gmail.com
Wed Feb 10 13:53:27 PST 2016
Hi Paolo,
Firstly, thanks for your help on this. We're getting closer and closer to
resolving the problem.
I found out what part of the problem was, nearly half of the data from GS
2.0 directory (layers and geotiffs) was missing in my GS 2.4 data
directory. After reuploading and running 'geonode udatelayers', the layers
updated successfully without any errors in geoserver logs. When logged in
as admin,  I can see the layers in GeoNode and GeoServer 'now all enabled'.
However, when I executed 'python create_auth_group_and_update_res.py', this
is within migrate2.sh, I see 2 main errors:
1. <class 'geoserver.catalog.FailedRequestError'>  for all layers
*Eg: Geoserver log error shows* - Caused by: java.io.FileNotFoundException:
/usr/share/geoserver/data/workspaces/geonode/tuv_10_500t/tuv_10_500t/coverage.xml.7dee7b3e-b96b-4c26-ae3a-7ea615dbabbb.tmp
(Permission denied)
2. <class 'geonode.layers.models.DoesNotExist'> for all layers.
Lastly, if I click on a layer in Geonode's GUI, nothing happens it seems
like the page gets refreshed, and no errors appear in the geoserver log.
It looks like the first error is caused by a permissions issue relative to
an xml files within my workspaces directory. Would you have some idea how
to remedy this?
Many thanks again Paolo
On Thu, Feb 11, 2016 at 4:54 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Yes, it looks like a configuration problem with GeoServer.
> After GeoServer data migration, and even before running migrate2.sh,
> you should already see all the layers in GeoNode and GeoServer admin if
> logged as superuser.
> migrate2.sh just takes care of permissions, tags and regions if I
> remember correctly.
> Does GeoServer log say anything when updatelayers raises <class
> 'geoserver.catalog.FailedRequestError'> ?
> p
> On Tue, Feb 9, 2016 at 4:46 PM, Mana Etches <manadotcom at gmail.com> wrote:
> > Hi Paolo,
> > We are getting somewhere,
> > I set 'settings_path = geonode.settings, then ran the
> > create_auth_group_and_update_res.py, I got the following results:
> > Creating the authenticated group...
> > Now adding all users to the group...
> > Adding geonode to the group
> > Adding admin to the group
> > Adding joyp to the group
> > Adding liteab to the group
> > Adding amritr to the group
> > Adding susanv to the group
> > Adding mereonik to the group
> > Adding sachin to the group
> > Adding Brookey to the group
> > Adding Faatasim to the group
> > Adding digitaki to the group
> > Adding david to the group
> > Adding norense to the group
> > Adding zarin to the group
> > Adding sereima to the group
> > Adding fane to the group
> > Adding keleni to the group
> > Adding philb to the group
> > Adding Keikos to the group
> > Adding keikos to the group
> > Adding Lawrence to the group
> > Adding seelan to the group
> > Adding test to the group
> > Adding Lowry to the group
> > Adding mana to the group
> > Updating resources...
> > Updating layer NU_Surface_Soil
> > Updating layer WS_TC_HazardMap Wind 100 MRP
> > Updating layer PW_Point_Building_Exposure_Verified
> > Updating layer NR_EQ_HazardMap_10_2500 MRP
> > Updating layer PW_EQ_HazardMap_10_2500 MRP
> > Updating layer NU_TC_HazardMap Wind 100 MRP
> > Updating layer VU_Area_Council
> > Updating layer VU_Average_Annual_Loss_for_Tropical_Cyclone_and_Earthquake
> > Updating layer PG_lae2_sub2.tif
> > Updating layer TO_EQ_HazardMap_PGA_100 MRP
> > Updating layer PW_Landuse Landcover
> > Updating layer PG_lae2_sub1.tif
> > Updating layer WS_EQ_HazardMap_PGA_2500 MRP
> > Updating layer FJ_Roads
> > Updating layer SB_munda_gsd05_o_sub2.tif
> > Updating layer TL_EQ_HazardMap_PGA_100 MRP
> > Updating layer TO_Roads
> > Updating layer MH_Landuse Landcover
> > Updating layer SB_EQ_HazardMap_10_100_MRP
> > Updating layer CK_Point_Building_Exposure_Modelled
> > Updating layer WS_Roads
> > Updating layer PW_EQ_HazardMap_03_2500 MRP
> > Updating layer SB_EQ_HazardMap_PGA_500_MRP
> > Updating layer TL_EQ_HazardMap_PGA_2500_MRP
> > Updating map Fiji
> > Updating layer TL_EQ_HazardMap_10_2500 MRP
> > Updating layer VU_EQ_HazardMap_10_500 MRP
> > Updating layer TL_EQ_HazardMap_10_500 MRP
> > Updating layer NR_TC_HazardMap Wind 500 MRP
> > Updating layer VU_TC_HazardMap Wind 250 MRP
> > Updating layer SB_westguale_sub6.tif
> > Updating layer NU_EQ_HazardMap_10_100 MRP
> > Updating layer PG_EQ_HazardMap_03_500 MRP
> > Updating layer TL_Landuse Landcover
> > Updating layer MH_Atoll
> > Updating layer SB_EQ_HazardMap_10_500_MRP
> > Updating layer CK_Point_Building_Exposure_Verified
> > Updating layer KI_EQ_HazardMap_10_100 MRP
> > Updating map
> > Updating layer KI_Island
> > Updating layer VU_ambae.tif
> > Updating layer TO_Building_Aggregate_Exposure
> > Updating layer FJ_Buildings
> > Updating layer VU_tanna2.tif
> > Updating layer TO_Average_Annual_Loss
> > Updating layer KI_Surface_Soil_Pt14
> > Updating layer CK_Enumeration_Area
> > Updating layer TV_Roads
> > Updating layer NR_District
> > Updating layer VU_Point_Building_Exposure_Verified
> > Updating layer TO_Surface_Soil
> > Updating layer VU_Landuse Landcover
> > Updating layer PG_lae1.tif
> > Updating layer FM_Point_Building_Exposure_Modelled
> > Updating layer CK_Rarotonga_Satellite_Image_2009
> > Updating layer TO_EQ_HazardMap_03_100 MRP
> > Updating layer FJ_EQ_HazardMap_PGA_500_MRP
> > Updating layer PW_Hamlet
> > Updating layer TV_EQ_HazardMap_03_100 MRP
> > Updating layer KI_TC_HazardMap Wind 100 MRP_West
> > Updating layer CK_Island
> > Updating layer TV_EQ_HazardMap_PGA_2500_MRP
> > Updating layer SB_Roads
> > Updating layer
> FJ_Average_Annual_Loss_For_Tropical_Cyclone_and_Earthquakes
> > Updating layer PG_madang_s.tif
> > Updating layer TV_TC_HazardMap Wind 250 MRP
> > Updating layer PW_EQ_HazardMap_03_100 MRP
> > Updating layer TV_TC_HazardMap Wind 500 MRP
> > Updating layer MH_EQ_HazardMap_10_500 MRP
> > Updating layer PG_Bridges
> > Updating layer NR_EQ_HazardMap_10_500 MRP
> > Updating layer TV_Building_Aggregate_Exposure
> > Updating layer PW_EQ_HazardMap_10_100 MRP
> > Updating layer FJ_EQ_HazardMap_10_2500 MRP
> > Updating layer PG_EQ_HazardMap_10_100 MRP
> > Updating layer PG_EQ_HazardMap_03_2500 MRP
> > Updating layer TV_EQ_HazardMap_PGA_500 MRP
> > Updating layer TL_TC_HazardMap Wind 500 MRP
> > Updating layer PW_Point_Building_Exposure_Modelled
> > Updating layer TV_EQ_HazardMap_PGA_100 MRP
> > Updating layer PG_TC_HazardMap Wind 100 MRP
> > Updating layer NU_EQ_HazardMap_10_2500 MRP
> > Updating layer TO_EQ_HazardMap_10_2500 MRP
> > Updating layer TV_Point_Building_Exposure_Modelled
> > Updating layer FM_TC_HazardMap Wind 50 MRP
> > Updating layer TO_b4.tif
> > Updating layer TV_Point_Building_Exposure_Verified
> > Updating layer FJ_8C
> > Updating layer TO_d2.tif
> > Updating layer WS_Point_Building_Exposure_Verified
> > Updating layer SB_Kolombangara_sub2
> > Updating layer VU_Surface_Soil
> > Updating layer WS_Surface_Soil
> > Updating layer SB_Auki_Satellite_Imagery_2005_s2
> > Updating layer SB_Honiara_Satellite_Imagery_2005_s1
> > Updating layer SB_EQ_HazardMap_03_500 MRP
> > Updating layer PG_Census_Unit
> > Updating layer WS_Building_Aggregate_Exposure
> > Updating layer TO_Landuse Landcover
> > Updating layer FM_EQ_HazardMap_03_100 MRP
> > Updating layer VU_Point_Building_Exposure_Modelled
> > Updating layer FM_EQ_HazardMap_10_500 MRP
> > Updating layer SB_Gizo_Satellite_Imagery_2005_s1
> > Updating layer NR_EQ_HazardMap_10_100 MRP
> > Updating layer SB_Honiara_Satellite_Imagery_2005_s2
> > Updating layer FJ_nadi_s1.tif
> > Updating layer TV_EQ_HazardMap_03_2500 MRP
> > Updating layer TV_Island
> > Updating layer NU_EQ_HazardMap_03_2500 MRP
> > Updating layer KI_Surface_Soil_Pt13
> > Updating layer FJ_Coastline
> > Updating layer PG_TC_HazardMap Wind 500 MRP
> > Updating layer SB_rannogga_2.tif
> > Updating layer VU_EQ_HazardMap_PGA_100 MRP
> > Updating layer PW_Surface_Soil
> > Updating layer TO_a2.tif
> > Updating layer TO_b3.tif
> > Updating layer FJ_Special_Infrastructure
> > Updating layer FM_EQ_HazardMap_10_2500 MRP
> > Updating layer KI_Surface_Soil_Pt11
> > Updating layer FJ_Specials
> > Updating layer WS_EQ_HazardMap_03_500 MRP
> > Updating layer KI_Surface_Soil_Pt12
> > Updating map Yasawa Group
> > Updating map Vanuatu
> > Updating document NU_Country_Profile
> > Updating document
> > Advancing_Disaster_Risk_Financing&Insurance_In_The_Pacific.pdf
> > Updating document VU_Country_Profile
> > Updating document Country Note THE COOK ISLANDS
> > Updating document Country Note Fiji
> > Updating document PG_Country_Profile
> > Updating document FM_Country_Profile
> > Updating document CATASTROPHE RISK ASSESSMENT METHODOLOGY
> > Updating document PW_Country_Profile
> > Updating document KI_Country_Profile
> > Updating document Country Note Solomon Islands
> > Updating document Country Note Marshall Islands
> > Updating document Country_Note_Vanuatu
> > Updating document TO_Country_Profile
> > Updating document Solomon Islands Country Profile
> > Updating document PCRAFI_Risk_Assessment_Methodology
> > Updating document Country_Note_Tonga
> > Updating document MH_Country_Profile
> > Updating document WS_Country_Profile
> > Updating document Country-Note-Samoa
> > Updating document TL_Country_Profile
> > Updating document NR_Country_Profile
> > Updating document FJ_Country_Profile
> > Updating document CK_Country_Profile
> > Updating document TV_Country_Profile
> > Updating document Country Note: Samoa; Disaster risk financing and
> > insurance, February 2015
> > Updating document Country Note: Tonga; Disaster risk financing and
> > Updating document Country Note: Cook Islands; Disaster risk financing and
> > Updating document Country Note: Vanuatu; Disaster risk financing and
> > Updating layer ck_evacuation_centers
> > GDAL_ERROR 4: Unable to open
> > /var/www/geonode/uploaded/layers/ck_evacuation_centers.shp or
> > /var/www/geonode/uploaded/layers/ck_evacuation_centers.SHP.
> > Could not open /var/www/geonode/uploaded/layers/ck_evacuation_centers.shp
> > <type 'exceptions.AssertionError'>
> > Updating layer rarotonga_electoral_boundaries
> > /var/www/geonode/uploaded/layers/rarotonga_electoral_boundaries.shp or
> > /var/www/geonode/uploaded/layers/rarotonga_electoral_boundaries.SHP.
> > Could not open
> > Updating layer mangaia_electoral_boundaries
> > /var/www/geonode/uploaded/layers/mangaia_electoral_boundaries.shp or
> > /var/www/geonode/uploaded/layers/mangaia_electoral_boundaries.SHP.
> > Could not open
> > Updating layer aitutaki_electoral_boundaries
> > /var/www/geonode/uploaded/layers/aitutaki_electoral_boundaries.shp or
> > /var/www/geonode/uploaded/layers/aitutaki_electoral_boundaries.SHP.
> > Could not open
> > I checked the layers in GUI of geonode and none of my migrate layers
> appear.
> > I checked the documents link, I see the meta data and links but I get an
> > internal error 500 when I try to download.
> > It looks like the clue we've got is <class
> > 'geoserver.catalog.FailedRequestError'>. This looks like a geoserver
> > configuration issue then, would you have some idea which configuration
> file
> > specifically. Is it contained within my Geoserver Directory? or
> elsewhere.
> > Mana
> > On Wed, Feb 10, 2016 at 10:14 AM, Paolo Corti <pcorti at gmail.com> wrote:
> >> Yes, I think that you need to fix the first error to have the
> >> migration working properly.
> >> Don't worry about the second error: you are getting IntegrityError as
> >> the records were already added to the database when you ran the script
> >> first time.
> >> The third error is caused by the first one.
> >> Let me know if you get more issues
> >> p
> >> On Tue, Feb 9, 2016 at 3:38 PM, Mana Etches <manadotcom at gmail.com>
> wrote:
> >> > Hi Paolo,
> >> > Firstly, I should have ran the python scripts individually within
> >> > migrate2.sh, I noticed some errors as follows:
> >> >  'create_auth_group_and_update_res.py', reveals error:
> >> > Traceback (most recent call last):
> >> >   File "create_auth_group_and_update_res.py", line 10, in <module>
> >> >     from geonode.groups.models import GroupProfile
> >> >   File
> >> > "/usr/local/lib/python2.7/dist-packages/geonode/groups/models.py",
> >> > line 5, in <module>
> >> >     from django.contrib.auth.models import Group
> >> >   File
> >> > "/usr/lib/python2.7/dist-packages/django/contrib/auth/__init__.py",
> >> > line 6, in <module>
> >> >     from django.middleware.csrf import rotate_token
> >> >   File "/usr/lib/python2.7/dist-packages/django/middleware/csrf.py",
> >> > line
> >> > 14, in <module>
> >> >     from django.utils.cache import patch_vary_headers
> >> >   File "/usr/lib/python2.7/dist-packages/django/utils/cache.py", line
> >> > 26, in
> >> > <module>
> >> >     from django.core.cache import get_cache
> >> >   File
> "/usr/lib/python2.7/dist-packages/django/core/cache/__init__.py",
> >> > line 69, in <module>
> >> >     if DEFAULT_CACHE_ALIAS not in settings.CACHES:
> >> >   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py",
> line
> >> > 54,
> >> > in __getattr__
> >> >     self._setup(name)
> line
> >> > 49,
> >> > in _setup
> >> >     self._wrapped = Settings(settings_module)
> line
> >> > 132,
> >> > in __init__
> >> >     % (self.SETTINGS_MODULE, e)
> >> > ImportError: Could not import settings '/etc/genode/local_settings.py'
> >> > (Is
> >> > it on sys.path? Is there an import error in the settings file?):
> Import
> >> > by
> >> > filename is not supported.
> >> > The second script, 'migrate_tags.py', ran errors for the first part
> >> > relative
> >> > to psycopg2.IntegrityError on my layers, eg:
> >> > ('Municipality', 'municipality')
> >> > <class 'psycopg2.IntegrityError'>
> >> > duplicate key value violates unique constraint "taggit_tag_name_key"
> >> > DETAIL:  Key (name)=(Island) already exists.
> >> > ('Island', 'island')
> >> > DETAIL:  Key (name)=(Atoll) already exists.
> >> > ('Atoll', 'atoll')
> >> > DETAIL:  Key (name)=(nr) already exists.
> >> > ('nr', 'nr')
> >> > DETAIL:  Key (name)=(District) already exists.
> >> > ('District', 'district')
> >> > DETAIL:  Key (name)=(Village) already exists.
> >> > ('Village', 'village')
> >> > DETAIL:  Key (name)=(Local Level Government) already exists.
> >> > ('Local Level Government', 'local-level-government')
> >> > DETAIL:  Key (name)=(Building Replacement Cost) already exists.
> >> > ('Building Replacement Cost', 'building-replacement-cost')
> >> > DETAIL:  Key (name)=(State) already exists.
> >> > ('State', 'state')
> >> > DETAIL:  Key (name)=(Ward) already exists.
> >> > ('Ward', 'ward')
> >> > DETAIL:  Key (name)=(Sub District) already exists.
> >> > ('Sub District', 'sub-district')
> >> > DETAIL:  Key (name)=(Area Council) already exists.
> >> > ('Area Council', 'area-council')
> >> > DETAIL:  Key (name)=(hazards) already exists.
> >> > ('hazards', 'hazards')
> >> > DETAIL:  Key (name)=(Building Exposure Aggregates) already exists.
> >> > ('Building Exposure Aggregates', 'building-exposure-aggregates')
> >> > DETAIL:  Key (name)=(nrj) already exists.
> >> > ('nrj', 'nrj')
> >> > DETAIL:  Key (name)=(Land cover) already exists.
> >> > ('Land cover', 'land-cover')
> >> > DETAIL:  Key (name)=(Land use) already exists.
> >> > ('Land use', 'land-use')
> >> > DETAIL:  Key (name)=(Land Cover) already exists.
> >> > ('Land Cover', 'land-cover_1')
> >> > DETAIL:  Key (name)=(Land Use) already exists.
> >> > ('Land Use', 'land-use_1')
> >> > DETAIL:  Key (name)=(Average Annual Loss For TC & EQ) already exists.
> >> > ('Average Annual Loss For TC & EQ', 'average-annual-loss-for-tc-eq')
> >> > DETAIL:  Key (name)=(Average Annual Loss) already exists.
> >> > ('Average Annual Loss', 'average-annual-loss')
> >> > DETAIL:  Key (name)=(Building Replacement Costs) already exists.
> >> > ('Building Replacement Costs', 'building-replacement-costs')
> >> > DETAIL:  Key (name)=(Exposure Cash Crops) already exists.
> >> > ('Exposure Cash Crops', 'exposure-cash-crops')
> >> > DETAIL:  Key (name)=(imagery) already exists.
> >> > ('imagery', 'imagery')
> >> > DETAIL:  Key (name)=(REQUIRED: Common-use word or phrase used to
> >> > describe
> >> > the subject of the data set.) already exists.
> >> > ('REQUIRED: Common-use word or phrase used to describe the subject of
> >> > the
> >> > data set.',
> 'required-common-use-word-or-phrase-used-to-describe-the-subject-of-the-data-set')
> >> > DETAIL:  Key (name)=(Average Annual Loss TC & EQ) already exists.
> >> > ('Average Annual Loss TC & EQ', 'average-annual-loss-tc-eq')
> >> > DETAIL:  Key (name)=(Average Annual Loss for TC & EQ) already exists.
> >> > ('Average Annual Loss for TC & EQ', 'average-annual-loss-for-tc-eq_1')
> >> > DETAIL:  Key (name)=(Population) already exists.
> >> > ('Population', 'population')
> >> > DETAIL:  Key (name)=(Average Annual Loss tc and eq) already exists.
> >> > ('Average Annual Loss tc and eq', 'average-annual-loss-tc-and-eq')
> >> > DETAIL:  Key (name)=(Average Annual Loss for Tropical Cyclone and
> >> > Earthquake) already exists.
> >> > ('Average Annual Loss for Tropical Cyclone and Earthquake',
> >> > 'average-annual-loss-for-tropical-cyclone-and-earthquake')
> >> > DETAIL:  Key (name)=(Probabilistic) already exists.
> >> > ('Probabilistic', 'probabilistic')
> >> > DETAIL:  Key (name)=(Earthquake) already exists.
> >> > ('Earthquake', 'earthquake')
> >> > DETAIL:  Key (name)=(Hazard) already exists.
> >> > ('Hazard', 'hazard')
> >> > DETAIL:  Key (name)=(cyclone) already exists.
> >> > ('cyclone', 'cyclone')
> >> > DETAIL:  Key (name)=(solomons) already exists.
> >> > ('solomons', 'solomons')
> >> > DETAIL:  Key (name)=(risk) already exists.
> >> > ('risk', 'risk')
> >> > DETAIL:  Key (name)=(Summary Report) already exists.
> >> > ('Summary Report', 'summary-report')
> >> > DETAIL:  Key (name)=(Risk Assessment) already exists.
> >> > ('Risk Assessment', 'risk-assessment')
> >> > DETAIL:  Key (name)=(Loss) already exists.
> >> > ('Loss', 'loss')
> >> > DETAIL:  Key (name)=(Topography) already exists.
> >> > ('Topography', 'topography')
> >> > DETAIL:  Key (name)=(Document) already exists.
> >> > ('Document', 'document')
> >> > DETAIL:  Key (name)=(Imagery) already exists.
> >> > ('Imagery', 'imagery_1')
> >> > DETAIL:  Key (name)=(Soil) already exists.
> >> > ('Soil', 'soil')
> >> > DETAIL:  Key (name)=(SOILS) already exists.
> >> > ('SOILS', 'soils')
> >> > DETAIL:  Key (name)=(SOIL) already exists.
> >> > And the last python script, 'migrate_group_permissions.py', revealed:
> >> >   File "migrate_group_permissions.py", line 16, in <module>
> >> >     authenticated_group_id = dst_cur.next()[0]
> >> > StopIteration
> >> > Correct me if I'm wrong, it looks like the error in the first script
> is
> >> > related to my settings_path within gn_migration.cfg file. I saw within
> >> > the
> >> > forums that this should be set to 'settings_path = geonode.settings'.
> >> > As for errors in scripts migrate_tags.py and
> >> > migrate_group_permissions.py,
> >> > I'm hoping to get your advice on this part.
> >> > Thank you immensely,
> >> > Mana
> >> > On Wed, Feb 10, 2016 at 5:09 AM, Paolo Corti <pcorti at gmail.com>
> wrote:
> >> >> Hi Mana
> >> >> did you run migrate2.sh after migrating the GeoServer data directory?
> >> >> did you see any error running that script?
> >> >> p
> >> >> On Tue, Feb 9, 2016 at 2:00 AM, Mana Etches <manadotcom at gmail.com>
> >> >> wrote:
> >> >> > Hello geonode gurus,
> >> >> > I've installed geonode 2.4 following instructions at
> >> >> > http://geonode.org/blog/2015/11/19/geonode-2.4-released/
> >> >> > I've followed Capooti's migration steps at guidelines at
> https://github.com/capooti/geonode/blob/migration_from20_to_24/scripts/migrations/migrate20to24/index.rst
> >> >> > I'm at a point where I can see the number of layers, maps and users
> >> >> > on
> >> >> > geonode GUI (but only as a registered user). I can log into
> geoserver
> >> >> > admin,
> >> >> > however I don't see my layers, stores, on the admin panel.
> >> >> > I uploaded 2.0 GS data directory to geoserver 2.4 data directory as
> >> >> > follows:
> >> >> > data/default     to    data/default
> >> >> > gwc-layers      to     gwc/layers
> >> >> > workspaces/geonode    to      workspaces/geonode/datastore
> >> >> > Note, I can upload layers just fine but I can only see the the
> layers
> >> >> > that I
> >> >> > uploaded in the geonode_data in postgres. I can't see the layers
> from
> >> >> > 2.0
> >> >> > database.
> >> >> > Lastly I ran a 'geonode updatelayers' and got the following
> results:
> >> >> > Finished processing 4 layers in 2.0 seconds.
> >> >> > 0 Created layers
> >> >> > 4 Updated layers
> >> >> > 0 Failed layers
> >> >> > 0.500000 seconds per layer
> >> >> > Updating only the layers that I uploaded.
> >> >> > For referencing purposes see my 'gn_migration.cfg' configurations
> >> >> > below:
> >> >> > [db20]
> >> >> > dbname = old_db
> >> >> > host = 192.168.137.12
> >> >> > user = geonode
> >> >> > password = secret (replaced)
> >> >> > [db24]
> >> >> > dbname = geonode
> >> >> > user = geonode
> >> >> > [path]
> >> >> > geonode_path = /usr/local/lib/python2.7/dist-packages/geonode
> >> >> > settings_path = /etc/genode/local_settings.py
> >> >> > My gut feeling is its a configuration issue.
> >> >> > Any help or point in the right direction would be very much
> >> >> > appreciated
> >> >> > Mana
> >> >> > _______________________________________________
> >> >> > geonode-users mailing list
> >> >> > geonode-users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/geonode-users
> >> >> Paolo Corti
> >> >> Geospatial software developer
> >> >> web: http://www.paolocorti.net
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160211/0163e5e5/attachment-0001.html>
More information about the geonode-users mailing list
