[GeoNode-users] I can't pubishing map: internal error server
Enzo Cocca enzo.ccc at gmail.com
Wed Feb 17 04:30:48 PST 2016
yes in geonode.conf
2016-02-17 13:18 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> Hi everyone,
> It works with my instalation also. Perfect! Thank you!
> The apache configuration Enzo suggested is on geonode.conf? I am asking
> because everything is working on my server (geonode and all the other
> websites).
> Best regards,
> Ivo
> 2016-02-16 16:30 GMT+00:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Enzo,
>> I just tried the solution you proposed. Actually it works! I'm happy for
>> that.
>> Of course a curiosity still remain: I don't know why in the server setup
>> for test
>> the module wsgi doesn't crash with module php5.
>> Thank you again,
>> best
>> Eugenio
>> Date: Fri, 12 Feb 2016 18:14:13 +0100
>> Subject: Re: [GeoNode-users] I can't pubishing map: internal error server
>> From: enzo.ccc at gmail.com
>> To: frippe12573 at hotmail.com; geonode-users at lists.osgeo.org
>> maybe the solution is simple:
>> try to use libapache-mod-fcgid and php5-fpm and disable mod-php5
>> but you need install
>> example in apache configuration:
>> <Directory /var/www/app/>
>>   AddHandler fcgid-script .php
>>   FCGIWrapper /usr/bin/php .php
>>   Options ExecCGI
>> </Directory>
>>   ciao
>> E
>> 2016-02-10 16:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi all,
>> just to update all of you, yesterday I restarted the installation from
>> scratch. I follow the administrator installation guide,
>> of course taking into consideration my system.
>> I installed again geonode from git, deleted and re-installed the DBs in
>> my already running postgresql-postgis and deploy again geoserver
>> obtained after paver server start action.
>> This time I also deleted all the packages already downloaded in
>> /usr/local/lib/python2.7/site-packages in order to let pip install -e . to
>> get
>> packages required again.
>> Everything went well, and almost the functionalities works fine, again
>> excluding saving a new map.
>> Here below the error I got on apache error.log:
>> Wed Feb 10 09:22:25.197172 2016] [:error] [pid 25962] Internal Server
>> Error: /maps/new/data
>> [Wed Feb 10 09:22:25.197247 2016] [:error] [pid 25962] Traceback (most
>> recent call last):
>> [Wed Feb 10 09:22:25.197256 2016] [:error] [pid 25962]   File
>> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line
>> 112, in get_response
>> [Wed Feb 10 09:22:25.197261 2016] [:error] [pid 25962]     response =
>> wrapped_callback(request, *callback_args, **callback_kwargs)
>> [Wed Feb 10 09:22:25.197266 2016] [:error] [pid 25962]   File
>> "/dati/geonode/geonode/maps/views.py", line 428, in new_map_json
>> [Wed Feb 10 09:22:25.197270 2016] [:error] [pid 25962]
>> map_obj.update_from_viewer(body)
>> [Wed Feb 10 09:22:25.197274 2016] [:error] [pid 25962]   File
>> "/dati/geonode/geonode/maps/models.py", line 173, in update_from_viewer
>> [Wed Feb 10 09:22:25.197279 2016] [:error] [pid 25962]
>> conf['map']['zoom'])
>> [Wed Feb 10 09:22:25.197283 2016] [:error] [pid 25962]   File
>> "/dati/geonode/geonode/base/models.py", line 437, in
>> set_bounds_from_center_and_zoom
>> [Wed Feb 10 09:22:25.197287 2016] [:error] [pid 25962]     lon, lat =
>> get_lon_lat()
>> [Wed Feb 10 09:22:25.197292 2016] [:error] [pid 25962]   File
>> "/dati/geonode/geonode/base/models.py", line 429, in get_lon_lat
>> [Wed Feb 10 09:22:25.197296 2016] [:error] [pid 25962]     lon, lat =
>> transform(mercator, wgs84, center_x, center_y)
>> [Wed Feb 10 09:22:25.197300 2016] [:error] [pid 25962]   File
>> "/usr/local/lib/python2.7/dist-packages/pyproj/__init__.py", line 504, in
>> transform
>> [Wed Feb 10 09:22:25.197305 2016] [:error] [pid 25962]
>> _proj._transform(p1,p2,inx,iny,inz,radians)
>> [Wed Feb 10 09:22:25.197309 2016] [:error] [pid 25962]   File
>> "_proj.pyx", line 361, in _proj._transform (_proj.c:3762)
>> [Wed Feb 10 09:22:25.197314 2016] [:error] [pid 25962] RuntimeError:
>> geocentric transformation missing z or ellps
>> [Wed Feb 10 16:22:26.082801 2016] [core:notice] [pid 25957] AH00051:
>> child pid 25962 exit signal Segmentation fault (11), possible coredump in
>> /tmp/core-dump
>> Last line stated that a possible coredump, due to the segmentation fault,
>> maybe has been created (actually not).
>> In this case a new map is listed, however it is empty, which means that
>> the layer I used has not been saved.
>> The action create a row in the db (geonode) but almost all field are
>> empty. It seems the application doesn't pass values
>> in the db. I guess this fault raise the seg fault.
>> I hope this can help to find a solution or a sort of workaround.
>> E.
>> Date: Tue, 9 Feb 2016 21:35:18 +0000
>> From: ivojfs at gmail.com
>> To: simone.dalmasso at gmail.com; enzo.ccc at gmail.com;
>> geonode-users at lists.osgeo.org; ingenieroariel at gmail.com;
>> Hi everyone,
>> Eugenio is right, it appear's that it could be exactly the same error. I
>> haven't found the solution either.
>> If there's something I can do to help to find out, please let me know.
>> Best regards,
>> Ivo
>> 2016-02-09 18:13 GMT+00:00 Enzo Cocca <enzo.ccc at gmail.com>:
>> Hi,
>> I haven't resolved the problem and I can not find the solution.
>> Someone have same idea?
>> E
>> 2016-02-09 10:39 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>> Hi Simone,
>> I have configurated geonode like instruction
>> Geonode is installed on ubuntuserver 14.04 with a ip  public adress.
>> Every thinks work very well but just the publishing map dasn't work.
>> So today I will review the apache configuration and I will let you know.
>> If you have any idea about this error, please let me know
>> Thanks
>> E
>> 2016-02-08 21:00 GMT+01:00 <geonode-users-request at lists.osgeo.org>:
>> Send geonode-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/mailman/listinfo/geonode-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         geonode-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>>    1. Re: I can't pubishing map: internal error server (Eugenio Trumpy)
>> Message: 1
>> Date: Mon, 8 Feb 2016 15:21:00 +0100
>> From: Eugenio Trumpy <frippe12573 at hotmail.com>
>> To: Simone Dalmasso <simone.dalmasso at gmail.com>, Enzo Cocca
>>         <enzo.ccc at gmail.com>, "ivojfs at gmail.com" <ivojfs at gmail.com>
>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>         server
>> Message-ID: <DUB123-W4169565D16F21E8DBC0876E5D50 at phx.gbl>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Hi Enzo and Simone,
>> this is more or less what happened to me [1] recently and, if I remember
>> well, to Ivo Santos [2] in january.
>> I would propose to put together the forces to solve this issue, to find
>> out what is produce wsgi mod crash on apache.
>> Best regards
>> Eugenio
>> [1]
>> https://lists.osgeo.org/pipermail/geonode-users/2016-January/001281.html
>> [2]
>> https://lists.osgeo.org/pipermail/geonode-users/2016-January/001366.html
>> From: simone.dalmasso at gmail.com
>> Date: Mon, 8 Feb 2016 14:50:02 +0100
>> To: enzo.ccc at gmail.com
>> CC: geonode-users at lists.osgeo.org
>> Hi,
>> how did you install Geonode? What is your platform? You are not the first
>> that gets this error and we need as much information as possible to
>> understand what configuration is causing it. The error should come from
>> apache configuration see
>> http://stackoverflow.com/questions/4331310/apache-with-mod-wsgi-segfaults
>> 2016-02-08
>> <http://stackoverflow.com/questions/4331310/apache-with-mod-wsgi-segfaults2016-02-08>
>> 12:33 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>> Hi,
>> I can't publishing map. I have the internal error server. So in apache
>> error log I have founf this problem:
>> [Mon Feb 08 12:30:01.758476 2016] [core:error] [pid 59907] [client
>> 90.147.101.142:38620] End of script output before headers: wsgi.py,
>> referer: http://myipaddress/maps/new
>> [Mon Feb 08 12:30:02.353489 2016] [core:notice] [pid 59412] AH00051:
>> child pid 59416 exit signal Segmentation fault (11), possible coredump in
>> /etc/apache2
>> How can I resolve it?
>> Thanks
>> E
>> Enzo Cocca PhDin "Science and Technology for Archaeology and Cultural
>> Heritage"
>> mail: enzo.ccc at gmail.comcell: +393495087014
>> Simone
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20160208/8eaf4d48/attachment-0001.html
>> Subject: Digest Footer
>> End of geonode-users Digest, Vol 13, Issue 15
>> Enzo Cocca PhD
>> in "Science and Technology for Archaeology and Cultural Heritage"
>> cell: +393495087014
>> Enzo Cocca PhD
>> cell: +393495087014
>> Ivo Santos
>> Enzo Cocca PhD
>> cell: +393495087014
> Ivo Santos
Enzo Cocca PhD
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160217/c416971b/attachment-0001.html>
More information about the geonode-users mailing list
