[GeoNode-users] I can't pubishing map: internal error server
Ivo Santos ivojfs at gmail.com
Wed Feb 17 04:37:06 PST 2016
Ok, thank you.
2016-02-17 12:30 GMT+00:00 Enzo Cocca <enzo.ccc at gmail.com>:
> yes in geonode.conf
> 2016-02-17 13:18 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi everyone,
>> It works with my instalation also. Perfect! Thank you!
>> The apache configuration Enzo suggested is on geonode.conf? I am asking
>> because everything is working on my server (geonode and all the other
>> websites).
>> Best regards,
>> Ivo
>> 2016-02-16 16:30 GMT+00:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Enzo,
>>> I just tried the solution you proposed. Actually it works! I'm happy for
>>> that.
>>> Of course a curiosity still remain: I don't know why in the server setup
>>> for test
>>> the module wsgi doesn't crash with module php5.
>>> Thank you again,
>>> best
>>> Eugenio
>>> Date: Fri, 12 Feb 2016 18:14:13 +0100
>>> Subject: Re: [GeoNode-users] I can't pubishing map: internal error server
>>> From: enzo.ccc at gmail.com
>>> To: frippe12573 at hotmail.com; geonode-users at lists.osgeo.org
>>> maybe the solution is simple:
>>> try to use libapache-mod-fcgid and php5-fpm and disable mod-php5
>>> but you need install
>>> example in apache configuration:
>>> <Directory /var/www/app/>
>>>   AddHandler fcgid-script .php
>>>   FCGIWrapper /usr/bin/php .php
>>>   Options ExecCGI
>>> </Directory>
>>>   ciao
>>> E
>>> 2016-02-10 16:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi all,
>>> just to update all of you, yesterday I restarted the installation from
>>> scratch. I follow the administrator installation guide,
>>> of course taking into consideration my system.
>>> I installed again geonode from git, deleted and re-installed the DBs in
>>> my already running postgresql-postgis and deploy again geoserver
>>> obtained after paver server start action.
>>> This time I also deleted all the packages already downloaded in
>>> /usr/local/lib/python2.7/site-packages in order to let pip install -e . to
>>> get
>>> packages required again.
>>> Everything went well, and almost the functionalities works fine, again
>>> excluding saving a new map.
>>> Here below the error I got on apache error.log:
>>> Wed Feb 10 09:22:25.197172 2016] [:error] [pid 25962] Internal Server
>>> Error: /maps/new/data
>>> [Wed Feb 10 09:22:25.197247 2016] [:error] [pid 25962] Traceback (most
>>> recent call last):
>>> [Wed Feb 10 09:22:25.197256 2016] [:error] [pid 25962]   File
>>> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line
>>> 112, in get_response
>>> [Wed Feb 10 09:22:25.197261 2016] [:error] [pid 25962]     response =
>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>> [Wed Feb 10 09:22:25.197266 2016] [:error] [pid 25962]   File
>>> "/dati/geonode/geonode/maps/views.py", line 428, in new_map_json
>>> [Wed Feb 10 09:22:25.197270 2016] [:error] [pid 25962]
>>> map_obj.update_from_viewer(body)
>>> [Wed Feb 10 09:22:25.197274 2016] [:error] [pid 25962]   File
>>> "/dati/geonode/geonode/maps/models.py", line 173, in update_from_viewer
>>> [Wed Feb 10 09:22:25.197279 2016] [:error] [pid 25962]
>>> conf['map']['zoom'])
>>> [Wed Feb 10 09:22:25.197283 2016] [:error] [pid 25962]   File
>>> "/dati/geonode/geonode/base/models.py", line 437, in
>>> set_bounds_from_center_and_zoom
>>> [Wed Feb 10 09:22:25.197287 2016] [:error] [pid 25962]     lon, lat =
>>> get_lon_lat()
>>> [Wed Feb 10 09:22:25.197292 2016] [:error] [pid 25962]   File
>>> "/dati/geonode/geonode/base/models.py", line 429, in get_lon_lat
>>> [Wed Feb 10 09:22:25.197296 2016] [:error] [pid 25962]     lon, lat =
>>> transform(mercator, wgs84, center_x, center_y)
>>> [Wed Feb 10 09:22:25.197300 2016] [:error] [pid 25962]   File
>>> "/usr/local/lib/python2.7/dist-packages/pyproj/__init__.py", line 504, in
>>> transform
>>> [Wed Feb 10 09:22:25.197305 2016] [:error] [pid 25962]
>>> _proj._transform(p1,p2,inx,iny,inz,radians)
>>> [Wed Feb 10 09:22:25.197309 2016] [:error] [pid 25962]   File
>>> "_proj.pyx", line 361, in _proj._transform (_proj.c:3762)
>>> [Wed Feb 10 09:22:25.197314 2016] [:error] [pid 25962] RuntimeError:
>>> geocentric transformation missing z or ellps
>>> [Wed Feb 10 16:22:26.082801 2016] [core:notice] [pid 25957] AH00051:
>>> child pid 25962 exit signal Segmentation fault (11), possible coredump in
>>> /tmp/core-dump
>>> Last line stated that a possible coredump, due to the segmentation
>>> fault, maybe has been created (actually not).
>>> In this case a new map is listed, however it is empty, which means that
>>> the layer I used has not been saved.
>>> The action create a row in the db (geonode) but almost all field are
>>> empty. It seems the application doesn't pass values
>>> in the db. I guess this fault raise the seg fault.
>>> I hope this can help to find a solution or a sort of workaround.
>>> E.
>>> Date: Tue, 9 Feb 2016 21:35:18 +0000
>>> From: ivojfs at gmail.com
>>> To: simone.dalmasso at gmail.com; enzo.ccc at gmail.com;
>>> geonode-users at lists.osgeo.org; ingenieroariel at gmail.com;
>>> Hi everyone,
>>> Eugenio is right, it appear's that it could be exactly the same error. I
>>> haven't found the solution either.
>>> If there's something I can do to help to find out, please let me know.
>>> Best regards,
>>> Ivo
>>> 2016-02-09 18:13 GMT+00:00 Enzo Cocca <enzo.ccc at gmail.com>:
>>> Hi,
>>> I haven't resolved the problem and I can not find the solution.
>>> Someone have same idea?
>>> E
>>> 2016-02-09 10:39 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>>> Hi Simone,
>>> I have configurated geonode like instruction
>>> Geonode is installed on ubuntuserver 14.04 with a ip  public adress.
>>> Every thinks work very well but just the publishing map dasn't work.
>>> So today I will review the apache configuration and I will let you know.
>>> If you have any idea about this error, please let me know
>>> Thanks
>>> E
>>> 2016-02-08 21:00 GMT+01:00 <geonode-users-request at lists.osgeo.org>:
>>> Send geonode-users mailing list submissions to
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>         http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>         geonode-users-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-users digest..."
>>> Today's Topics:
>>>    1. Re: I can't pubishing map: internal error server (Eugenio Trumpy)
>>> Message: 1
>>> Date: Mon, 8 Feb 2016 15:21:00 +0100
>>> From: Eugenio Trumpy <frippe12573 at hotmail.com>
>>> To: Simone Dalmasso <simone.dalmasso at gmail.com>, Enzo Cocca
>>>         <enzo.ccc at gmail.com>, "ivojfs at gmail.com" <ivojfs at gmail.com>
>>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>>         server
>>> Message-ID: <DUB123-W4169565D16F21E8DBC0876E5D50 at phx.gbl>
>>> Content-Type: text/plain; charset="iso-8859-1"
>>> Hi Enzo and Simone,
>>> this is more or less what happened to me [1] recently and, if I remember
>>> well, to Ivo Santos [2] in january.
>>> I would propose to put together the forces to solve this issue, to find
>>> out what is produce wsgi mod crash on apache.
>>> Best regards
>>> Eugenio
>>> [1]
>>> https://lists.osgeo.org/pipermail/geonode-users/2016-January/001281.html
>>> [2]
>>> https://lists.osgeo.org/pipermail/geonode-users/2016-January/001366.html
>>> From: simone.dalmasso at gmail.com
>>> Date: Mon, 8 Feb 2016 14:50:02 +0100
>>> To: enzo.ccc at gmail.com
>>> CC: geonode-users at lists.osgeo.org
>>> Hi,
>>> how did you install Geonode? What is your platform? You are not the
>>> first that gets this error and we need as much information as possible to
>>> understand what configuration is causing it. The error should come from
>>> apache configuration see
>>> http://stackoverflow.com/questions/4331310/apache-with-mod-wsgi-segfaults
>>> 2016-02-08
>>> <http://stackoverflow.com/questions/4331310/apache-with-mod-wsgi-segfaults2016-02-08>
>>> 12:33 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>>> Hi,
>>> I can't publishing map. I have the internal error server. So in apache
>>> error log I have founf this problem:
>>> [Mon Feb 08 12:30:01.758476 2016] [core:error] [pid 59907] [client
>>> 90.147.101.142:38620] End of script output before headers: wsgi.py,
>>> referer: http://myipaddress/maps/new
>>> [Mon Feb 08 12:30:02.353489 2016] [core:notice] [pid 59412] AH00051:
>>> child pid 59416 exit signal Segmentation fault (11), possible coredump in
>>> /etc/apache2
>>> How can I resolve it?
>>> Thanks
>>> E
>>> Enzo Cocca PhDin "Science and Technology for Archaeology and Cultural
>>> Heritage"
>>> mail: enzo.ccc at gmail.comcell: +393495087014
>>> Simone
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <
>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20160208/8eaf4d48/attachment-0001.html
>>> Subject: Digest Footer
>>> End of geonode-users Digest, Vol 13, Issue 15
>>> Enzo Cocca PhD
>>> in "Science and Technology for Archaeology and Cultural Heritage"
>>> cell: +393495087014
>>> Enzo Cocca PhD
>>> cell: +393495087014
>>> Ivo Santos
>>> Enzo Cocca PhD
>>> cell: +393495087014
>> Ivo Santos
> Enzo Cocca PhD
> cell: +393495087014
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160217/71669719/attachment-0001.html>
More information about the geonode-users mailing list
