[GeoNode-users] Geonode SRS 3857
Allan Oware allanoware at gmail.com
Fri Feb 12 00:37:20 PST 2016
Hi Simone,
On the same topic, is it possible for GeoNode/GeoServer/Geoexplorer to
support upload/storage/visualization of data which is in a projected
coordinate system
specific to a country e.g ITRF 2005 (rwanda) ?
When I attempt to upload such data in my 2.4 instance, the uploader returns
"GeoServer failed to detect the projection for layer [airports]. It doesn't
look like EPSG:4326, so backing out the layer."
Regards,
On Thu, Feb 11, 2016 at 3:34 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Can't reach your server, anyway would be strange if geoserver treats
> 900913 requests different from 3857.
> @afabiani any hints?
> 2016-02-11 10:26 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
>> Hi Simone,
>> It’s strange yes… In GeoServer the layers are served in 3857 (native and
>> declared) and if I preview the layer directly from GeoServer I can see
>> those labels correctly but once loaded into the GeoExplorer Map the tiles
>> are requested under 900913, I mean, I’ve tracking them down with fiddler
>> and I can’t see anywhere a 3857 parameter.
>> If you want to check the layer I’m using you can do it with:
>> http://www.geo.euskadi.eus/WMS_NEKAZARITZA?
>> LAYER=ADR_DR_TEXT
>> Agur bero bat,
>> David Alda Fernández de Lezea
>> Área de Sistemas de Información Geográfica, Planificación Territorial y
>> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
>> Arloa.
>> dalda at hazi.eus | www.hazi.eus
>> T 945 003 240 – M 627 923 170 – F 945 003 290
>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
>> *********************  LEGE OHARRA   *******************   AVISOLEGAL
>> *******************   DISCLAIMER   *****************************
>> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
>> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
>> kontserbatu gabe.
>> Este mensaje es personal y confidencial y su uso no autorizado está
>> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
>> sin reenviarlo ni conservarlo.
>> This message is personal and confidential, unauthorised use is legally
>> prohibited. If you are not the intended recipient, delete it without
>> resending or backing it.
>> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
>> Enviado el: jueves, 11 de febrero de 2016 10:11
>> Para: David Alda Fernandez de Lezea
>> CC: geonode-users at lists.osgeo.org
>> Asunto: Re: [GeoNode-users] Geonode SRS 3857
>> Hi,
>> the two srs should be exactly the same. I've loaded many 3857 layers
>> without any issue or need to change the geonode code. Also, geonode
>> preserves the native projection so in geoserver they are published as 3857
>> and geoexplorer just directly load them.
>> Not sure why you get deformed labels.
>> 2016-02-10 12:54 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>> Hi list,
>> I need to change the default CRS to EPSG:3857. In theory it's the same to
>> EPSG:900913 but when I get a layer in a native 3857 CRS if I load the layer
>> into the GeoExplorer the labels and vector contours appear slightly
>> deformed.
>> I've changed views.py and layers.py but I still get in the map
>> SRS=EPSG:900913 requests..
>> Where do I have to change the default srs?
>> Is there a plan to move from 900913 to 3857?? 900913 seems to be obsolete
>> and the official is 3857?
>> Thanks,
>> Agur bero bat,
>> Arloa.
>> T 945 003 240 - M 627 923 170 - F 945 003 290
>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
>> kontserbatu gabe.
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
Allan Oware
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160212/9352e291/attachment.html>
More information about the geonode-users mailing list
