[GeoNode-users] Geonode SRS 3857
David Alda Fernandez de Lezea dalda at hazi.eus
Fri Feb 12 02:38:00 PST 2016
It's a public service from the Basque Government, you should be able to reach it.
Do you have/know any service that serves data in EPSG:3857 to test it with our GeoNode installation?
Anyway, I'll ask in the GeoServer list to get a bit more of information.
Thanks,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: jueves, 11 de febrero de 2016 13:34
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Geonode SRS 3857
Can't reach your server, anyway would be strange if geoserver treats 900913 requests different from 3857.
@afabiani any hints?
2016-02-11 10:26 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi Simone,
It’s strange yes… In GeoServer the layers are served in 3857 (native and declared) and if I preview the layer directly from GeoServer I can see those labels correctly but once loaded into the GeoExplorer Map the tiles are requested under 900913, I mean, I’ve tracking them down with fiddler and I can’t see anywhere a 3857 parameter.
If you want to check the layer I’m using you can do it with:
http://www.geo.euskadi.eus/WMS_NEKAZARITZA?
LAYER=ADR_DR_TEXT
Agur bero bat,
Enviado el: jueves, 11 de febrero de 2016 10:11
the two srs should be exactly the same. I've loaded many 3857 layers without any issue or need to change the geonode code. Also, geonode preserves the native projection so in geoserver they are published as 3857 and geoexplorer just directly load them.
Not sure why you get deformed labels.
2016-02-10 12:54 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
I need to change the default CRS to EPSG:3857. In theory it's the same to EPSG:900913 but when I get a layer in a native 3857 CRS if I load the layer into the GeoExplorer the labels and vector contours appear slightly deformed.
I've changed views.py and layers.py but I still get in the map SRS=EPSG:900913 requests..
Where do I have to change the default srs?
Is there a plan to move from 900913 to 3857?? 900913 seems to be obsolete and the official is 3857?
Thanks,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
More information about the geonode-users mailing list
