[GeoNode-users] Errors on layer info after upgrade
Annalisa Schiavon annalisa.schiavon at gmail.com
Thu Feb 18 06:19:43 PST 2016
Maybe I found the error. In my layers_style table, the field "sld_url" is
like:
<bound method Style.body_href of <geoserver.style.Style object at
0x7f9a0fda9610>>
or
http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
If I change the field to "
http://localhost:8080/geoserver/rest/styles/acque_transizione.sld", for
example, there's no errors for that layer.
I've launched an updatelayers for all my layers, before found this, but it
doesn't correct the layer's styles. Is it linked to this issue:
https://github.com/GeoNode/geonode/issues/2329 ?
However the updatelayers has deleted some layers, I don't know why, and
then it has re-created them, correctly.
So, now, I have to change manually all "sld_url" values or you have other
suggestions?
Thanks
Annalisa
2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
> Hi Alessio
> See if data in field 'detail_url' from table base_resourcebase are
> correct. It should not be empty.
> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
> Did you specify the DB PORT on your local_settings.py?
> If so, be sure the value is quoted:
> "5432"
> if you remove the quotes you'll get an error similar to the one on the
> logs.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon <
> annalisa.schiavon at gmail.com> wrote:
>> I have sld styles for all my layers. But on geoserver, the preview works
>> fine.
>> What field on DB I have to check?
>> It may be due to the fact that I don't have upload sessions associated to
>> my layers?
>> I usually load layers on postgis, then I create layers in geoserver and
>> then I throw  geonode updatelayers from console.
>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon <
>>> annalisa.schiavon at gmail.com>:
>>> > Hi all,
>>> > I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors during
>>> > installation, no problem to log in geonode and geoserver, but the
>>> layer info
>>> > page  gives "Internal Server Error".
>>> > It's all ok in maps, on layers list's, but when I click on a layer, it
>>> gives
>>> > internal error.
>>> Accoridng to lines 73-74 of erro.log it seems that the script
>>> geonode/layers/models.py is unable to make the right url for sld style
>>> (index out of range)
>>> Do you have custom sld style associated to  the tested layer
>>> (rete_balneazione_2015)?
>>> Amedeo Fadini
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
> best regards
> Muhammad Nabi Ahmad
> Twitter : mnabiahmad
> Blog    : https://scriptndebug.wordpress.com/
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160218/4ba10bc9/attachment.html>
More information about the geonode-users mailing list
