[GeoNode-users] Errors on layer info after upgrade
Annalisa Schiavon annalisa.schiavon at gmail.com
Thu Feb 18 09:18:26 PST 2016
The layer info page doesn't caused errors on 2.4c1, but the "manage style"
operation caused no result on "load styles".
I don't know what value had sld_url.
I upgrade ubuntu, after having update ppa references. Then I've changed the
geoserver data-dir, from default to my path. At this point I have 73 layers
on geoserver and also on geonode, but the errors described above.
Than I run updatelayers, but with no result. I run again updatelayers,
adding some layers, and the new layers have the right value of sld_url and
the layer info page is OK forma the news.
Il 18/feb/2016 03:28 PM, "Paolo Corti" <pcorti at gmail.com> ha scritto:
> Hi Annalisa
> this is strange indeed, because accordingly to what you did the value
> for sld_url shouldn't have changed (unless you run updatelayers on the
> layer), and that value indicates that at
> some point the layer was saved and this generated the error (every
> time the layer is saved the style table is synced with GeoServer).
> Are you sure that this page was not causing error also on 2.4c1?
> cheers
> p
> On Thu, Feb 18, 2016 at 9:19 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
> > Maybe I found the error. In my layers_style table, the field "sld_url" is
> > like:
> > <bound method Style.body_href of <geoserver.style.Style object at
> > 0x7f9a0fda9610>>
> > or
> > http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
> > If I change the field to
> > "http://localhost:8080/geoserver/rest/styles/acque_transizione.sld", for
> > example, there's no errors for that layer.
> > I've launched an updatelayers for all my layers, before found this, but
> it
> > doesn't correct the layer's styles. Is it linked to this issue:
> > https://github.com/GeoNode/geonode/issues/2329 ?
> > However the updatelayers has deleted some layers, I don't know why, and
> then
> > it has re-created them, correctly.
> > So, now, I have to change manually all "sld_url" values or you have other
> > suggestions?
> > Thanks
> > Annalisa
> > 2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
> >> Hi Alessio
> >> See if data in field 'detail_url' from table base_resourcebase are
> >> correct. It should not be empty.
> >> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
> >> Did you specify the DB PORT on your local_settings.py?
> >> If so, be sure the value is quoted:
> >> "5432"
> >> if you remove the quotes you'll get an error similar to the one on the
> >> logs.
> >> Best Regards,
> >> Alessio Fabiani.
> >> GeoServer Professional Services from the experts!
> >> Visit http://goo.gl/it488V for more information.
> >> Ing. Alessio Fabiani
> >> @alfa7691
> >> Founder/Technical Lead
> >> GeoSolutions S.A.S.
> >> Via di Montramito 3/A
> >> 55054  Massarosa (LU)
> >> Italy
> >> phone: +39 0584 962313
> >> fax:     +39 0584 1660272
> >> mob:   +39 333 8128928
> >> http://www.geo-solutions.it
> >> http://twitter.com/geosolutions_it
> >> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> >> Le informazioni contenute in questo messaggio di posta elettronica e/o
> >> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro
> >> utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> >> finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> >> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> >> via e-mail e di procedere alla distruzione del messaggio stesso,
> >> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> >> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per
> >> finalità diverse, costituisce comportamento contrario ai principi
> dettati
> >> dal D.Lgs. 196/2003.
> >> The information in this message and/or attachments, is intended solely
> for
> >> the attention and use of the named addressee(s) and may be confidential
> or
> >> proprietary in nature or covered by the provisions of privacy act
> >> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> >> Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> >> copying, distribution, or either dissemination, either whole or
> partial, is
> >> strictly forbidden except previous formal approval of the named
> >> addressee(s). If you are not the intended recipient, please contact
> >> immediately the sender by telephone, fax or e-mail and delete the
> >> information in this message that has been received in error. The sender
> does
> >> not give any warranty or accept liability as the content, accuracy or
> >> completeness of sent messages and accepts no responsibility  for changes
> >> made after they were sent or for other risks which arise as a result of
> >> e-mail transmission, viruses, etc.
> >> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon
> >>> I have sld styles for all my layers. But on geoserver, the preview
> works
> >>> fine.
> >>> What field on DB I have to check?
> >>> It may be due to the fact that I don't have upload sessions associated
> to
> >>> my layers?
> >>> I usually load layers on postgis, then I create layers in geoserver and
> >>> then I throw  geonode updatelayers from console.
> >>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
> >>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon
> >>>> <annalisa.schiavon at gmail.com>:
> >>>> > Hi all,
> >>>> > I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors during
> >>>> > installation, no problem to log in geonode and geoserver, but the
> >>>> > layer info
> >>>> > page  gives "Internal Server Error".
> >>>> > It's all ok in maps, on layers list's, but when I click on a layer,
> it
> >>>> > gives
> >>>> > internal error.
> >>>> Accoridng to lines 73-74 of erro.log it seems that the script
> >>>> geonode/layers/models.py is unable to make the right url for sld style
> >>>> (index out of range)
> >>>> Do you have custom sld style associated to  the tested layer
> >>>> (rete_balneazione_2015)?
> >>>> Amedeo Fadini
> >>> _______________________________________________
> >>> geonode-users mailing list
> >>> geonode-users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> >> best regards
> >> Muhammad Nabi Ahmad
> >> Twitter : mnabiahmad
> >> Blog    : https://scriptndebug.wordpress.com/
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160218/5564cfa9/attachment-0001.html>
More information about the geonode-users mailing list
