[GeoNode-users] Errors on layer info after upgrade
Paolo Corti pcorti at gmail.com
Fri Feb 19 13:13:41 PST 2016
Ah, thanks!
Didn't think about it
cheers
p
On Fri, Feb 19, 2016 at 3:44 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Hi Paolo,
> it is also possible to override it by passing a java system property like JAVA_OPTS="-DGEOSERVER_DATA_DIR=<somewhere>" to your container’s jvm options of its init script.
> Francesco
> Il giorno 19/feb/2016, alle ore 16:47, Paolo Corti <pcorti at gmail.com> ha scritto:
>> Hi Annalisa
>> that is the only setting where you can change the location of the
>> GeoServer data directory.
>> p
>> On Fri, Feb 19, 2016 at 5:05 AM, Annalisa Schiavon
>> <annalisa.schiavon at gmail.com> wrote:
>>> I was wondering, there is a place in geonode where setting the
>>> Geoserver-data-dir?
>>> I've just modified web.xml file in /usr/share/geoserver/WEB-INF
>>> 2016-02-18 18:18 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
>>>> The layer info page doesn't caused errors on 2.4c1, but the "manage style"
>>>> operation caused no result on "load styles".
>>>> I don't know what value had sld_url.
>>>> I upgrade ubuntu, after having update ppa references. Then I've changed
>>>> the geoserver data-dir, from default to my path. At this point I have 73
>>>> layers on geoserver and also on geonode, but the errors described above.
>>>> Than I run updatelayers, but with no result. I run again updatelayers,
>>>> adding some layers, and the new layers have the right value of sld_url and
>>>> the layer info page is OK forma the news.
>>>> Il 18/feb/2016 03:28 PM, "Paolo Corti" <pcorti at gmail.com> ha scritto:
>>>>> Hi Annalisa
>>>>> this is strange indeed, because accordingly to what you did the value
>>>>> for sld_url shouldn't have changed (unless you run updatelayers on the
>>>>> layer), and that value indicates that at
>>>>> some point the layer was saved and this generated the error (every
>>>>> time the layer is saved the style table is synced with GeoServer).
>>>>> Are you sure that this page was not causing error also on 2.4c1?
>>>>> cheers
>>>>> p
>>>>> On Thu, Feb 18, 2016 at 9:19 AM, Annalisa Schiavon
>>>>>> Maybe I found the error. In my layers_style table, the field "sld_url"
>>>>>> is
>>>>>> like:
>>>>>> <bound method Style.body_href of <geoserver.style.Style object at
>>>>>> 0x7f9a0fda9610>>
>>>>>> or
>>>>>> http://localhost:8080/geoserver/rest/styles/depuratoripubblici.xml
>>>>>> If I change the field to
>>>>>> "http://localhost:8080/geoserver/rest/styles/acque_transizione.sld",
>>>>>> for
>>>>>> example, there's no errors for that layer.
>>>>>> I've launched an updatelayers for all my layers, before found this, but
>>>>>> it
>>>>>> doesn't correct the layer's styles. Is it linked to this issue:
>>>>>> https://github.com/GeoNode/geonode/issues/2329 ?
>>>>>> However the updatelayers has deleted some layers, I don't know why, and
>>>>>> then
>>>>>> it has re-created them, correctly.
>>>>>> So, now, I have to change manually all "sld_url" values or you have
>>>>>> other
>>>>>> suggestions?
>>>>>> Thanks
>>>>>> Annalisa
>>>>>> 2016-02-18 14:44 GMT+01:00 Muhammad <mnabiahmad at gmail.com>:
>>>>>>> Hi Alessio
>>>>>>> See if data in field 'detail_url' from table base_resourcebase are
>>>>>>> correct. It should not be empty.
>>>>>>> On 02/18/2016 04:11 PM, Alessio Fabiani wrote:
>>>>>>> Did you specify the DB PORT on your local_settings.py?
>>>>>>> If so, be sure the value is quoted:
>>>>>>> "5432"
>>>>>>> if you remove the quotes you'll get an error similar to the one on the
>>>>>>> logs.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> GeoServer Professional Services from the experts!
>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A
>>>>>>> 55054  Massarosa (LU)
>>>>>>> Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax:     +39 0584 1660272
>>>>>>> mob:   +39 333 8128928
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
>>>>>>> Il loro
>>>>>>> utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>> per le
>>>>>>> finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>> messaggio
>>>>>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>>>>>>> notizia
>>>>>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>>>>>>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>> divulgarlo
>>>>>>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>> utilizzarlo per
>>>>>>> finalità diverse, costituisce comportamento contrario ai principi
>>>>>>> dettati
>>>>>>> dal D.Lgs. 196/2003.
>>>>>>> The information in this message and/or attachments, is intended solely
>>>>>>> for
>>>>>>> the attention and use of the named addressee(s) and may be
>>>>>>> confidential or
>>>>>>> proprietary in nature or covered by the provisions of privacy act
>>>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection
>>>>>>> Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction,
>>>>>>> copying, distribution, or either dissemination, either whole or
>>>>>>> partial, is
>>>>>>> strictly forbidden except previous formal approval of the named
>>>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>> information in this message that has been received in error. The
>>>>>>> sender does
>>>>>>> not give any warranty or accept liability as the content, accuracy or
>>>>>>> completeness of sent messages and accepts no responsibility  for
>>>>>>> changes
>>>>>>> made after they were sent or for other risks which arise as a result
>>>>>>> of
>>>>>>> e-mail transmission, viruses, etc.
>>>>>>> On Thu, Feb 18, 2016 at 1:47 PM, Annalisa Schiavon
>>>>>>>> I have sld styles for all my layers. But on geoserver, the preview
>>>>>>>> works
>>>>>>>> fine.
>>>>>>>> What field on DB I have to check?
>>>>>>>> It may be due to the fact that I don't have upload sessions
>>>>>>>> associated to
>>>>>>>> my layers?
>>>>>>>> I usually load layers on postgis, then I create layers in geoserver
>>>>>>>> and
>>>>>>>> then I throw  geonode updatelayers from console.
>>>>>>>> 2016-02-18 13:14 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
>>>>>>>>> 2016-02-18 12:54 GMT+01:00 Annalisa Schiavon
>>>>>>>>>> Hi all,
>>>>>>>>>> I've just upgrade geonode from 2.4c1 to 2.4 stable. No errors
>>>>>>>>>> during
>>>>>>>>>> installation, no problem to log in geonode and geoserver, but the
>>>>>>>>>> layer info
>>>>>>>>>> page  gives "Internal Server Error".
>>>>>>>>>> It's all ok in maps, on layers list's, but when I click on a
>>>>>>>>>> layer, it
>>>>>>>>>> gives
>>>>>>>>>> internal error.
>>>>>>>>> Accoridng to lines 73-74 of erro.log it seems that the script
>>>>>>>>> geonode/layers/models.py is unable to make the right url for sld
>>>>>>>>> style
>>>>>>>>> (index out of range)
>>>>>>>>> Do you have custom sld style associated to  the tested layer
>>>>>>>>> (rete_balneazione_2015)?
>>>>>>>>> Amedeo Fadini
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> best regards
>>>>>>> Muhammad Nabi Ahmad
>>>>>>> Twitter : mnabiahmad
>>>>>>> Blog    : https://scriptndebug.wordpress.com/
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
