[GeoNode-users] Errors creating map from layer
Simone Dalmasso simone.dalmasso at gmail.com
Mon Feb 15 00:02:41 PST 2016
Hi, did you change the default map SRS to something different than 900913?
I geonode doesn't find the 900913 then thinks that the projection is 4326
which should be supported but apparently there may be a bug with the 4326
support.
We need to explore more. I'll open a ticket in case you confirm that you
changed the default projection.
2016-02-15 8:31 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> I've began to receive an error 500 when creating a Map from layers link
> "create a map". I get the following:
> [Fri Feb 12 06:51:36.716735 2016] [:error] [pid 20620:tid
> 140326078498560] Internal Server Error: /maps/new
> [Fri Feb 12 06:51:36.716762 2016] [:error] [pid 20620:tid 140326078498560]
> Traceback (most recent call last):
> [Fri Feb 12 06:51:36.716767 2016] [:error] [pid 20620:tid
> 140326078498560]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112,
> in get_response
> [Fri Feb 12 06:51:36.716772 2016] [:error] [pid 20620:tid
> 140326078498560]     response = wrapped_callback(request, *callback_args,
> **callback_kwargs)
> [Fri Feb 12 06:51:36.716776 2016] [:error] [pid 20620:tid
> "/usr/local/lib/python2.7/dist-packages/geonode/maps/views.py", line 388,
> in new_map
> [Fri Feb 12 06:51:36.716779 2016] [:error] [pid 20620:tid
> 140326078498560]     config = new_map_config(request)
> [Fri Feb 12 06:51:36.716783 2016] [:error] [pid 20620:tid
> "/usr/local/lib/python2.7/dist-packages/geonode/maps/views.py", line 529,
> in new_map_config
> [Fri Feb 12 06:51:36.716796 2016] [:error] [pid 20620:tid
> 140326078498560]     layer_params=json.dumps(config),
> [Fri Feb 12 06:51:36.716800 2016] [:error] [pid 20620:tid
> 140326078498560]   File "/usr/lib/python2.7/json/__init__.py", line 243, in
> dumps
> [Fri Feb 12 06:51:36.716803 2016] [:error] [pid 20620:tid
> 140326078498560]     return _default_encoder.encode(obj)
> [Fri Feb 12 06:51:36.716806 2016] [:error] [pid 20620:tid
> 140326078498560]   File "/usr/lib/python2.7/json/encoder.py", line 207, in
> encode
> [Fri Feb 12 06:51:36.716809 2016] [:error] [pid 20620:tid
> 140326078498560]     chunks = self.iterencode(o, _one_shot=True)
> [Fri Feb 12 06:51:36.716812 2016] [:error] [pid 20620:tid
> 140326078498560]   File "/usr/lib/python2.7/json/encoder.py", line 270, in
> iterencode
> [Fri Feb 12 06:51:36.716815 2016] [:error] [pid 20620:tid
> 140326078498560]     return _iterencode(o, 0)
> [Fri Feb 12 06:51:36.716818 2016] [:error] [pid 20620:tid
> 140326078498560]   File "/usr/lib/python2.7/json/encoder.py", line 184, in
> default
> [Fri Feb 12 06:51:36.716821 2016] [:error] [pid 20620:tid
> 140326078498560]     raise TypeError(repr(o) + " is not JSON serializable")
> [Fri Feb 12 06:51:36.716824 2016] [:error] [pid 20620:tid 140326078498560]
> TypeError: Decimal('-3.4519594771') is not JSON serializable
> [Fri Feb 12 06:51:36.732762 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858] mod_wsgi (pid=20620): Exception occurred
> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Fri Feb 12 06:51:36.732793 2016] [:error] [pid 20620:tid
> 140326078498560] [remote 192.168.1.65:1858] Traceback (most recent call
> last):
> [Fri Feb 12 06:51:36.732813 2016] [:error] [pid 20620:tid
> 140326078498560] [remote 192.168.1.65:1858]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
> in __call__
> [Fri Feb 12 06:51:36.732949 2016] [:error] [pid 20620:tid
> 140326078498560] [remote 192.168.1.65:1858]     response =
> self.get_response(request)
> [Fri Feb 12 06:51:36.732969 2016] [:error] [pid 20620:tid
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
> in get_response
> [Fri Feb 12 06:51:36.732992 2016] [:error] [pid 20620:tid
> self.handle_uncaught_exception(request, resolver, sys.exc_info())
> [Fri Feb 12 06:51:36.733004 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
> in handle_uncaught_exception
> [Fri Feb 12 06:51:36.733021 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     return callback(request, **param_dict)
> [Fri Feb 12 06:51:36.733036 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
> _wrapped_view
> [Fri Feb 12 06:51:36.733104 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     response = view_func(request, *args,
> **kwargs)
> [Fri Feb 12 06:51:36.733120 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in
> server_error
> [Fri Feb 12 06:51:36.733178 2016] [:error] [pid 20620:tid 140326078498560]
> http.HttpResponseServerError(template.render(Context({})))
> [Fri Feb 12 06:51:36.733193 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
> render
> [Fri Feb 12 06:51:36.733483 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     return self._render(context)
> [Fri Feb 12 06:51:36.733501 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
> _render
> [Fri Feb 12 06:51:36.733520 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     return self.nodelist.render(context)
> [Fri Feb 12 06:51:36.733542 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
> render
> [Fri Feb 12 06:51:36.733560 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     bit = self.render_node(node, context)
> [Fri Feb 12 06:51:36.733571 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
> render_node
> [Fri Feb 12 06:51:36.733586 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     return node.render(context)
> [Fri Feb 12 06:51:36.733600 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53,
> in render
> [Fri Feb 12 06:51:36.733692 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     result = self.nodelist.render(context)
> [Fri Feb 12 06:51:36.733707 2016] [:error] [pid 20620:tid 140326078498560]
> render
> [Fri Feb 12 06:51:36.733725 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733736 2016] [:error] [pid 20620:tid 140326078498560]
> render_node
> [Fri Feb 12 06:51:36.733751 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733762 2016] [:error] [pid 20620:tid 140326078498560]
> 155, in render
> [Fri Feb 12 06:51:36.733777 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     return self.render_template(self.template,
> context)
> [Fri Feb 12 06:51:36.733788 2016] [:error] [pid 20620:tid 140326078498560]
> 137, in render_template
> [Fri Feb 12 06:51:36.733803 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     output = template.render(context)
> [Fri Feb 12 06:51:36.733814 2016] [:error] [pid 20620:tid 140326078498560]
> render
> [Fri Feb 12 06:51:36.733828 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733839 2016] [:error] [pid 20620:tid 140326078498560]
> _render
> [Fri Feb 12 06:51:36.733853 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733864 2016] [:error] [pid 20620:tid 140326078498560]
> render
> [Fri Feb 12 06:51:36.733878 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733889 2016] [:error] [pid 20620:tid 140326078498560]
> render_node
> [Fri Feb 12 06:51:36.733903 2016] [:error] [pid 20620:tid 140326078498560]
> [Fri Feb 12 06:51:36.733914 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
> line 24, in render
> [Fri Feb 12 06:51:36.733962 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     request = context["request"]
> [Fri Feb 12 06:51:36.733979 2016] [:error] [pid 20620:tid 140326078498560]
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Fri Feb 12 06:51:36.734058 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858]     raise KeyError(key)
> [Fri Feb 12 06:51:36.734080 2016] [:error] [pid 20620:tid 140326078498560]
> [remote 192.168.1.65:1858] KeyError: 'request'
> [Fri Feb 12 06:51:54.321429 2016] [:error] [pid 20620:tid
> 140326061713152] Internal Server Error: /maps/new
> [Fri Feb 12 06:51:54.321461 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.321465 2016] [:error] [pid 20620:tid
> 140326061713152]   File
> in get_response
> [Fri Feb 12 06:51:54.321468 2016] [:error] [pid 20620:tid
> 140326061713152]     response = wrapped_callback(request, *callback_args,
> **callback_kwargs)
> [Fri Feb 12 06:51:54.321472 2016] [:error] [pid 20620:tid
> in new_map
> [Fri Feb 12 06:51:54.321475 2016] [:error] [pid 20620:tid
> 140326061713152]     config = new_map_config(request)
> [Fri Feb 12 06:51:54.321478 2016] [:error] [pid 20620:tid
> in new_map_config
> [Fri Feb 12 06:51:54.321481 2016] [:error] [pid 20620:tid
> 140326061713152]     layer_params=json.dumps(config),
> [Fri Feb 12 06:51:54.321484 2016] [:error] [pid 20620:tid
> 140326061713152]   File "/usr/lib/python2.7/json/__init__.py", line 243, in
> dumps
> [Fri Feb 12 06:51:54.321487 2016] [:error] [pid 20620:tid
> 140326061713152]     return _default_encoder.encode(obj)
> [Fri Feb 12 06:51:54.321491 2016] [:error] [pid 20620:tid
> 140326061713152]   File "/usr/lib/python2.7/json/encoder.py", line 207, in
> encode
> [Fri Feb 12 06:51:54.321494 2016] [:error] [pid 20620:tid
> 140326061713152]     chunks = self.iterencode(o, _one_shot=True)
> [Fri Feb 12 06:51:54.321497 2016] [:error] [pid 20620:tid
> 140326061713152]   File "/usr/lib/python2.7/json/encoder.py", line 270, in
> iterencode
> [Fri Feb 12 06:51:54.321500 2016] [:error] [pid 20620:tid
> 140326061713152]     return _iterencode(o, 0)
> [Fri Feb 12 06:51:54.321503 2016] [:error] [pid 20620:tid
> 140326061713152]   File "/usr/lib/python2.7/json/encoder.py", line 184, in
> default
> [Fri Feb 12 06:51:54.321506 2016] [:error] [pid 20620:tid
> 140326061713152]     raise TypeError(repr(o) + " is not JSON serializable")
> [Fri Feb 12 06:51:54.321509 2016] [:error] [pid 20620:tid 140326061713152]
> TypeError: Decimal('-3.4519594766') is not JSON serializable
> [Fri Feb 12 06:51:54.336518 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336549 2016] [:error] [pid 20620:tid
> 140326061713152] [remote 192.168.1.65:1858] Traceback (most recent call
> last):
> [Fri Feb 12 06:51:54.336569 2016] [:error] [pid 20620:tid
> 140326061713152] [remote 192.168.1.65:1858]   File
> in __call__
> [Fri Feb 12 06:51:54.336596 2016] [:error] [pid 20620:tid
> 140326061713152] [remote 192.168.1.65:1858]     response =
> [Fri Feb 12 06:51:54.336610 2016] [:error] [pid 20620:tid
> in get_response
> [Fri Feb 12 06:51:54.336627 2016] [:error] [pid 20620:tid
> [Fri Feb 12 06:51:54.336639 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336655 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336678 2016] [:error] [pid 20620:tid 140326061713152]
> _wrapped_view
> [Fri Feb 12 06:51:54.336697 2016] [:error] [pid 20620:tid 140326061713152]
> **kwargs)
> [Fri Feb 12 06:51:54.336708 2016] [:error] [pid 20620:tid 140326061713152]
> server_error
> [Fri Feb 12 06:51:54.336724 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336736 2016] [:error] [pid 20620:tid 140326061713152]
> render
> [Fri Feb 12 06:51:54.336752 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336762 2016] [:error] [pid 20620:tid 140326061713152]
> _render
> [Fri Feb 12 06:51:54.336777 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336788 2016] [:error] [pid 20620:tid 140326061713152]
> render
> [Fri Feb 12 06:51:54.336802 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336813 2016] [:error] [pid 20620:tid 140326061713152]
> render_node
> [Fri Feb 12 06:51:54.336842 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336857 2016] [:error] [pid 20620:tid 140326061713152]
> in render
> [Fri Feb 12 06:51:54.336875 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336886 2016] [:error] [pid 20620:tid 140326061713152]
> render
> [Fri Feb 12 06:51:54.336900 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336911 2016] [:error] [pid 20620:tid 140326061713152]
> render_node
> [Fri Feb 12 06:51:54.336925 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336936 2016] [:error] [pid 20620:tid 140326061713152]
> 155, in render
> [Fri Feb 12 06:51:54.336951 2016] [:error] [pid 20620:tid 140326061713152]
> context)
> [Fri Feb 12 06:51:54.336962 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336977 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.336988 2016] [:error] [pid 20620:tid 140326061713152]
> render
> [Fri Feb 12 06:51:54.337002 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337019 2016] [:error] [pid 20620:tid 140326061713152]
> _render
> [Fri Feb 12 06:51:54.337035 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337046 2016] [:error] [pid 20620:tid 140326061713152]
> render
> [Fri Feb 12 06:51:54.337060 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337070 2016] [:error] [pid 20620:tid 140326061713152]
> render_node
> [Fri Feb 12 06:51:54.337085 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337095 2016] [:error] [pid 20620:tid 140326061713152]
> line 24, in render
> [Fri Feb 12 06:51:54.337111 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337122 2016] [:error] [pid 20620:tid 140326061713152]
> __getitem__
> [Fri Feb 12 06:51:54.337137 2016] [:error] [pid 20620:tid 140326061713152]
> [Fri Feb 12 06:51:54.337155 2016] [:error] [pid 20620:tid 140326061713152]
> It occurs in any layer type..
> Any ideas?
> Thanks.
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160215/1c5f7292/attachment-0001.html>
More information about the geonode-users mailing list
