[GeoNode-users] Copy part of the layers in a geonode instance
Daniel Victoria daniel.victoria at gmail.com
Wed Feb 24 05:52:17 PST 2016
Hi Alessio,
Good to know this export/import feature is being investigated. Will be a
nice addition. As for your suggestion, where can I get the layers JSon?
Directily from the database? I'm more of a user than a developer.
Thanks
Daneil
On Wed, Feb 24, 2016 at 8:15 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear Daniel,
> as part of the Backup&Restore procedure I am investigating a way to
> export/import part of the GeoNode data.
> WARNING: All this work is in progress, so at this time there is nothing
> ready to use.
> The idea is the following one:
> 1. Providing to the user a management command to backup the GeoNode
> catalog. The whole catalog or part of it.
> - This will make use of the "fixtures" and there should be a way to
> provide somehow a query or a list of keys to store a subset of the layers.
> - Backup the GeoServer data.
> 2. Providing to the user a management command to restore the GeoNode
> - The command will use saved fixtures to restore GeoNode data.
> - Restore the GeoServer data.
> As a first implementation there will be the possibility to save the whole
> catalog as a set of Json fixtures.
> For you specific use case, the possibility would be to take the Layers
> JSON and preserve "only" the layers you want to restore.
> On GeoServer side you will need to get the layers data manually. This is
> possible simply by getting the files from the GEOSERVER_DATA_DIRECTORY:
>  - Get the saved shapefiles from the upload subfolder
>  - Get the catalog metadata from workspace/geonode subfolder
>  - Get the styles SLDs and XMLs from styles subfolder
>  - Reload the catalog from the admin interface or restart GeoServer.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Feb 23, 2016 at 8:44 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> We have a GeoNode instance with more than 1000 layers published. We'd
>> like to have a seccond GeoNode site with only some of the layers published
>> in the first site, around 100. So far we've though of two ways to do this:
>> 1) install a clean GeoNode and manually register the 100 layers
>> 2) Copy the GeoNode with 1000 layers and manually delete the 900 excess
>> layers
>> The first option sound better, specially if we use the importlayers
>> command. But can I import the metadata with the importlayers commad?
>> Are there any other options?
>> Thanks
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160224/5e0bd566/attachment-0001.html>
More information about the geonode-users mailing list
